desert westy Samba Member
Joined: October 01, 2011 Posts: 103 Location: Twentynine Palms, Ca
Posted: Tue Oct 15, 2019 1:54 pm Post subject: case ID |
Can anyone tell me if case #w0014515 is from a Porsche? If it is, what size motor is it and what model/year Porsche would it have come from? Thanks. |
raygreenwood Samba Member
Posted: Wed Oct 16, 2019 1:34 am Post subject: Re: case ID |
desert westy wrote: |
It could be from a 914 or a VW 411.
The VW 411 used the W case from the tail end of the Z series in 1969. It would have been a 1.7L engine.
Ray |
Joined: December 28, 2016 Posts: 280 Location: atlanta ga
Posted: Wed Oct 16, 2019 7:57 am Post subject: Re: case ID |
certainly a 1700 cc engine |
Posted: Wed Oct 16, 2019 4:22 pm Post subject: Re: case ID |
Are these motors worth screwing with? I bought this case with rebuilt crank, rods, heads, etc... about 15 years ago. Also came with a set of Weber 44 IDFs. Plan was to build the motor and put it a VW, not a Porsche. Is it worth the time, money and effort? |
Posted: Thu Oct 17, 2019 8:12 am Post subject: Re: case ID |
Probably should buy the factory 2.0 version with factory fuel injection Far superior. 44s are too much carb for these engines unless heavily modifed for racing
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Thu Oct 17, 2019 2:58 pm Post subject: Re: case ID |
It doesn't have to stay a 1.7L. Big bore kits are readily available - easily upgraded to 96mm-104mm for larger capacity. Unbreakable bottom end on the T4 engines. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Mon Dec 23, 2019 11:52 am Post subject: Re: case ID |
The 1.7 case is a bit beefier and will need some clearancing to handle a 96mm jugs. and even more to handle a 71mm crank. But it will still be the preferred case to make a 2056cc or a 1911cc. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
