xzener Samba Member
Posted: Sat Nov 09, 2019 4:17 pm Post subject: Re: The Aufgeladen Ghia |
Picked up a 900mm belt. Stock is 905mm... Should fix the problem right up. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sun Nov 10, 2019 4:29 pm Post subject: Re: The Aufgeladen Ghia |
Electric fuel pump plummed. Truss bar installed and tightened. I guess the motor is ready to go back in.
xzener Samba Member
Posted: Mon Nov 11, 2019 5:31 pm Post subject: Re: The Aufgeladen Ghia |
After replacing the alternator belt and securing everything, the damn fan was rubbing the shroud somewhere. Wedged a BA screwdriver and forced the alternator into the shroud a tad bit. Tightened everything down. No more rubbing. NOW she's ready to go back in.
greek_tony Samba Member
Joined: February 12, 2013 Posts: 243 Location: Athens, Greece
Posted: Tue Jan 14, 2020 6:44 am Post subject: Re: The Aufgeladen Ghia |
Any news? _________________ 1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there. |
xzener Samba Member
Posted: Thu Jan 16, 2020 6:13 pm Post subject: Re: The Aufgeladen Ghia |
Sorry, no. Been super busy over the holidays. Been contemplating a freeway flier transmission. Would be the perfect time. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Fri Jan 24, 2020 9:19 pm Post subject: Re: The Aufgeladen Ghia |
where is your rear bag kit from? didn't read(most likely overlooked) it anywhere.
thanks |
xzener Samba Member
Posted: Sun Jan 26, 2020 11:47 am Post subject: Re: The Aufgeladen Ghia |
It's called The Game Changer from jj-vintage.de
LCDR O Samba Member
Joined: July 03, 2016 Posts: 46 Location: Isabela, Puerto Rico
Posted: Wed Feb 19, 2020 7:58 am Post subject: Re: The Aufgeladen Ghia |
xzener wrote: |
AMR500 mounting holes tapped. Got everything mocked up, now to tighten everything down. Have the Weber DCOE 40 in place just to see the overall look. This thing looks bad ass! This was fairly easy to install, some of the manifold bolts on the intake side were difficult to start. Easier to remove the intake manifold off the boot, after that, no problem.
Did you have any issues clearing the decklid? Enough space there? I am seriously considering doing this upgrade, but want to make sure before ordering stuff from, literally, half way across the Earth.
Mike |
xzener Samba Member
Posted: Thu Feb 20, 2020 9:54 pm Post subject: Re: The Aufgeladen Ghia |
The engine is still sitting in that very spot. The weather is warming up finally, was thinking about installing it this weekend.
Looking at other Ghia's with this setup, I'm afraid the deck lid will not clear. I am planning on two things... 1) Buying another deck lid to butcher, paint and install. 2) Using stand offs to raise the deck lid to clear the assembly. Probably do the latter at first. There is another setup, from The Dub Shop, that may clear the deck lid. I think it's much more expensive than Joeblow setup. Here is a link to one installed and running...
xzener Samba Member
Posted: Mon Feb 24, 2020 5:22 pm Post subject: Re: The Aufgeladen Ghia |
While the engine is out, waiting for warmer weather, decided to pull the air ride setup out and get some odd jobs done... As well as upgrade the air ride. Haven't been happy with the brightness of the running lights (headlight halos). Replaced the resistors I installed to dim them, and am pleased with the results. Also installed a missing lamp socket/bulb in the speedometer. Now, the dash is fully lit. For the air ride, I purchased the new Accuair E-Level Plus ECU. This thing should resolve the battery drain I had with my original ECU. Here are some pictures of the progress so far...
Instead of modifying my current mount, I made a new one.
Here it is after vaneer...
Stain and polyurethane...
Installed the new ECU.
Ready to go back in, but had to lengthen the sensor harness...
xzener Samba Member
Posted: Sun Mar 01, 2020 2:36 pm Post subject: Re: The Aufgeladen Ghia |
Finally got the Accuair E-Level Plus installed. Now for the engine...
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
xzener Samba Member
Posted: Sat Mar 07, 2020 2:42 pm Post subject: Re: The Aufgeladen Ghia |
Rewrapped the dashboard today...
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Sun Mar 08, 2020 2:13 am Post subject: Re: The Aufgeladen Ghia |
Although I'm no air ride guy, that setup looks very neat! Also, the wrapped dash cover adds a little extra something without jumping out too much, great idea! _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sun Mar 08, 2020 5:10 am Post subject: Re: The Aufgeladen Ghia |
What did you use to rewrap the dash pad?
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
xzener Samba Member
Posted: Sun Mar 08, 2020 2:15 pm Post subject: Re: The Aufgeladen Ghia |
It's a faux leather material I picked up at Jo-Ann's. Used Gorilla glue spray adhesive and gorilla super glue around the vent areas. That's were it peeled up with the 3M 90 spray adhesive that didn't seem to ever dry properly... It seemed to have a chemical reaction to the material and got all gooey. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Mar 10, 2020 4:57 pm Post subject: Re: The Aufgeladen Ghia |
Ok. Enough procrastinating. Time to get this engine back in. But first, I need to weld in a bung for the O2 sensor. Looking at the inside of this muffler, it looks to have a collector inside that dissipates the exhaust into the muffler housing. Should work out perfectly with the O2 sensor placement. It's centered and furthest away from the tips. Hope this works...
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Tue Mar 10, 2020 7:36 pm Post subject: Re: The Aufgeladen Ghia |
You always do such careful work. _________________ Volkswagen!
(Compression 8.7:1) |
xzener Samba Member
Posted: Tue Mar 10, 2020 8:17 pm Post subject: Re: The Aufgeladen Ghia |
Haha! Thanks Jeff. This Ninja coffee maker box was a perfect fit. Was surprised I was able to drill the hole. My DeWalt drill batteries are on their last legs. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Mar 11, 2020 4:58 pm Post subject: Re: The Aufgeladen Ghia |
Welded, primed, and painted with 2000 degree paint...
