lee griffiths Samba Member
Joined: February 02, 2004 Posts: 229 Location: Manchester, UK
Posted: Wed Jul 11, 2012 11:56 pm Post subject: |
So can we even get compensation now from WW and the hassle the product is causing ? _________________ Lee Griffiths
72 Westfalia Campmobile Type 4 1700 |
bus guy Samba Member
Joined: November 13, 2002 Posts: 785 Location: Southsea, UK South Coast
Posted: Thu Jul 12, 2012 12:28 am Post subject: |
I went to an o ring supplier years ago and got some fat nitrile o rings and have been using them ever since with no problems. I'm pretty sure ww will eventually step up and sort it out, but forget about any compensation, I'm sure something about thAt is in their terms of sale.
X2 about what everyone says about better quality vs mOre expensive, most people will still be lead on Price alone. Sad but true |
llovette Samba Member
Joined: March 07, 2002 Posts: 377 Location: north of Philly
Posted: Thu Jul 12, 2012 2:38 am Post subject: |
WideFive wrote: |
llovette wrote: |
had Aaron from ohio do mine last August. The same for me, they split after only about 2 weeks. I reused original VW . 45 years old these seals are. |
Just to clarify... STOCK rebuild and those were the "stock" style seals for the link pins NOT the king pin seals, correct?
I've been using the o-ring type seal since I started doing spindles. I have not personally had a failure or been notified about any customers having a king pin seal fail.
Thanks. |
Yes!! The seals that split were for the link pins. Just to be very clear, Your stock rebuilt spindles quality is second to none and could'nt be happier with there performance almost 1 year later |
Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1381 Location: Arizona's version of the east coast
Posted: Thu Jul 12, 2012 7:14 am Post subject: |
Same problem here.......I talked with both Tony and Rich about this months ago with no solution given for the problem.
Wait til you guys try the $125 plus hubcaps that they are selling, from Wolfsburg Classics.....the factory VW parts program _________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu Jul 12, 2012 9:29 am Post subject: |
Those seals have been complete garbage for years. Considering the amount of effort it takes to put in a new set it's criminal that they are even allowed into the marketplace. Cleaned up used ones are the way to go. I had a set of the crap ones split and ended up finding thin 1/4 inch wide worm clamps that I put around each one. At least I can squirt in grease and a fair amount of water stays out. I bought some new VW-Audi Brazilian seals to put on but never did. They are still good in the box but that proves nothing. |
runderwood Samba Member
Joined: July 17, 2007 Posts: 274 Location: near philadelphia, pa
Posted: Thu Jul 12, 2012 12:32 pm Post subject: |
Mine are completely shot as well. Didn't last at all.
Anyone know the size o-ring that works for this?
McMaster-Carr seems to have a nice selection ( http://www.mcmaster.com/#o-rings )... now to just know which is the correct material and size... _________________ 61 DD Panel |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Sun Sep 30, 2012 12:12 pm Post subject: |
I`m about to put some spindles on my panel and will need to find some O rings to rplace what`s left of the kingpin seals on them now. So if anyone knows the right size o ring to use it would save me some hassle. Thanks. _________________ If you`re going to do something, do it right. |
sled Samba Member
Posted: Sun Jun 09, 2013 9:07 am Post subject: |
the answer has been discussed above, o rings.
_________________ drive your split. |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Sun Jun 09, 2013 10:01 am Post subject: |
All of the black rubber WW is using these days is JUNK! I have had a set of decklid hinge seals on my decklid for 4 months and they are already cracking badly! No doubt they are made of the same rubber! |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sun Jun 09, 2013 10:26 am Post subject: |
After "knocking" the O-ring concept for many years I finally got fed up when I had about 50 Wolfsburg West kingpin seals fail after having a batch of rebuilt spindle sit on the shelf unused for six months. Amazingly I had almost zero complaints from customers about them before that point and I had used a ton of them.
Since then, I've been using part #9452K44 from Mcmaster Carr in all our spindle rebuilds.
It's listed as Buna-N O-Ring AS568A Dash Number 325
I also tried the "hard" Buna-N O-rings they sell but found them slightly difficult to install in colder weather. The part number listed above seems to work fine and I have received no complaints with them. I haven't seen one crack or split yet. Buna rubber is supposed to hold up well to gas, grease, and oil.
If anyone has a better suggestion for o-rings feel free to let me know.
I've also had trouble with the WW breather pipe boots and the 2" fresh air tube seals. They usually crack and fail within about six months of use. The 2" seals don't get exposed to oil or gas but they likely do get warm sitting right above the exhaust. |
Posted: Sun Jun 09, 2013 2:53 pm Post subject: |
campingbox wrote: |
Oh yeah, my WW breather boot is cracking badly after a few months too, the fresh air seals are fine so far. |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Tue Jun 11, 2013 7:43 am Post subject: |
i had similar problems with swingaxle boots, front suspension tierod boots, irs CV joint boots, Type4 oil disptick seals, some engine pushrod seals, vw original (!) air seals for 50mm air tubes in engine compartment.
some also cracked also before betting oil/grease inside. just being in the garage during restoration.
very shitty parts. |
azbob Samba Member
Joined: April 04, 2010 Posts: 714 Location: Phoenix, AZ
Posted: Mon Jan 27, 2014 1:09 pm Post subject: |
So the going consensus is to use the Mcmaster Carr O rings? _________________ Bus Builder |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sun Jan 18, 2015 9:02 pm Post subject: |
Old post, I know.
I took apart my spindles from a 1963 double cab. This has the 1 year 1 ton suspension. All the parts appear to be original VW so I don't think this has ever been apart.
On both spindles, the top and kingpin seal was cracked and not reusable. The bottom was mostly missing. It has a VW on the inner surface but I could find no part number. This seal is quite a bit bigger in diameter than the other seals
The other seals in the middle were also OE VW but they have a part number of 211 405 439 and some other numbers 32836 and 2-12 on the inside.
I understood that all the kingpin and linkpin seals were the same.
I guess it's possible that the seal has swollen accounting for the size difference, but the missing part number on the inside has me wondering if there is a slightly different size for the Upper and possibly lower versus the center two and the linkpin seals on this 1 year only suspension?
Thoughts anyone? |
Posted: Sun Jan 18, 2015 9:33 pm Post subject: |
They are all the same, early, late, '63 1-ton, barndoor, etc. Feel free to review the parts list. |
Scott'sVR Samba Member
Posted: Wed Jan 15, 2020 6:46 pm Post subject: Re: New kingpin seals have snapped and fallen off - advice pleas |
This is a good way to do it without pressing them apart. Buy o-rings and spend 40$ on this loctite 404 which is designed specifically for gluing o-rings. One drop and about 5 seconds and you physically cant rip apart the joint! cut your o-rings, wrap them around and apply a drop of glue, literally can do the whole job in about 5 minutes with little disassembly.
ezcamper Samba Member
Joined: January 10, 2001 Posts: 897 Location: Atlantic Beach, FL
Posted: Wed Jan 15, 2020 8:13 pm Post subject: Re: New kingpin seals have snapped and fallen off - advice pleas |
I sell correct seals make from the correct rubber that will not crack or split when grease touches them. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
