Ghia coming home
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
halbug
halbug is offline
PostPosted: Tue Nov 12, 2019 10:01 am    Post subject: Re: Ghia coming home Reply with quote
Thank you!
Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
Ian Godfrey
Ian Godfrey is offline
PostPosted: Tue Nov 12, 2019 3:43 pm    Post subject: Re: Ghia coming home Reply with quote
for a really good chrome finish I would suggest sanding the 'pits' out of the bronze as flux often is at the bottom of the pits and the first copper coat of the plating process won't cover the pits.
Sometimes the polishing people at the plating shop are not as thorough as I would like in the preparation Rolling Eyes
halbug
halbug is offline
PostPosted: Thu Nov 14, 2019 3:24 am    Post subject: Re: Ghia coming home Reply with quote
Thanks Ian, I will check for pits and will sand them out, or have the plater do it. I will for sure talk to him about it.
But now back to the pan. This is what I discovered last night: Totally misaligned d'oh!
Frustrating when someone does such a shitty job. Luckily I found this in my storage, but still more unexpected work.
I wonder why the first owner had to install a hand brake bracket in the first place. Doesn't the Thing have one like the bug???
KGCoupe
KGCoupe is offline
PostPosted: Thu Nov 14, 2019 11:48 am    Post subject: Re: Ghia coming home Reply with quote
I just did a Samba Gallery search for "hand brake" in the Thing/Type181 category, and there are half a dozen photos there - maybe one of them will help you.
halbug
halbug is offline
PostPosted: Thu Nov 14, 2019 11:40 pm    Post subject: Re: Ghia coming home Reply with quote
I checked them, but unfortunately they do not give me an answer. But Thanks for letting me know!
It seems as the replacement pan I am using had an awkward heater cable set up. The cable tube that sticks out of the tunnel in the front is (was) the original heater cable tube Shocked
The previous owner cut it at the hand brake position and modified all heater stuff in the tunnel to be like in a bug. Therefore he needed a handbrake bracket with provisions for the heater levers I suppose...
But question remains, how the heater boxes where operated in this Mexican Thing the pan was a replacement for Rolling Eyes
Cheers halbug
halbug
halbug is offline
PostPosted: Mon Nov 18, 2019 10:31 am    Post subject: Re: Ghia coming home Reply with quote
Handbrake done:
Still not sure what ratchet plate to use or how to change the ones I have to make the handle sit like on the photo. I will start looking for ratchet plates on swap meets for the first time in my live Laughing
djkeev Premium Member
djkeev is offline
PostPosted: Mon Nov 18, 2019 12:19 pm    Post subject: Re: Ghia coming home Reply with quote
Not sure about the Mexican Thing but apparently not all VWs were given heaters..
I understand From my reading that the Brazilian Ghia did not have a heater.?
But, Ive read things that turn out not to be true ........
Dave
Ghia
Vanagon
Beetle
halbug
halbug is offline
PostPosted: Mon Nov 18, 2019 11:25 pm    Post subject: Re: Ghia coming home Reply with quote
Hi Dave, very nice selection of Vdubs you have there!
My Ghia is from Germany, exported to Michigan and than brought back to Germany. BUT the pan I am using is a (altmost Wink ) NOS replacement Thing pan built in Mexico... Laughing
The heater cable tube ran from the back of the pan to this one point on top of the tunnel shown on above picture. Similar to old bugs, but does not end in a turning knob for adjustment...
I had not seen this before. I know that VW Mexico has been building some unique stuff. I just assume the heater cable exits the pan at this point and somehow ends in an extra mechanism, maybe attached to the body?
Either way I welded it up, as I am now using the mechanism on the hand brake bracket now Cool
Thanks
halbug
halbug
halbug is offline
PostPosted: Sat Nov 23, 2019 11:01 am    Post subject: Re: Ghia coming home Reply with quote
Making SEAT pods Cool
halbug
halbug is offline
PostPosted: Fri Dec 06, 2019 12:23 pm    Post subject: Re: Ghia coming home Reply with quote
Making progress - slowly Rolling Eyes
Seat attachments are done. The outer rear pod is lower. The alumuminum spacer will be machined to fit under the track. This will give me an even plane, once the pan is mounted to the body.
Complete assembly
Small stuff, but it all takes time Smile
In parallel I am working on a custom fuel catch tank, because the space under the tank is very limited with the Mendeola, transmission oil cooling plus ton's of other things...
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Dec 06, 2019 12:28 pm    Post subject: Re: Ghia coming home Reply with quote
Please fit the seats first, I found that you don't want an "even plane". When I mounted the seats (Miata) in my car, I found that the front of the seat needed to be at least 1.5" higher than the rear or I was only sitting on my tail bone which became uncomfortable quickly.
halbug
halbug is offline
PostPosted: Fri Dec 06, 2019 12:59 pm    Post subject: Re: Ghia coming home Reply with quote
Yup! That is the idea. First pan to body to make sure nothing moves anymore. Than seats to tracks, tracks to pan. The alu-spacer allows last adjustment...
So the idea Laughing Laughing
TRS63
TRS63 is offline
PostPosted: Thu Dec 19, 2019 2:52 am    Post subject: Re: Ghia coming home Reply with quote
As usual, every thing well thought and carefully made, can't wait to see the next update!
Antoine
Antoine
My 62 ragtop daily driver:
halbug
halbug is offline
PostPosted: Fri Jan 10, 2020 3:13 pm    Post subject: Re: Ghia coming home Reply with quote
I got so many things going on Laughing
First of all a happy New Year to all of you reading!
During the holydays I spent some more time on the aluminum cylinders...
I opened my Berg-5 transmission to modify some parts for improved oiling, as recommended by the Berg's.
TRS63
TRS63 is offline
PostPosted: Fri Jan 10, 2020 11:53 pm    Post subject: Re: Ghia coming home Reply with quote
Happy to see some progress here Very Happy
Happy new year too!
Antoine
Antoine
halbug
halbug is offline
PostPosted: Sat Jan 11, 2020 2:16 pm    Post subject: Re: Ghia coming home Reply with quote
Thank you!
I started a separate thread for the details of my transmission oiling and cooling...
https://www.thesamba.com/vw/forum/viewtopic.php?p=9251628#9251628
Just in case you are interested Wink
Clatter
Clatter is offline
PostPosted: Sun Jan 12, 2020 10:53 am    Post subject: Re: Ghia coming home Reply with quote
Wow.
Epic build.
Love the details. Thanks for taking the time to document it here.
Bus Motor Build
Fastback Build
What's That Noise??
Onceler
Onceler is offline
PostPosted: Sun Jan 12, 2020 5:57 pm    Post subject: Re: Ghia coming home Reply with quote
Cool! Im envisioning a modern version of Rodbuster with this build
1972 Karmann Ghia
halbug
halbug is offline
PostPosted: Mon Jan 13, 2020 12:41 pm    Post subject: Re: Ghia coming home Reply with quote
Laughing Laughing Laughing Laughing you will have to lower your expectations - a lot!
Mine will be fast, practical driver Cool
Cheers
halbug
halbug
halbug is offline
PostPosted: Mon Feb 03, 2020 8:19 am    Post subject: Re: Ghia coming home Reply with quote
Trail assembled the rear end. It's very busy back there, between the trailing arms...
I was searching spots to install all the parts for the transmission oiling/cooling as well for exhaust, rear brake calipers, heater tubes, the gas lines and the Kfer-Cup-Bar. I will have to address a lot of it again, when the body is fitted. Things are just too tight to guess. Either way, some brackets are already in the making.
The chassis went out to be professionally welded today Cool
as always... very slow progress Rolling Eyes
Page 6 of 7
