Front negative camber
Albertoprop17
Albertoprop17 is offline
PostPosted: Mon Dec 09, 2019 4:18 am    Post subject: Front negative camber Reply with quote
Hi everyone, I was wondering how to have negative camber in front of a link pin car, so I've seen that FV's and 356's used to have offset link pin bushings to achieve that.
Do you guys know were can I purchase a set of those offset bushings? I really would like to have negative camber on my 54, it will be nicer on the corners
Thanks
'54 vintage speed beetle slow project
Visit my workshop site and leave a like:
https://www.facebook.com/talleresalacreu/
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Mon Dec 09, 2019 6:30 am    Post subject: Re: Front negative camber Reply with quote
When we were circle tracking a Ghia we had a local machine shop make some for the car.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
slalombuggy
slalombuggy is offline
PostPosted: Mon Dec 09, 2019 6:58 am    Post subject: Re: Front negative camber Reply with quote
I got mine from Lybarger but he retired and has since passes. The FV shop that built my transaxle gets them made. Vallis Motorsports in Welland, Ontario, Canada. 905-384-0016 I have them on the front of my buggy, huge improvement.
brad
Albertoprop17
PostPosted: Mon Dec 09, 2019 9:46 am    Post subject: Re: Front negative camber Reply with quote
brad
Thanks, I will send them an email and see if they can ship them to Spain, where I'm from
How much negative camber does your front wheels have now guys?
slalombuggy
PostPosted: Mon Dec 09, 2019 11:29 am    Post subject: Re: Front negative camber Reply with quote
I got -2.5* offset bushings and I now have -1* camber.
One thing you will have to watch is, now that the front will turn in better, you may find the back will want to come around easier and send you for a loop. The positive camber was built into the front ends so that the front would understeer and the car would plow through a corner rather than the tail heavy car go into a spin.
Call Bill instead of emailing him, he is usually very busy, he prepares and maintains a lot of cars.
brad
petrol punk
petrol punk is offline
PostPosted: Mon Dec 09, 2019 1:58 pm    Post subject: Re: Front negative camber Reply with quote
If you don't mind mounting heim joints in bending (An engineering no-no) this is the easiest way. 18mm heims and a big ol 18mm bolt.
36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma
Albertoprop17
PostPosted: Tue Dec 10, 2019 2:47 am    Post subject: Re: Front negative camber Reply with quote
That was my first idea, but I heard that the link pin suspension needs a radius between the links for strength. That system is perfect for adjustability, but the shaft starts to flex and deform because of the lack of the radius reinforcement.
Although, I would like to fabricate this setup in the future. The only thing that concerns me is the attachment to the heim joint threads with the trailing arm, I don't know how to do it.
And the offset bushings will be a lot cheaper too Very Happy
TomSimon
TomSimon is offline
PostPosted: Tue Dec 10, 2019 5:59 am    Post subject: Re: Front negative camber Reply with quote
that's pretty cool!
2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer
JeeWee
JeeWee is offline
PostPosted: Sun Dec 22, 2019 11:57 am    Post subject: Re: Front negative camber Reply with quote
I do run this heim joint setup as well, but the travel of the heim joints is not enough, at least I could not get it setup correctly. It hits the ends when you drive it hard on a bumpy road. also steering is not perfect, it gets heavy because the heim joints are not made for it. My set is for sale if you would like to give it a try. Made of the chromobilydeen steel.
although I have to say it is such a big improvement, I never have been so quick thru a corner in a '57 swingaxle beetle
I do run a ARB 19mm in the front and 16mm in the rear! NICE! Spax adjustable all round and vredestein sprint classic 155R15 front and 165R15 rear
1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm
Albertoprop17
PostPosted: Sun Dec 22, 2019 12:03 pm    Post subject: Re: Front negative camber Reply with quote
I'll send you a PM for more details, it may suit my needs
petrol punk
PostPosted: Sun Dec 22, 2019 10:52 pm    Post subject: Re: Front negative camber Reply with quote
I had wondered about that, when you look up the misalignment angle of a typical heim joint and figure you have a 6" swing on the trailing arms, it adds up to less than 4" of wheel travel which is definitely less than stock. There are off the shelf high-misalignment heims out there that would support over 6" of suspension travel, but as far as I can tell they're in inch size, so you have to go machine it out to 3/4" or neck down to 5/8".
JeeWee
JeeWee is offline
PostPosted: Mon Dec 23, 2019 1:01 am    Post subject: Re: Front negative camber Reply with quote
cool, that would help me out in this setup! The adjustment is amazing! I do run HD heim joints which is motorsport quality, ordered in the Netherlands:
https://www.chassisparts.com/nl-nl/stangkoplager-h...count%3d20
Do you have any URL with the 6"+ travel? I'll have that machined then
1192CC WW okrasa
petrol punk
PostPosted: Mon Dec 23, 2019 1:32 am    Post subject: Re: Front negative camber Reply with quote
Here's a McMaster link to a 3/4" version. They have different sizes on their website. I actually have some 5/8" ones I was going to use for long travel truck tie rods to give you an idea. No branding on them so I'm not sure who actually manufactures them.
https://www.mcmaster.com/6960t5-6960T51
