dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Nov 13, 2019 10:28 am Post subject: Spare tire carrier identification |
There appears to be at least three variants of the spare tire carrier "clamshell".
1. The most common is for the 185-195 14" steel wheels and tires #251801901D
2. The slightly larger, I guess, version for 205 14" alloy wheels #255801901A
3. And the elusive SA version that will carry a Rhein or Starburst 15" part #BCR801901 or 22S804001B. I don't know which number is correct.
The question, how are they identified? There does not appear to be a part number stamped as is commonly done by VW. _________________ Schau in das Buch
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Wed Nov 13, 2019 7:24 pm Post subject: Re: Spare tire carrier identification |
This shows the taller tang for the 205 tire version.
Mark |
Posted: Wed Nov 13, 2019 7:29 pm Post subject: Re: Spare tire carrier identification |
Thanks for the replies thus far. Since I have Rhein wheels I am particularly interested in compatibility. _________________ Schau in das Buch |
Posted: Wed Nov 13, 2019 7:38 pm Post subject: Re: Spare tire carrier identification |
The tire is the limiting factor.
The diameter, width, and profile are keys.
The model of the wheel isn't so important other than how it affects the dimensions of the tire. The width of the rim can make a big difference with respect to tire contact in the 2 key places.
Mark |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4777 Location: Bemidji, MN
Posted: Wed Nov 13, 2019 7:39 pm Post subject: Re: Spare tire carrier identification |
interesting. i swapped out my munged up steel wheel carrier for one off of a Carat with Al wheels... never noticed the drop for the bolt but i'm sure it is there. have to think of something to do with all that extra room! _________________ -dan
www.thefixitworkshop.com |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Wed Nov 13, 2019 8:26 pm Post subject: Re: Spare tire carrier identification |
I have a 90 Carat that came with 205/70R14 on alloys. I upgraded to 205/65R15 on Rhein rims and the spare fits fine in the clamshell. |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Wed Nov 13, 2019 10:53 pm Post subject: Re: Spare tire carrier identification |
Also, if I recall correctly, these two primary versions on USA vans also came with different "bars" that go above the tire and also form the hinge pin for the clamshell. I recall taking photos in years ago when I had 2 varieties side-by-side, but don't have access to those photos at the moment.
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
