valvecovergasket Samba Member
Posted: Fri Jan 17, 2020 12:33 pm Post subject: Re: Stainless Coolant Pipes |
Sodo wrote: |
Jeffrey Lee wrote: |
valvecovergasket wrote: |
would there have been any room to upsize to the larger ones? i assume its a huge project with little upside given the tight quarters under there |
There is little benefit—and much added work—to installing the 1.5" pipes in an older van which has the 1.25" pipes. Just install new 1.25" SS replacement pipes. |
I agree.
Looking around for evidence,,,, consider that the big-engine crowd, by now, would have discovered if the 1.25s were insufficient. |
Sounds good!
Yeah that makes sense, I don't see anyone complaining about capacity with swapped older vans _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
jlrftype7 Samba Member
Posted: Fri Jan 17, 2020 12:34 pm Post subject: Re: Stainless Coolant Pipes |
to sort of derail the topic - whats the feeling on replacing the old 1.25" metal pipes with like-sized stainless?
maybe dont bother?
or how hard is fitting 1.5" stainless lines in place of factory 1.25" originals? |
I did this since I have a stock 1.9 liter system. You would have to open up or expand the sheetmetal sections that the stock metal pipes are routed through if you upgrade to the later 1 1/2" pipes.
The stock holes fit the smaller 1 1/4" pipes . This is mentioned in several places if you're thinking about it.
I stuck with 1/ 1/4" pipes, may someday have to buy adapters if I need the radiator hoses since I think only the 1 1/2" ones are easily available compared to the earlier hoses.
My original steel pipes were very nice internally, they only rusted on the outside at a couple of spots, but a leak is a leak either way... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Fri Jan 17, 2020 12:49 pm Post subject: Re: Stainless Coolant Pipes |
Sodo wrote: |
fxr wrote: |
Sodo wrote: |
Are the stainless steel pipes electrically isolated from the van chassis? They are certainly isolated from the engine by the rubber hoses. It seems like if they are isolated, they would add no threat of corrosion. Is this true? |
They are electrically connected via the coolant, which is slightly conductive |
Yes the coolant (as a mild electrolyte is a current path). My question is, if the pipes are isolated, what then......is the other current path? |
There isn't. You need the metal to metal contact to create a thermoelectric junction and lead to corrosion. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Fri Jan 17, 2020 1:27 pm Post subject: Re: Stainless Coolant Pipes |
E1 wrote: |
Jeffrey, I'd think that the worse the strain, the more the gain of the larger pipes, No? |
More, of course, is always better, especially when discussing motor sports. But do we really want to apply that term to Vanagons?
It's Friday, so ...
Assuming a 10' length of pipe, the difference in total fluid capacity between the two pipe diameters is approximately 36 fluid ounces, or 2.25 pints of Potosi Snake Hollow IPA*.
That's roughly one additional quart in an 18-quart cooling system, or about 5% more.
* For the record, I generally find the Potosi eminently more drinkable than the ethylene glycol, with a cleaner finish. _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Fri Jan 17, 2020 1:44 pm Post subject: Re: Stainless Coolant Pipes |
AtlasShrugged it is really great to have you back. Hope you are doing well and won't take this first thread back as a deterrent to giving your input. I have relied on many of your past posts for top notch information over the years. Your knowledge is greatly valued here. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Fri Jan 17, 2020 2:19 pm Post subject: Re: Stainless Coolant Pipes |
Math Alert!
With the aid of the aforementioned Snake Hollow IPA, I just realized that my previous calculations only factored for ONE theoretical coolant pipe, rather than the customary TWO pipes. This sort of numerical nonsense is exactly how very expensive space probes are lost.
So, the difference in total fluid capacity between the two pipe diameters is approximately 72 fluid ounces, or 4.5 pints of Potosi Snake Hollow IPA.
That's roughly TWO additional quarts in an 18-quart cooling system, or about 10% more. Which is not negligible, but still unnecessary, IMHO. _________________ Camp Westfalia
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Jan 17, 2020 4:48 pm Post subject: Re: Stainless Coolant Pipes |
khughes wrote: |
Sodo wrote: |
fxr wrote: |
Sodo wrote: |
There isn't. You need the metal to metal contact to create a thermoelectric junction and lead to corrosion. |
The current path between the aluminium components such as the engine block and the stainless steel coolant pipes is the chassis - the coolant pipes are mounted with steel saddles screwed into the chassis (at least mine are using the original saddles on the 1.25" steel pipes) and the engine is earthed to the chassis. But if you change your coolant regularly it has corrosion inhibitors that would prevent the reaction happening anyway. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Fri Jan 17, 2020 5:19 pm Post subject: Re: Stainless Coolant Pipes |
Re: Corrosion issues. I've had the SS pipes for about 13 years now. If there was going to be a corrosion issue I would have seen it.
Change your coolant, I do so every 2-3 years. The corrosion inhibitors take care of the problem as long as they're kept reasonably fresh.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Posted: Fri Jan 17, 2020 5:51 pm Post subject: Re: Stainless Coolant Pipes |
Mellow Yellow 74 wrote: |
khughes wrote: |
Sodo wrote: |
fxr wrote: |
Sodo wrote: |
The current path between the aluminium components such as the engine block and the stainless steel coolant pipes is the chassis - the coolant pipes are mounted with steel saddles screwed into the chassis (at least mine are using the original saddles on the 1.25" steel pipes) and the engine is earthed to the chassis. But if you change your coolant regularly it has corrosion inhibitors that would prevent the reaction happening anyway. |
You don't need a current path. You need the dissimilar metals to contact each other in the presence of a electrolyte for electrolytic corrosion, or without any electrolyte for a Seebeck thermoelectric effect. Either way, corrosion is only at the junction of the different metals. Unless you introduce an external current/voltage. Those are the only mechanisms for dissimilar metal corrosion I'm aware of. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Fri Jan 17, 2020 8:14 pm Post subject: Re: Stainless Coolant Pipes |
khughes wrote: |
khughes wrote: |
Sodo wrote: |
fxr wrote: |
Sodo wrote: |
You don't need a current path. You need the dissimilar metals to contact each other in the presence of a electrolyte for electrolytic corrosion, or without any electrolyte for a Seebeck thermoelectric effect. Either way, corrosion is only at the junction of the different metals. Unless you introduce an external current/voltage. Those are the only mechanisms for dissimilar metal corrosion I'm aware of. |
So....can stainless steel pipes increase "corrosive activity" anywhere in the system?
Where would this increased corrosive activity be?
There is no "other metal" touching the stainless pipe (inside).
And what if they were mounted with "insulation" (no path to gruond)? _________________
....KTMs, GasGas, SPOT mtb |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Sat Jan 18, 2020 10:05 am Post subject: Re: Stainless Coolant Pipes |
"You don't need a current path. You need the dissimilar metals to contact each other in the presence of a electrolyte for electrolytic corrosion"
No worries about SS coolant pipes and a dissimilar metals/electrolyte/corrosion problem.
You already have four big ferrous metal jugs (the piston cylinders) and sixteen steel rods (head studs) in contact with aluminum swimming in hot coolant all the time.
[/u] |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Jan 18, 2020 11:37 am Post subject: Re: Stainless Coolant Pipes |
I repaired my plastic pipes at the time of my Subaru installation almost ten years and ~80,000 miles ago and haven't heard a peep from them since!
Heated the pipes and tapped the steel inserts back in, then secured them with a couple of rivets each. Easy peasy - and very inexpensive. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Sat Jan 18, 2020 12:28 pm Post subject: Re: Stainless Coolant Pipes |
AtlasShrugged wrote: |
You already have four big ferrous metal jugs (the piston cylinders) and sixteen steel rods (head studs) in contact with aluminum swimming in hot coolant all the time. |
Well...*you* might. _________________ '86 Westy FAS GenV Turbo (Marvin) |
jimf909 Samba Member
Posted: Sat Jan 18, 2020 1:50 pm Post subject: Re: Stainless Coolant Pipes |
termuehlen wrote: |
AtlasShrugged it is really great to have you back. Hope you are doing well and won't take this first thread back as a deterrent to giving your input. I have relied on many of your past posts for top notch information over the years. Your knowledge is greatly valued here. |
I was working my way to the end of this thread to say the same thing. A few folks here have rock-solid credibility behind their advice. You're one of 'em. Thanks. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Posted: Sat Jan 18, 2020 2:00 pm Post subject: Re: Stainless Coolant Pipes |
No worries about SS coolant pipes and a dissimilar metals/electrolyte/corrosion problem. |
The stainless pipes have no electrical contact with any of the "other engine or radiator metals" inside the coolant....
My thought is that there is NO corrosion concern because there is no contact.
I think this is what people want to "KNOW"....without "speculation". _________________
Zeitgeist 13 Samba Member
Posted: Sat Jan 18, 2020 4:09 pm Post subject: Re: Stainless Coolant Pipes |
Shark jumping 101:
This thread disappoints, as we haven't even discussed types of coolant, coolant filters, sacrificial anodes, magnets or even healing crystals. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sat Jan 18, 2020 7:45 pm Post subject: Re: Stainless Coolant Pipes |
jimf909 wrote: |
termuehlen wrote: |
I was working my way to the end of this thread to say the same thing. A few folks here have rock-solid credibility behind their advice. You're one of 'em. Thanks. |
You all are most welcome and I appreciate the fellowship.
[Moderator edit: Inflammatory second paragraph removed by request.] |
Selsk Samba Member
Posted: Tue Jan 21, 2020 4:42 pm Post subject: Re: Stainless Coolant Pipes |
This thread was an unexpectedly wild ride. Thanks for all the responses. I am going to order the GW stainless kit. |
Posted: Tue Jan 21, 2020 4:56 pm Post subject: Re: Stainless Coolant Pipes |
Selsk wrote: |
Indeed - just to reiterate in case it was lost in the melee, the GW kit will not work with some conversions (like my GenV FAS kit) without modification at the engine end. No biggie if you're staying stock, and I'm sure the quality is fine, just a reminder _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Wed Jan 22, 2020 2:07 pm Post subject: Re: Stainless Coolant Pipes |
khughes wrote: |
Selsk wrote: |
Indeed - just to reiterate in case it was lost in the melee, the GW kit will not work with some conversions (like my GenV FAS kit) without modification at the engine end. No biggie if you're staying stock, and I'm sure the quality is fine, just a reminder |
Correction - brainfart, the FAS kit will work with the GW or other currently marketed s/s pipes for 86 and later years. _________________ '86 Westy FAS GenV Turbo (Marvin) |
