VOLTWAGEN Samba Member
Joined: May 24, 2014 Posts: 118 Location: Perth, Australia
Posted: Sun Oct 27, 2019 6:47 pm Post subject: Re: Off road modifications for your bus FAQ |
dastransporter wrote: |
that looks amazing. you aren't in the states so im not sure I can find those exact same wheels, but if I could - id totally copy you. I don't have any decent caps and my stock wheels are pitted and ugly.
Time to hit the yards for Merc's running 15's. |
PM sent re where I got them from, you might be able to get them shipped to the US easy enough?, they cme from Germany to Australia for me. |
Posted: Sun Oct 27, 2019 7:07 pm Post subject: Re: Off road modifications for your bus FAQ |
Have put a freshly built 2L type 4 engine in with a 6 rib bellhousing/flywheel/clutch on a 5 rib box, all seems good, when sitting at 60kmph in 4th i'm at 2000rpm, still bedding in the new engine, will get higher speeds later.
I also updated the front seats with covers from Sewfine, got some spare plaid fabric to do the new bed when I get that sorted
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Sat Nov 30, 2019 1:56 pm Post subject: Re: Off road modifications for your bus FAQ |
Does anybody know of published specs for a stock bus approach and departure angles?
Anybody measured their own?
Thanks,
www.airschooled.com |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Sat Nov 30, 2019 5:38 pm Post subject: Re: Off road modifications for your bus FAQ |
asiab3 wrote: |
Thanks,
Robbie |
The Syncro prototype with 16” wheels, muffler and from bumper raised 3” has 22.5 departure, 30.5 approach. I could measure mine tomorrow if interested in late bay #s _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Sat Nov 30, 2019 6:14 pm Post subject: Re: Off road modifications for your bus FAQ |
ImAddicted wrote: |
asiab3 wrote: |
Thanks,
Robbie |
The Syncro prototype with 16” wheels, muffler and from bumper raised 3” has 22.5 departure, 30.5 approach. I could measure mine tomorrow if interested in late bay #s |
Yes please, if you don’t mind!
Posted: Sun Dec 01, 2019 1:26 pm Post subject: Re: Off road modifications for your bus FAQ |
Ok, did this twice with two different buses
1979 7 passenger with header, glass pak, 27” ATs, my front seats are 35# heavier than stock, each, plus my winch is another 45#, stuck 50# of rock salt up front to simulate 165# driver. Approach 27 (tow hooks and bumper hit at same time) departure 21.5 Measured with laser level, corrected for ground slope.
1979 7 passenger 49-state original-style exhaust, 25” (stock profile) tires, stock interior, 50# rock salt, 105# girlfriend +10# iron weight. Approach 25 (tow hook), depart 19.5 exhaust. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Abscate Samba Member
Joined: October 05, 2014 Posts: 22566 Location: NYC/Upstate/ROW
Posted: Sun Dec 01, 2019 6:55 pm Post subject: Re: Off road modifications for your bus FAQ |
It’s the maximum angle you can approach/ depart from flatland, units are degrees _________________ .ssS! |
Posted: Sun Dec 01, 2019 7:06 pm Post subject: Re: Off road modifications for your bus FAQ |
Like this, Jason.
KC1MUR
strfish7 wrote: |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sun Dec 01, 2019 7:17 pm Post subject: Re: Off road modifications for your bus FAQ |
VOLTWAGEN wrote: |
The new shoes are on
They fitted perfectly, I only had to remove 2 bolts from the rear drums, which I believe hold the cover on before the wheel nuts are tightened
Looks good. I think the large, black, Brazilian mirrors would really set it off. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Tue Dec 03, 2019 5:09 pm Post subject: Re: Off road modifications for your bus FAQ |
ivwshane wrote: |
VOLTWAGEN wrote: |
Looks good. I think the large, black, Brazilian mirrors would really set it off. |
Funnily enough, I've just been thinking the same, i've been looking at getting a set, only thing is they are made for LHD and i've got a RHD, will be looking into the design of them so see if I can make them work, even if I need to take them apart |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2921 Location: San Diego, CA
Posted: Wed Dec 04, 2019 12:22 pm Post subject: Re: Off road modifications for your bus FAQ |
Sharp looking bus. Those black framed windows look tough! |
Posted: Wed Dec 04, 2019 5:08 pm Post subject: Re: Off road modifications for your bus FAQ |
Anchovy wrote: |
They are, it was originally a panel van that was cut for windows, I felt it needed some proper support so the frames are pretty sturdy, sikaflexed on and screwed into wooden 1x1 battens behind.
The mesh is metal security mesh as well so I can leave the slider windows open when I leave the van and it doesn't turn into an oven, it's good for overnighting in the van as well. |
pau79 Samba Member
Joined: February 21, 2016 Posts: 3 Location: barcelona
Posted: Fri Dec 20, 2019 5:00 pm Post subject: Re: Off road modifications for your bus FAQ |
HastaAlaska wrote: |
Don't you worry those 16s are going to be too big?
I fitted New 15" Steel wheels to my bus (mainly for better tire selection) I'm not sure I'd want to go much bigger than this after hearing some reports of people's wheels binding in the wheel well when on rough roads.
Campervan Culture bought up all the remaining MEFRO wheels (ET30) as they are NLA, supply is limited . https://campervanculture.com/shop/15-mefro-steel-wheels-set-of-5/
They bolt right onto the bus and the clearance looks good The tire is 205 / 70. Michelin Latitude Cross. not as beefy as the other ATs but better fuel economy and much better grip in the wet. |
Hello, how do you drive the van with that measure? Does it keep enough space with the body? I have a set of mefro for my stock westy, and I have doubts about installing this measure or going a little bigger 215 / 75r15, regards |
BIGSERG Samba Member
Posted: Sat Dec 28, 2019 11:45 pm Post subject: Re: Off road modifications for your bus FAQ |
went with the Empi 911 15 inch wheels and 215/75R15 Ko2 all terrains.
im running Fox shocks too . so far its great , no rubbing during normal driving conditions. rubs when fully locked on turns but ill adjust the steering stop and deal with the turning radius . ride is way better then 195 size tires. in the back i got about an inch of gap between fender wall and tire.
Posted: Sun Dec 29, 2019 5:49 pm Post subject: Re: Off road modifications for your bus FAQ |
BIGSERG wrote: |
Nice choice of tyres |
simon_london Samba Member
Posted: Thu Jan 09, 2020 3:16 am Post subject: Re: Off road modifications for your bus FAQ |
Great thread! |
Posted: Thu Jan 09, 2020 9:29 am Post subject: Re: Off road modifications for your bus FAQ |
ImAddicted wrote: |
1979 7 passenger 49-state original-style exhaust, 25” (stock profile) tires, stock interior, 50# rock salt, 105# girlfriend +10# iron weight. Approach 25 (tow hook), depart 19.5 exhaust. |
Thank you so much! Don’t know how I missed this before. I appreciate the measurements!
Tom Clarke Samba Member
Posted: Tue Jan 14, 2020 4:41 pm Post subject: Re: Off road modifications for your bus FAQ |
Hey guys,
Finally got round to doing what I’ve been meaning to do since owning my bus and fit some AT tyres. Went with the 27/3.50r14 maxxis big horns as they looked great on photos and were a reasonable price. Turned out really nice and has given my bus a lot more attitude. No lift kit, just a low mileage stock ride height van that I’ve built a tin top westy interior for.
