Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Tue Dec 26, 2017 10:20 am Post subject: Re: 40 hp evolution |
Owners manuals pictures are generally an unreliable reference. They reused and retouched photos all the time. My observations are that they are usually correct about what is being referred to. Other things in the photo might be much earlier, and they may have had to retouch the thing which they are referring to.
Owners manual photos can be useful for telling that something certainly existed by a certain time, but they can't prove a negative.
62DoKaGuy wrote: |
If anyone finds anything more definitive on the round-to-ribbed generator stand transition, like PR references or other sources, I would appreciate it to add to my resources.
If you look the manuals, which, of course, are not always the most accurate resources, the non-ribbed or round generator stand was still shown in the February as well as October '62 manuals, while the February '63 shows the ribbed version among others changes, like fresh air, etc:
Feb '62:
https://www.thesamba.com/vw/archives/manuals/mighetto/62t2_p66p67.jpg
Oct' '62:
https://www.thesamba.com/vw/archives/manuals/oct62bus/page66.jpg
Feb '63: https://www.thesamba.com/vw/archives/manuals/feb63bus/page66.jpg
Adding more confusion and contradiction, I have a very original engine, an April '62 (#6723517, I believe) that had the round generator stand. So, where do we draw the line? Stands are interchangeable and could have been replaced on mine with an available round one, or the March '62 described above could have replaced a broken round type.
Like you guys, I just want a straight answer, something black and white, saying "at this time or engine #, VW started its transition, while using existing resources [of round bubbas] until depleted." Given nothing concrete, I tend to rely on the manuals or whatever is available. If anyone finds anything out like a PR reference or bulletin or what, post it! Cheers, guys.
EDIT: Another note on the Manuals' (in)accuracies: even the images in the Oct '62 still show the breather hose running from oil cleaner intake (earlier), rather than the reservoir (later), which transition in late February '62 according to PR. Ahh, I need clarity and ritalin! |
My 10/62 parts list page shows 113 101 211 for the generator stand. That would suggest that there had not been any modifications to the part by that time.
The picture of the 1/63 engine shows the later stand.
Does anyone have other data points in the mid -'62 through 1/63 era? Parts list pages dated after 10/62 into early 1963 would be helpful. _________________ .
Wanted:
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Dec 28, 2017 6:56 pm Post subject: Re: 40 hp evolution |
EverettB wrote: |
EverettB wrote: |
5. Yes, you should have a metal vacuum line. After doing some searching on here, I am pretty sure it should be the one with loop and not the one with simply a bend in it. |
To be more clear on this - I couldn't find when it was switched from the circle to the "hump" style in Progressive Refinements but there is another user on here that had a very original late 1963 1500cc Bus and it still had the circle style.
As far as I know 1500cc vs. 40hp would not matter for that part.
Someone else posted that the hump style was introduced in 1964 but he did not list the source of that information.
This
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1487879
Maybe will chime in on where he found 1964 or if that was an educated guess. |
Feb '63 bus owner's manual shows the hump. (Oct. '62 doesn't)
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Marand Samba Member
Joined: December 24, 2017 Posts: 9 Location: Vancouver Canada
Posted: Thu Jan 02, 2020 5:44 pm Post subject: Re: 40 hp evolution |
Calling all the stale air experts out there again after all your informational assistance who helped me build my Sept 62 stale air 40hp build to this point.
The pic shows where I am at so far but would live some critiquing on where I might be missing the mark on being factory stock.
I know I don"t have the vent line connected just wanted to confirm the length first
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jan 02, 2020 5:49 pm Post subject: Re: 40 hp evolution |
Other than the coil and vacuum line it looks good! _________________ In Stereo, Where Available! |
Busted-bolt Samba Member
Joined: April 14, 2018 Posts: 514 Location: minnesoota
Posted: Thu Jan 02, 2020 6:25 pm Post subject: Re: 40 hp evolution |
My 9-30-60 61 panel has the vent on the oil breather assembly but there is no vent connection on the air filter. The engine was a factory replacement so I might not have the correct oil breather assembly.
_________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission. |
Posted: Thu Jan 02, 2020 7:02 pm Post subject: Re: 40 hp evolution |
Busted-bolt wrote: |
The engine was a factory replacement so I might not have the correct oil breather assembly. |
Definitely the wrong oil filler. _________________ In Stereo, Where Available! |
Marand Samba Member
Posted: Thu Jan 02, 2020 7:20 pm Post subject: Re: 40 hp evolution |
Hi Eric&Barb your thought is that I need the looped vacuum line? |
Marand Samba Member
Posted: Thu Jan 02, 2020 7:21 pm Post subject: Re: 40 hp evolution |
And I'm guessing I need a black coil and my coil clamp should be zinc plated correct? |
Posted: Thu Jan 02, 2020 7:51 pm Post subject: Re: 40 hp evolution |
Marand wrote: |
Correct, and correct with yellow label. _________________ In Stereo, Where Available! |
Lind Samba Member
Posted: Thu Jan 02, 2020 7:56 pm Post subject: Re: 40 hp evolution |
Marand wrote: |
Yes, and yes. You can search out correct date codes for electrical items like coils if you want to be super correct.
You can gently bend the humped vacuum line into a loop style. _________________ .
Wanted:
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Thu Jan 02, 2020 9:36 pm Post subject: Re: 40 hp evolution |
Marand wrote: |
Calling all the stale air experts out there again after all your informational assistance who helped me build my Sept 62 stale air 40hp build to this point. |
You also have 40 HP fresh air head tin. _________________ In Stereo, Where Available! |
Posted: Thu Jan 02, 2020 9:50 pm Post subject: Re: 40 hp evolution |
Marand wrote: |
Incorrect fan shroud. The below from the Progressive Refinements:
Like the upper one in the image below:
Posted: Thu Jan 02, 2020 10:02 pm Post subject: Re: 40 hp evolution |
Eric&Barb wrote: |
Definitely the wrong oil filler. |
The below from PR:
Posted: Thu Jan 02, 2020 10:15 pm Post subject: Re: 40 hp evolution |
Marand wrote: |
Should be a bright blue colored spark plug cables. The below from the original 22 mile 64 Beetle:
Posted: Fri Jan 03, 2020 7:32 am Post subject: Re: 40 hp evolution |
At any time did the engine blocks receive a black coat of paint from production. It appeared that the VW replacement engine did from my 61. It also had oversized pistions 77.5 mm and cam bearings. Any one know where I can get rings for those? Id like to bore out some bastard cylinders for my 60. _________________ Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
Lind Samba Member
Posted: Fri Jan 03, 2020 8:34 am Post subject: Re: 40 hp evolution |
At any time did the engine blocks receive a black coat of paint from production. It appeared that the VW replacement engine did from my 61. |
I have seen plenty of VW remanufactured cases, and none of the ones I have seen were painted.
Revmaster in Riverside would paint the cases on the engines that they rebuilt. _________________ .
Wanted:
Posted: Sat Jan 04, 2020 9:19 am Post subject: Re: 40 hp evolution |
I have the right oil filler ,I just had to dig in my parts pile. I was wondering what is the correct upper bell housing tin for my bastard forty hp build.
Posted: Sun Jan 05, 2020 7:08 pm Post subject: Re: 40 hp evolution |
Would try the "Bastard 40 HP Engine" thread in the FAQ's. Lots of great info and images to go by. _________________ In Stereo, Where Available! |
House Minutia Militia
