Vanagon914 Samba Member
Posted: Thu Dec 26, 2019 3:28 pm Post subject: Re: Scooby-gets-a-suby |
Ready to be connected |
Posted: Sat Dec 28, 2019 1:01 pm Post subject: Re: Scooby-gets-a-suby |
Rice meets sauerkraut
Posted: Sun Dec 29, 2019 11:10 am Post subject: Re: Scooby-gets-a-suby |
Removed the old nasty cv axles
In with the new
Posted: Sun Dec 29, 2019 11:11 am Post subject: Re: Scooby-gets-a-suby |
Removed the old mounts..........dont think I will ever need to buy washers again ha wtf
Posted: Sun Dec 29, 2019 12:36 pm Post subject: Re: Scooby-gets-a-suby |
mock up of the engine carrier before I put the engine in
Posted: Sun Dec 29, 2019 2:46 pm Post subject: Re: Scooby-gets-a-suby |
Mounts drilled |
Posted: Mon Dec 30, 2019 12:03 pm Post subject: Re: Scooby-gets-a-suby |
Installation
Time for a beer
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Mar 01, 2020 3:05 pm Post subject: Re: Scooby-gets-a-suby |
So it has been a while since I last posted,here is why.......
So the PO installed an ac unit up front and that is not going to work with a radiator sooooooo....I went to remove it....
First off the jack was welded on to the front hitch so I had to cut it off just to remove the bumper........then
He welded a nipple on after installing the ac and welded it 3/4 around essentially blocking the unit from coming off.........then |
Posted: Sun Mar 01, 2020 3:13 pm Post subject: Re: Scooby-gets-a-suby |
Rot.... there was no barrier inbetween the ac and the metal underneath so all the condensation rusted it away........
This is a safety issue and I cant pass it up and continue with the engine swap. So I cut out the rot and spent the next few weekends trying to teach myself to weld....
It came out decent but more importantly the metal is solid so now I can continue |
Posted: Sun Mar 01, 2020 3:16 pm Post subject: Re: Scooby-gets-a-suby |
The gas tank I pulled out had rust in the bottom and new ones are cheap so I got a new tank and put all new seals in
The filler neck was also rusted so I put it in an ultrasonic bath. All the rust is gone and threw some paint on it
Also I got new wheels
Posted: Sun Mar 08, 2020 1:04 pm Post subject: Re: Scooby-gets-a-suby |
Stock forester fuel filter mounted along with my coolant reservoir
dustibus Samba Member
Joined: March 10, 2010 Posts: 72 Location: cincinnati
Posted: Mon Mar 09, 2020 8:37 pm Post subject: Re: Scooby-gets-a-suby |
This is looking sweet!!!🤙 Love the rocky mtn suby kit too🎉 |
Posted: Wed Mar 11, 2020 4:43 pm Post subject: Re: Scooby-gets-a-suby |
Little progress while I wait on parts.
Back to the original fuel pump and a generic inlet filter.
Routed return line
Posted: Wed Mar 11, 2020 4:45 pm Post subject: Re: Scooby-gets-a-suby |
Yokohama Geolander 215/65r16
Posted: Sat Mar 14, 2020 2:39 pm Post subject: Re: Scooby-gets-a-suby |
Mounted fuel pump
Posted: Sat Mar 14, 2020 2:40 pm Post subject: Re: Scooby-gets-a-suby |
Ran a new throttle cable
Posted: Sat Mar 14, 2020 2:43 pm Post subject: Re: Scooby-gets-a-suby |
Inner cv joined along with the VSS ring
Along with a new slave cylinder
