Questions and Advice Before Installing Engine and Trans
Charlie57
Charlie57 is offline
PostPosted: Mon Jan 13, 2020 10:15 am    Post subject: Questions and Advice Before Installing Engine and Trans Reply with quote
I am very close to getting my engine and trans installed, but have a few questions. The engine turns out to be a 73, not sure about trans, it appears that the trans only has three available bolt holes to bolt to the engine due to the starter, while the bolt at the starter appears to go there should I consider running one long bolt from the starter to the engine?
Should I install it as one piece or do them separately?
Any accessories or pieces I should have on or leave off, such as the heat tubes?
Is the front transmission mount pictured suppose to be metal to metal?
The retainer/clip I have pictured, where are they actually used, I have two.
Based on the photos do you see any mistakes I'm about to make?
Any other advice would be appreciated.
Thanks,
Charlie
CarlosZ
CarlosZ is offline
PostPosted: Mon Jan 13, 2020 10:33 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
I’d double check that the tin isn’t sandwiched between the intake manifold and heads. Wrestling the tins once the engine’s installed sucks.
Wildthings
Wildthings is offline
The "D" bolt needs to be removed and then will go through the starter, the bell housing, and the engine flange in the opposite direction.
Your transmission appears to be an 091 "6 rib". Assuming it has the later bellhousing you will need the later starter to match. If this is going into a 72-75 van you mayhave to shorten the shift rod to get the shifter positioned correctly.
It is way easier to close off the large rectangular hole in your tin before you install the engine than to do it with the engine installed.
Knowing the year of your van would be helpful.
ivwshane
ivwshane is offline
PostPosted: Mon Jan 13, 2020 12:33 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
You are missing some seals around your alternator (dipstick and alternator seal), you may want to take care of those before the engine goes in.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Wildthings
PostPosted: Mon Jan 13, 2020 1:45 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
Charlie57 wrote:
You need to get the screws and fender washer that attach the tin to the heads to the front and back of where the intake manifold bolt into place.
The hole where the tube from the heat exchanger comes up through the tin needs to be sealed off if you don't have the tube. The hole in the heat exchanger needs to be closed off as well.
timvw7476
timvw7476 is offline
PostPosted: Mon Jan 13, 2020 2:25 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
If you do install the engine after the transaxle the three pieces of tin at the
rear will have to be off to do it. Maybe the oil filler pipe as well, it will go in
with it installed but tends to scrape the rear metal of the bus body.
alaskadan
alaskadan is offline
PostPosted: Mon Jan 13, 2020 8:25 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
Why not mate the engine and trans together and install as one. At least dry fit them together. That would let you make sure the starter fits, the clutch on its splines, the pilot bushing, etc.
Wildthings
PostPosted: Mon Jan 13, 2020 8:56 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
Why is your pilot bearing sitting on the bench still?
sjbartnik
sjbartnik is offline
PostPosted: Mon Jan 13, 2020 8:59 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
Charlie57 wrote:
I
Naw dawg.
You've got that starter bolt backwards. Take it out from where you have it now.
Get the engine in, using the two lower studs & trans input shaft to align it with the transmission.
Once you get it mated up fully, then you put in the top two bolts. The D shape on the starter bolt fits against the starter so you can put the nut on from inside the engine compartment without the bolt turning.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Charlie57
PostPosted: Wed Jan 15, 2020 10:28 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
Good catch, the engine builder installed one, plus I ordered the wrong clutch kit. Anybody want to buy a 78 clutch?!
Charlie57
PostPosted: Wed Jan 15, 2020 10:32 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
The bus is a 78, the engine is a 73, the trans is stamped 091 but not sure of the year. I took it out of the bus with this set up so I believe I'll be alright. Just learned my started bearing are bad, going to start looking, it is marked 921 Bosch 0-00-211-221
halfassleatherworks
PostPosted: Wed Jan 15, 2020 11:20 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
did you put a new starter bushing in when it was apart?
better now then later
Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, *****
Charlie57
PostPosted: Thu Jan 16, 2020 10:50 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
That was my plan unless there was a good reason not to.
Wildthings
PostPosted: Thu Jan 16, 2020 10:59 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
Not sure what you mean by bearing. There is a bushing that is installed into the bellhousing that supports one end of the starter shaft and another bushing on the other end of the shaft that is pressed into the starter endplate. The bushing in the flywheel is easily replaceable with the engine and tranny split.
If someone tried to bench test your starter, it would sound like a bearing/bushing is bad because the one end of the shaft is not supported without the starter being installed on the car or into the proper jig.
Charlie57
PostPosted: Thu Jan 16, 2020 11:14 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
[/quote]
If someone tried to bench test your starter, it would sound like a bearing/bushing is bad because the one end of the shaft is not supported without the starter being installed on the car or into the proper jig.[/quote]
I meant to say bushing, just got it mixed up. I know they tested the starter on a brand new machine but I doubt it had support on the end of the shaft.
Charlie
vwwestyman
vwwestyman is offline
PostPosted: Sat Jan 18, 2020 7:02 pm    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
I would install them together as a unit.
The front transmission mount isn't metal to metal, it's just that the rubber part was also spray painted silver.
The "retainer/clip" things you're asking about-Do you mean the funny looking things hanging off the bolts at the top of the transmission?
Assuming so, those aren't used when the transmission is installed. I suppose they are there to keep the bolts from getting lost.
Do those bolts have tapered ends, or are they flat? If I remember correctly, the original bolts have tapered ends to help get them started, because they are kind of in a fiddly place.
Dave Cook
1973 Wild Westerner
My Thing
SamboSamba22
SamboSamba22 is offline
PostPosted: Sun Jan 19, 2020 8:47 am    Post subject: Re: Questions and Advice Before Installing Engine and Trans Reply with quote
I second the recommendation to install the engine and transmission as a pair. I find this much easier to do since the rear aprons on 72-79 Bay’s are not removable.
I’m currently tackling a similar project: finished building a 2L paired with a 5-Rib transaxle going into a 1973 Transporter. I will be installing as a pair. It’s as simple as attaching the motor cross bar (mustache bar) to the chassis, the upper transmission carrier bolts, and the front (front is front) transmission bracket (two 17m bolts w/ bracket) holding the nosecone. Everything else (cv joints, electrical, shift rod, couplers, fuel lines, cables, etc...is fairly straight forward.
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
