Ejspada Samba Member
Joined: April 27, 2018 Posts: 74 Location: South Carolina
Posted: Sun Dec 15, 2019 6:41 pm Post subject: 1995 Eurovan: No reverse, no neutral, can't even roll |
I have a 95 Eurovan just rebuilt - put in my eurovan and no reverse and no nuetral. Its not the back brakes as can jack up the front end and push back. Forward gears work - I can uplug the TCM and still no reverse - also no nuetral even though it says its in nuetral - any ideas ?
I am pissed as this is a totally new set up bascially |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Mon Dec 16, 2019 5:27 pm Post subject: Re: No Reverse No Nuetral cant roll even 1995 Eurovan |
You have an internal issue. At this point, it would be spitballing as to why. |
Zeitgeist 13 Samba Member
Posted: Mon Dec 16, 2019 6:30 pm Post subject: Re: No Reverse No Nuetral cant roll even 1995 Eurovan |
Is the shifter cable properly clipped? I had a similar issue shortly after I reinstalled my trans. The clip holding the cable onto the trans had fallen off--my bad _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Mon Dec 16, 2019 7:48 pm Post subject: Re: No Reverse No Nuetral cant roll even 1995 Eurovan |
Zeitgeist 13 wrote: |
Is the shifter cable properly clipped? I had a similar issue shortly after I reinstalled my trans. The clip holding the cable onto the trans had fallen off--my bad |
Or, is the manual valve on the valve-body properly adjusted? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Tue Dec 17, 2019 4:03 am Post subject: Re: No Reverse No Nuetral cant roll even 1995 Eurovan |
So i did re adjust and make sure the shifter cable was installed correctly.
Ive heard the tab on reverse breaks off easy - if thats the case would I still not have nuetral ? The point that the in nuetral the vehicle will roll forward but not backward and the same in reverse is what has me stumped. Again nothing to do with the brakes. |
Posted: Wed Dec 18, 2019 8:56 am Post subject: Re: No Reverse No Nuetral cant roll even 1995 Eurovan |
If you've readjusted the manual valve on the valve-body, then either the valve body or transmission has an internal issue...perhaps one or the other was not rebuilt properly.
For the sake of asking, have you driven it at all in the forward speeds, either manually shifting it or automatically shifting it? _________________
66brm wrote: |
Bodacious wrote: |
Posted: Wed Dec 18, 2019 3:10 pm Post subject: Re: No Reverse No Nuetral cant roll even 1995 Eurovan |
I have driven it about 30 feet - barely. So off its going back to the transmission shop for them to check it. The odd thing to me is the nuetral not allowing it to move backward. it can roll forward but I cannot roll it or reverse it backward. A In hopes of not breaking anything I did not drive it at all basically |
