Ian Samba Moderator
Posted: Wed Dec 25, 2019 11:30 am Post subject: Porsche Engine Case Line Bore |
Does anyone here mess with 911 engines??
Do I need to skim the case halves before opening the bores back up???
Any old timers that used to do this stuff??
This thread had some pretty good info, and the guy has way more tools than I do.
https://www.practicalmachinist.com/vb/deckel-maho-...kSrqANIMH0 _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Wed Dec 25, 2019 3:12 pm Post subject: Re: Porsche Engine Case Line Bore |
fat performance-rimco offers that service.you can ask them.
714-637-2889 fat performance rimco.com
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
slalombuggy Samba Member
Posted: Wed Dec 25, 2019 3:57 pm Post subject: Re: Porsche Engine Case Line Bore |
The 911 engines I built just had the tunnel bored out, the cases werent shaved. I dont think you can because of the way some of the things like the oil pump go into the case.
brad |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Ian Samba Moderator
Posted: Wed Dec 25, 2019 8:23 pm Post subject: Re: Porsche Engine Case Line Bore |
slalombuggy wrote: |
brad |
From my understanding, they skim the case halves and then line bore it and then open up all the other holes. Everything remains "standard" in size when the case is skimmed. _________________ All your Buses are belong to us.
Ian Samba Moderator
Posted: Wed Dec 25, 2019 8:34 pm Post subject: Re: Porsche Engine Case Line Bore |
https://www.thesamba.com/vw/classifieds/detail.php?id=2332800
Quote: |
seam sanded and line-bored back to standard, |
Ian Samba Moderator
Posted: Wed Dec 25, 2019 8:36 pm Post subject: Re: Porsche Engine Case Line Bore |
I'm done mailing engine parts out to get machine work done to them. I will talk about that later, but I simply won't do it anymore. Whether it's the machine shops or the shipping companies, I just can't afford to have more parts show up broken, especially P car parts.
So, I am trying to figure out what I need to do. _________________ All your Buses are belong to us.
Ian Samba Moderator
Posted: Wed Dec 25, 2019 9:12 pm Post subject: Re: Porsche Engine Case Line Bore |
sgmalt46 wrote: |
Steve |
RIMCO/Fat Performance is a joke. I won't deal with them ever again. _________________ All your Buses are belong to us.
rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Thu Dec 26, 2019 7:03 am Post subject: Re: Porsche Engine Case Line Bore |
Yes you will most likely have to skim the case halves and line bore back to standard because complete sets of oversize shells are very hard to find and big $$. The Glyco aftermarket standards are hit and miss also. Check with Stoddard to see if they can get any oversize and be sitting down. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1505 Location: Buford GA
Posted: Thu Dec 26, 2019 7:25 am Post subject: Re: Porsche Engine Case Line Bore |
Ian wrote: |
sgmalt46 wrote: |
Steve |
RIMCO/Fat Performance is a joke. I won't deal with them ever again. |
I watched a youtube vid of them drilling for case savers and was astounded to see that they didn't bolt the case to the table. It was just rattling around as the drill bit went in.
https://fatperformance-rimco.com/collections/machine-shop-services |
mark tucker Samba Member
Posted: Thu Dec 26, 2019 12:53 pm Post subject: Re: Porsche Engine Case Line Bore |
Ian wrote: |
sgmalt46 wrote: |
Steve |
I totaly agree. ripoff. |
Posted: Thu Dec 26, 2019 1:05 pm Post subject: Re: Porsche Engine Case Line Bore |
rodeking wrote: |
To be honest, if the price of the bearings is going to make you faint, then the 911 engines isn't the car or engine for you. The last engine I did went out the door for $14K and that was before Porsche prices went through the roof. |
Posted: Thu Dec 26, 2019 5:40 pm Post subject: Re: Porsche Engine Case Line Bore |
I own a '79 930 and an '88 930 slant, haven't fainted yet, a lot of grimaces though when putting together part lists.
The problem is the oversize mains. I just looked at Stoddard and they have .25 over /.50 under mains 2-7 at 77+ per half so there's $930 for twelve halves. Then the #1 thrust .25 over is 70 each half and the #8 nose is 130-200 depending on year and size. So there's 1200 plus for the mains only not including align bore cost. (400 at Ollies for 1st over).
Ollies charges 850-875 to cut the cases and bore to standard plus the std OD bearings (100-300 depending on std/std or std/under) so pick your poison.
Don't know if the OP has a mag or aly case. If it's a 2.7 mag it's not unusual to have to put several thou in it for machining if you pay someone to do it. |
