ben_dubai Samba Member
Posted: Wed Nov 13, 2019 8:44 pm Post subject: Urgent Help - VIN 21 window |
Hey guys I need urgent support as the bus is in auction running out today.
It’s a 21 window bus but can’t get the number decodes. I wanna make sure it is an original 21 window. Can someone help please
Thanks
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Wed Nov 13, 2019 9:15 pm Post subject: Re: URGENT HELP - VIN 21 window |
The "Bus VIN / Chassis Numbers" is available thru the "Technical" button up above, and the "Models" link is at the top of that page.
Problem is the tag you have an image of could have had the rivets drilled out and put in another bus years ago. Chassi number stamped into the right side of the engine compartment is more likely to be correct, but even that could have been cut out and welded in. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Wed Nov 13, 2019 9:55 pm Post subject: Re: URGENT HELP - VIN 21 window |
I can't tell from those photos.
I can tell you that VIN # is a 1966 Deluxe VIN # but this doesn't tell me if it's an original 21-Window.
It could be a 13-Window with a roof clip added.
Or not an original Deluxe at all.
I've seen a "21-Window" before where they added the entire roof clip, including the unmodified VIN plate and everything.
Does it have belly pans underneath that look unmodified? _________________ How to Post Photos
