Fitting problems with seal under turn signal housing?
nize
nize is offline
PostPosted: Thu Nov 14, 2019 7:57 am    Post subject: Fitting problems with seal under turn signal housing? Reply with quote
Trying to finish of the work on the front of my 1957.
Any one else experiencing problems fitting the seal between body and the turn signal indicator housings?
I tried to save the original Hella seals as they seem to be fine but I cant get them to fit as they seem a bit too small. Is there any neat trick to get them in place without scratching the paint??
Could the seal have undergone shrinkage over the years??
----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
Braukuche
Braukuche is offline
PostPosted: Thu Nov 14, 2019 10:15 am    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
That's odd, I had the reverse problem on my 56 they seemed to large. I think mine were from WCM. Where are yours from?
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
nize
nize is offline
PostPosted: Thu Nov 14, 2019 12:11 pm    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
It’s the Hella marked original VW-seal. They were both in good condition so I tried to use them but they are to small to fit.
1954 Kombi
Braukuche
PostPosted: Thu Nov 14, 2019 12:22 pm    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
f
Oh, missed that bit.
Yeah, they shrink. Have you tried soaking them in hot water to make them more pliable and then install?
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Thu Nov 14, 2019 3:53 pm    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
Just a thought: you are using the original seals from your '57, but are you using the original turn signal housings? The housings changed sometime in 1964, so if you have later turn signals that might be a problem? Confused
djkeev
djkeev is offline
PostPosted: Thu Nov 14, 2019 4:51 pm    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
56-59
59-64
64-69
Three distinct lights, don't have chassis number breaks handy........ but I assume it is model year related?
Dave
Ghia
Vanagon
Beetle
aerosilver
aerosilver is offline
PostPosted: Thu Nov 14, 2019 11:25 pm    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
56-57 indicators are different from 58-63
56-57 same as oval/split bus,
58-63 as pictured
nize
nize is offline
PostPosted: Fri Nov 15, 2019 4:20 am    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
58-63 as pictured
I realise now that my 57 probably has a front fender repair some time in its life because I have got the 58-63 type turn signal with just a hole in the fender, just as the one in the pic above.
1954 Kombi
djkeev
djkeev is offline
PostPosted: Fri Nov 15, 2019 7:12 am    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
I've read that the earliest low light lights differed not much so much in design as in finish.
The earliest ones had painted bodies, the later lights (late 1950's) were chrome??
Dave
Ghia
Vanagon
Beetle
nize
nize is offline
PostPosted: Mon Nov 18, 2019 2:03 pm    Post subject: Re: Fitting problems with seal under turn signal housing? Reply with quote
Got some reproduction seals in the mail today. It proved my suspicion that the original seals had shrunken over the years. The repro seals had a perfect fit!
1954 Kombi
