SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Mon Dec 16, 2019 10:48 am Post subject: Fuel leak from charcoal canister? |
My van has been sitting for a couple months and I decided to take it out for spin yesterday. When I got back home I smelled gas and noticed a fairly large gas stain on the garage floor.
I didn't have much time to investigate but I saw no signs of leaks from my fuel lines. I did notice the plastic elbow on the bottom of the charcoal canister was wet and there was a stain on the top of my rear swing arm below the canister.
I didn't think liquid gasoline made it to the charcoal canister but maybe I don't understand how that works. Is there any chance my leak is from the canister rather than the fuel lines? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Mon Dec 16, 2019 11:22 am Post subject: Re: Fuel leak from charcoal canister? |
SCM wrote: |
I didn't think liquid gasoline made it to the charcoal canister but maybe I don't understand how that works. Is there any chance my leak is from the canister rather than the fuel lines? |
just a guess but gas vapors condensed and built up enough to drip? _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17118 Location: Retired South Florida
Posted: Mon Dec 16, 2019 11:48 am Post subject: Re: Fuel leak from charcoal canister? |
Do you neck fill the fuel tank when filling up? _________________ ☮️ |
SCM Samba Member
Posted: Mon Dec 16, 2019 2:05 pm Post subject: Re: Fuel leak from charcoal canister? |
MarkWard wrote: |
Do you neck fill the fuel tank when filling up? |
Nope. Once the pump clicks itself off I stop fueling. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
SCM Samba Member
Posted: Thu Dec 19, 2019 4:39 pm Post subject: Re: Fuel leak from charcoal canister? |
I’m really puzzled. I gave a real good look at all the fuel line and evap system connections after cycling the pump/relay and while idling the van for about 10 minutes. No leaks whatsoever. I just hat intermittent problems but I guess all I can do is keep an eye on things. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Thu Dec 19, 2019 5:26 pm Post subject: Re: Fuel leak from charcoal canister? |
The charcoal canister should collect hydrocarbons and purge going down the road. It may not be purging or has become saturated. The only way I recall is to weigh it against a new one. Don’t like to mess with fuel smells or leaks. _________________ ☮️ |
bluebus86 Banned
Posted: Thu Dec 19, 2019 5:53 pm Post subject: Re: Fuel leak from charcoal canister? |
some vans had a purge hose to the aircleaner, other did not come with that. on mine the vent on the cannister got clogged with a spider nest, but that prevented full filling of the gas tank, ie, it would not vent. i removed the nest and all was well, then I installed a screen over the vent to keep the spiders out.
conceivable that driving or parking on a steep slope could drain fuel into the canister I suppose.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
