r0adrun3r Samba Member
Joined: May 27, 2017 Posts: 17 Location: West Midlands
Posted: Thu Oct 24, 2019 7:54 am Post subject: 6 volt starter/ battery |
Ive recently brought a new 6 volt battery (S3 060 Bosch Car Battery 6V 66Ah Type 421 S3060). i tested the battery on my starter and the starter engaged but didnt spin. So i then brought a referb started off a 365(They are the same). Although when i test the new starter i get exactly the same. Ive tested the starter on a 12v battery and it seems to spin and engage. Does this mean i have a faulty battery ? what is a 6 volt battery meant to read ? |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Oct 24, 2019 3:38 pm Post subject: Re: 6 volt starter/ battery |
Are you testing the starters in the transmission? The shaft needs to be supported or it won't work as intended _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Thu Oct 24, 2019 3:53 pm Post subject: Re: 6 volt starter/ battery |
As above. The bushing in the bell housing supports the shaft.
Is the battery fully charged? 6V batteries are in low demand, my Interstate battery guy keeps a couple in stock and has told me to call the day before so they can make sure it is in tip top shape before I come get it. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
D-train Samba Member
Posted: Fri Oct 25, 2019 12:29 am Post subject: Re: 6 volt starter/ battery |
Is the cable big enough to carry the cca amps and power for 6v? Small cable won’t work.
Earth lead connected properly will help.
More info would be helpful also _________________ shiny paint doesnt make it worth any more |
Posted: Mon Oct 28, 2019 4:06 am Post subject: Re: 6 volt starter/ battery |
Cheers guys, I have a 4 Arm Engine Motor Stand Yoke with a fitting for the starter and have also tried to just bench test it in a vice. Both of these return the same result. Battery supplier are sending out a new battery tomorrow so ill try that. Is it vital to run these 6v in the bell house ? if that is the case then that may just be my issue. Sorry about the lack of info ill get some pictures of my setup tomorrow. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Sat Nov 16, 2019 1:49 pm Post subject: Re: 6 volt starter/ battery |
After changing all the bushings i had the same issue. Turns out the jumper cables i was using where too long. Thanks for the all help guys. |
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Sun Nov 17, 2019 4:54 pm Post subject: Re: 6 volt starter/ battery |
You have to LOVE 6 volts! |
