bad91teg Samba Member
Joined: February 13, 2007 Posts: 473 Location: florida
Posted: Sat Jan 11, 2020 12:15 pm Post subject: Re: mic lovin it , early 1964 bug project |
Posted: Thu Jan 16, 2020 4:37 pm Post subject: Re: mic lovin it , early 1964 bug project |
talk about a new world . with body off you have access to everything. cool to look at everything on chassis.
Posted: Thu Jan 16, 2020 6:39 pm Post subject: Re: mic lovin it , early 1964 bug project |
then got the foam cannon out.
Posted: Thu Jan 16, 2020 6:54 pm Post subject: Re: mic lovin it , early 1964 bug project |
then to dry it , I used a leaf blower. I must say , very satisfying to clean the chassis .
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4391 Location: Stuck in Ohio
Posted: Sat Jan 18, 2020 8:40 am Post subject: Re: mic lovin it , early 1964 bug project |
Buggeee wrote: |
66brm wrote: |
I agree, and that wiring will be "fun" |
Ya with paint on all the colored wires, disguising them, and the age of the connections, It would be easier to run a fresh harness. I got a complete harness from JBugs for my 61 and it went right in, everything color coded correctly and proper lengths. |
yes thanks for input on wiring. im trying to decide about new harness or not ? I inspected main harness. its in goooood condition. but....that paint on wires I know.. thinking maybe goof off to get paint off ? and was wondering about the quality compared to stock harness. im not sure what t o do yet ? |
Posted: Sat Jan 18, 2020 8:43 am Post subject: Re: mic lovin it , early 1964 bug project |
Buggeee wrote: |
This really does look to be in very good condition. A nice dry bug. Wow I am jealous of the car stock you all have in the south. Again congratulations now that it's cleaned for a closer look.
Adjustable front beam in there. Are you going to drop it? My early bug is left tall but everyone around here in Ohio gets their bug low as a matter of course. |
ya gonna lower 1 notch in rear.... then lower front to match.. not slamming it ,but lowered. thanks again buggee |
calvinater Samba Member
Posted: Sat Jan 18, 2020 8:53 am Post subject: Re: mic lovin it , early 1964 bug project |
Whats this foam cannon you speak of? _________________ "Albatross"! |
Posted: Sat Jan 18, 2020 5:53 pm Post subject: Re: mic lovin it , early 1964 bug project |
calvinater wrote: |
Whats this foam cannon you speak of? |
its a canister you put on end of pressure washer . look up foam cannon on youtube. its actually laying on the ground in one of the pics . I sprayed with foam cannon , then pressure cleaned the chassis |
Posted: Sat Jan 18, 2020 5:58 pm Post subject: Re: mic lovin it , early 1964 bug project |
l I don't have money for media blasting or dipping . gonna use a lot of elbow grease . wirewheels,sandpaper,and grinder wheels . decided to work on bulk head.
Posted: Sat Jan 18, 2020 6:04 pm Post subject: Re: mic lovin it , early 1964 bug project |
got a package .
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Sat Jan 18, 2020 6:10 pm Post subject: Re: mic lovin it , early 1964 bug project |
Looks pretty good.
Get after that bare metal with some Ospho (phosphoric acid) and convert that rust to iron oxide. Then prime and paint it when you have the rest of the chassis cleaned up.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sat Jan 18, 2020 6:51 pm Post subject: Re: mic lovin it , early 1964 bug project |
bad91teg wrote: |
Buggeee wrote: |
66brm wrote: |
If the harness is in good condition and the paint can be removed then use it but going off the progress and your mechanical aptitude it may be more time efficient/cost effective to pull a new harness through _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Sat Jan 18, 2020 6:56 pm Post subject: Re: mic lovin it , early 1964 bug project |
moved to tar boards. no dry ice ,,,, but
Posted: Sat Jan 18, 2020 7:05 pm Post subject: Re: mic lovin it , early 1964 bug project |
working on the pans.
Posted: Sat Jan 18, 2020 7:10 pm Post subject: Re: mic lovin it , early 1964 bug project |
Posted: Sat Jan 18, 2020 7:48 pm Post subject: Re: mic lovin it , early 1964 bug project |
ran into a patch job and , some rust in the rear . theres no way I could leave that lol . so ….blue tape is where I cut . im trying to keep as much og metal as possible
Posted: Sat Jan 18, 2020 8:07 pm Post subject: Re: mic lovin it , early 1964 bug project |
moving to the rear
