txasylum Samba Member
Joined: December 15, 2004 Posts: 389 Location: Boyers, PA
Posted: Fri Nov 22, 2019 5:16 am Post subject: Christine Lives! Carb/fuel problem resolved - now starter? |
Boy I tell you want. After messing around with this Super resolving my fuel pressure problem, and then my Empi 34Pict3 lean/jetting problem, I went for a nice drive last night. All is good!
But as Christine has a mind of her own, I wanted to hear the chirping of the motor before I left for work this morning, even considered driving Christine to work. So I get in the car, turn the key, and NOTHING. WTF? I have lights, I have electrical power, I hear the fuel cutoff solenoid click, but nothing from the starter. Christine is messing with me.
I know it has to be something simple - juice to starter solenoid to starter.
So, after work I will be under Christine (rubbing her belly) testing the solenoid.
When will this end? |
beetlenut Samba Member
Posted: Fri Nov 22, 2019 5:25 am Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
txasylum wrote: |
It won't! It's called a hobby! _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Fri Nov 22, 2019 6:11 am Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
I'm thinking it might be an easy fix. I put the back seat back in last night (I think it was after the drive). Maybe I knocked a wire off something, but anxious to get home and crawl under Christine to see if power is getting to solenoid.
beetlenut wrote: |
txasylum wrote: |
It won't! It's called a hobby! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Fri Nov 22, 2019 7:05 am Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
txasylum wrote: |
I'm thinking it might be an easy fix. I put the back seat back in last night (I think it was after the drive). Maybe I knocked a wire off something, but anxious to get home and crawl under Christine to see if power is getting to solenoid. |
Yep, you need to test, not guess. Under the seat is a good logical start before you climb underneath to test at small wire at the starter when helper turns the key to start; safer if in neutral with brake on !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
d2305 Samba Member
Joined: September 29, 2019 Posts: 63 Location: FLORIDA
Posted: Fri Nov 22, 2019 7:21 am Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
We have no immobilizers or chips in our keys. Shouldn't be hard to figure out. I found out a fully charged batter is 12.9 volts. Good place to start. |
reichfur Samba Member
Joined: September 17, 2007 Posts: 39 Location: Yakima , WA
Posted: Fri Nov 22, 2019 10:57 am Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
Had the same problem a week ago . Looked at all the connections before remembering to knock on the starter with a mallet . Problem solved . _________________ 1970 Standard Beetle . |
Posted: Fri Nov 22, 2019 3:43 pm Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
Easiest fix ever. Wire came off solenoid.
Cusser wrote: |
txasylum wrote: |
Yep, you need to test, not guess. Under the seat is a good logical start before you climb underneath to test at small wire at the starter when helper turns the key to start; safer if in neutral with brake on !!! |
Cusser Samba Member
Posted: Fri Nov 22, 2019 4:23 pm Post subject: Re: Christine Lives! Carb/fuel problem resolved - now starter? |
txasylum wrote: |
Cusser wrote: |
txasylum wrote: |
I've had that happen too, while doing a clutch adjustment. Be sure that the female connector onto the solenoid male terminal is tight, squeeze the ends a tad tighter. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
