67 wiper disassembley
Humanure
Humanure is offline
PostPosted: Tue Nov 11, 2008 8:29 am    Post subject: 67 wiper disassembley Reply with quote
From the picture below, can the plastic gear inside the housing be removed without major effort? I want to remove any old grease the may be underneath, but I can't do a nice job with it installed. Do I need to remove the pivot arm that is underneath on which it is attached to? Or should I just leave it be, blast it with brake cleaner and then repack?
It is difficult to free fools from the chains they revere.
Clara Premium Member
Clara is offline
PostPosted: Tue Nov 11, 2008 9:36 am    Post subject: Reply with quote
You have to wiggle the arm off, then the wiper gear slides out.
BEFORE wiggling the arm off, make sure you know which way exactly on the splines it is installed, as that determines where the wipers park, and og they park on the right. Perhaps a dab of nail polish so you can line it up later?
You don't want them to park in the middle. Confused
I have re-installed the splined arm by trial and error to fix the parking location. It is easier to do before installation in the bus.
Also make sure you don't lose the little cone piece of metal that the adjustment for the wiper motors sets on, or the wipers will be louder. It gets lost in the old grease.
xavi_242
xavi_242 is offline
PostPosted: Tue Nov 11, 2008 9:44 am    Post subject: Reply with quote
ouch!
mine park in the left (looking from inside..)
1967 Split SO-42 Dormobile
Ollie W
Ollie W is offline
PostPosted: Tue Nov 11, 2008 9:57 am    Post subject: Reply with quote
Parking wiper blades...must be nice.
Humanure
Humanure is offline
PostPosted: Tue Nov 11, 2008 11:53 am    Post subject: Reply with quote
Whew, I'm glad you said that. From an earlier search before I posted this thread, somebody (I think it was you) else mentioned that cone piece. I went back and looked on the napkin where I smeared the removed grease and on the floor where I disassembled the wiper assembly, no luck. I then took a peek into where the plastic gear is and noticed a blob of grease and found it there. I posted some photos for future reference. I'm guessing that cone piece is placed on the end of the armature shaft. Is that correct? Thanks for the help!
Clara is offline
PostPosted: Tue Nov 11, 2008 12:26 pm    Post subject: Reply with quote
Ya, that's it. you fit it in the housing before sliding the armature in.
The armature slops around w/o it and so the motor is noisier.
Guess how I know? Embarassed Laughing
Culito
11010101
Culito is offline
PostPosted: Tue Nov 11, 2008 5:14 pm    Post subject: Reply with quote
X2.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
iamdonquixote
iamdonquixote is offline
PostPosted: Sat Nov 30, 2019 2:17 pm    Post subject: Reply with quote
can't you just reindex the wiper arms on the wiper shafts to do this?
Clara is offline
PostPosted: Sun Dec 01, 2019 2:38 pm    Post subject: Reply with quote
try it and let us know how that works for you.
iamdonquixote
PostPosted: Sun Dec 01, 2019 6:40 pm    Post subject: Reply with quote
i can't tell if thats sarcasm.
coolerthanelvis
coolerthanelvis is offline
PostPosted: Sun Dec 01, 2019 8:46 pm    Post subject: Reply with quote
Yes. Yes it is. Moving just the wipers would change the arc of sweep.
Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob
iamdonquixote
PostPosted: Tue Dec 03, 2019 9:26 am    Post subject: Re: 67 wiper disassembley Reply with quote
I found this thread looking for wiper info. I too removed the mechanism from the motor without marking it.
I cleaned out old grease and reassembled motor. Motor works well at high and low and then I switch to self parking pin 54d to let the motor park. I am going to check the position of the assembly on my other 67' and attempt to line up the splines in the same way.
