swiss_bulli Samba Member
Joined: February 17, 2017 Posts: 123 Location: Switzerland
Posted: Mon Dec 30, 2019 1:54 pm Post subject: Peen king pin end cap into place |
I‘m looking for any tips and tricks to get the end cap in place. The bentley just say peen it into place. As the cap is at least 1 mm bigger than the hole, I got some issues. As I didn‘t find infos, it can‘t be that hard. My hammer method didn‘t work out...
_________________ Recent pics from my SO-42 rebuild: https://www.instagram.com/anni_vintage_bus/ |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Mon Dec 30, 2019 11:33 pm Post subject: Re: Peen king pin end cap into place |
Can you reused your originals?
If you want to use the aftermarket one you have you can probably center it over a ~1” hole and hit the center with a ~1/2” drift to balloon out the middle which will draw in the edges. 1mm isn’t a whole lot to take up. When you hammer it back into place it will flatten out. |
Posted: Tue Dec 31, 2019 12:12 am Post subject: Re: Peen king pin end cap into place |
I tried it with the original first, but hammered one to death with the same issue. So I ordered new caps, because I thought they will be an easy fit - no luck .
I thought, maybe I need to drive it in from the other side (before putting in the bushing), but been worried that I scratch the surface when pressing it through. Will need to try out your idea campingbox, if I can make it deeper with a less diameter. _________________ Recent pics from my SO-42 rebuild: https://www.instagram.com/anni_vintage_bus/ |
