Domed pistons and WW okrasa heads?
Frederik
Frederik is offline
PostPosted: Tue Jan 07, 2020 10:23 am    Post subject: Domed pistons and WW okrasa heads? Reply with quote
Bought a new KS piston and cylinder kit for 36hp. I think the pistons in the kit are 40hp and the cylinders 36hp. Pistons have a small dome. Has anyone tried this with a ww kit/ heads? Any clearens problemet? Would it be doomed Rolling Eyes to fail with ratio rockers,1.25 1.4 speedwell or other?
AirCooledClassics
AirCooledClassics is offline
PostPosted: Fri Jan 10, 2020 1:16 pm    Post subject: Re: Domed pistons and WW okrasa heads? Reply with quote
Go for it,They are a great setup. I run 1500 type 3 domed on my Bville engine with ww heads .060 deck, 1.25 ratio rocker and a porsche grind cam.The 77 dome top rev like a hot dam
2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552
PEPPE
PEPPE is offline
PostPosted: Sat Jan 11, 2020 3:40 am    Post subject: Re: Domed pistons and WW okrasa heads? Reply with quote
piston are european mid 70/80 from 40 hp engine with about 1mm machined for clearance.
PEPPE
PEPPE is offline
PostPosted: Sat Jan 11, 2020 3:42 am    Post subject: Re: Domed pistons and WW okrasa heads? Reply with quote
i would check for piston to cylinder clearance. 36hp is tighter and 40hp is looser.
AirCooledClassics
PostPosted: Sun Jan 12, 2020 9:07 am    Post subject: Re: Domed pistons and WW okrasa heads? Reply with quote
I have used these p?cyl here they came off of Mexican factory industrial engines.If your worried about it silly putty the heads and check clearance
My You-tube video
Frederik
Frederik is offline
PostPosted: Sun Jan 12, 2020 6:00 pm    Post subject: Re: Domed pistons and WW okrasa heads? Reply with quote
Thanks for your replys!
