mc lovin it , early 1964 bug project
Page: Previous  1, 2, 3, 4 ... 15, 16, 17  Next
bad91teg
bad91teg is offline
PostPosted: Sat Jan 11, 2020 12:15 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
bad91teg
bad91teg is offline
PostPosted: Thu Jan 16, 2020 4:37 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
talk about a new world . with body off you have access to everything. cool to look at everything on chassis.
bad91teg
bad91teg is offline
PostPosted: Thu Jan 16, 2020 6:39 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
then got the foam cannon out.
bad91teg
bad91teg is offline
PostPosted: Thu Jan 16, 2020 6:54 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
then to dry it , I used a leaf blower. I must say , very satisfying to clean the chassis .
Buggeee
Buggeee is offline
PostPosted: Thu Jan 16, 2020 8:27 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
66brm wrote:
I agree, and that wiring will be "fun"
Ya with paint on all the colored wires, disguising them, and the age of the connections, It would be easier to run a fresh harness. I got a complete harness from JBugs for my 61 and it went right in, everything color coded correctly and proper lengths.
Rebuilt Salvage
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
Buggeee
Buggeee is offline
PostPosted: Thu Jan 16, 2020 8:42 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
This really does look to be in very good condition. A nice dry bug. Wow I am jealous of the car stock you all have in the south. Again congratulations now that it's cleaned for a closer look.
Adjustable front beam in there. Are you going to drop it? My early bug is left tall but everyone around here in Ohio gets their bug low as a matter of course.
Rebuilt Salvage
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 8:40 am    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
yes thanks for input on wiring. im trying to decide about new harness or not ? I inspected main harness. its in goooood condition. but....that paint on wires I know.. thinking maybe goof off to get paint off ? and was wondering about the quality compared to stock harness. im not sure what t o do yet ?
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 8:43 am    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
ya gonna lower 1 notch in rear.... then lower front to match.. not slamming it ,but lowered. thanks again buggee
calvinater
calvinater is offline
PostPosted: Sat Jan 18, 2020 8:53 am    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
Whats this foam cannon you speak of?
"War...War Never Changes"
"three is the magic number"
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 5:53 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
its a canister you put on end of pressure washer . look up foam cannon on youtube. its actually laying on the ground in one of the pics . I sprayed with foam cannon , then pressure cleaned the chassis
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 5:58 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
l I don't have money for media blasting or dipping . gonna use a lot of elbow grease . wirewheels,sandpaper,and grinder wheels . decided to work on bulk head.
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 6:04 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
got a package .
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sat Jan 18, 2020 6:10 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
Looks pretty good.
Get after that bare metal with some Ospho (phosphoric acid) and convert that rust to iron oxide. Then prime and paint it when you have the rest of the chassis cleaned up.
Good Luck.
66brm
66brm is offline
PostPosted: Sat Jan 18, 2020 6:51 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
If the harness is in good condition and the paint can be removed then use it but going off the progress and your mechanical aptitude it may be more time efficient/cost effective to pull a new harness through
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 6:56 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
moved to tar boards. no dry ice ,,,, but
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 7:05 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
working on the pans.
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 7:10 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 7:48 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
ran into a patch job and , some rust in the rear . Mad theres no way I could leave that lol . so .blue tape is where I cut . im trying to keep as much og metal as possible
bad91teg
bad91teg is offline
PostPosted: Sat Jan 18, 2020 8:07 pm    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
moving to the rear
Buggeee
Buggeee is offline
PostPosted: Sun Jan 19, 2020 12:15 am    Post subject: Re: mic lovin it , early 1964 bug project Reply with quote
bad91teg wrote:
It's ready for clear coat right now. Shocked Wow that's alot of elbow grease!
Rebuilt Salvage
Page 3 of 17
