Setting up rebuild automatic transmission for first time
Ejspada
Ejspada is offline
PostPosted: Thu Dec 12, 2019 2:55 pm    Post subject: Setting up rebuild automatic transmission for first time Reply with quote
anything I should do upon installing my rebuild transmission for fist time. I have filled trans and differential with respective oils. Do I need to re learn the TCM ? reset it ?
jjvincent
jjvincent is offline
PostPosted: Thu Dec 12, 2019 4:08 pm    Post subject: Re: Setting up rebuild automatic transmission for first time Reply with quote
Just install the trans and go with it.
mvaska
mvaska is offline
PostPosted: Thu Dec 12, 2019 4:36 pm    Post subject: Re: Setting up rebuild automatic transmission for first time Reply with quote
if you did it yourself and didn't completely tear down/clean the case, ensure all the metal shavings/gunk from the previous failure are flushed out before driving!
