casey79westfalia Samba Member
Posted: Sat Jan 18, 2020 9:06 am Post subject: Aux Battery Setup |
So I'm finalizing my aux battery setup and I really want to keep it fairly simple. Will probably add on to it as needed down the road. I am just using an isolator and not going to install the switch to jump start with the aux battery. I have small jump box in case I get stranded. I plan to tap/unhook the #3 (radio, interior lights, etc) from main fuse panel and tie those devices to the aux fuse panel. Still have to decide on my solar panel setup.
I tend to not use a ton of power when camping and I only fo for a couple days at a time so I am not looking to go overkill just enough to be off grid for a couple days at most. Any suggestions (wire sizes, fuses) to my setup or concerns Im all ears. Attached below are the items I am using.
Note: Ground Block will be ground to chassis! and inverter will most likely be 2-4awg wire.
Charger
https://www.amazon.com/dp/B00CBTRMZ4/?coliid=I3803..._lig_dp_it
Charging Relay
https://www.amazon.com/Blue-Sea-Systems-Automatc-C...amp;sr=8-2
Aux Battery
Renogy Deep Cycle AGM Battery 12 Volt 100Ah for RV, Solar Marine and Off-grid Applications https://www.amazon.com/dp/B075RFXHYK/ref=cm_sw_r_cp_api_i_nV5iEbBWWR1JC
Fuse Panel
https://www.amazon.com/dp/B001P6FTHC/?coliid=I3039..._lig_dp_it
Battery
https://www.amazon.com/Renogy-Battery-Marine-Off-g...amp;sr=8-2
Ground Block
https://www.amazon.com/Blue-Sea-Systems-Common-10-...amp;sr=8-1
Circuit Breakers
https://www.amazon.com/STETION-Resettable-Circuit-...amp;sr=8-4
Jump Start
https://www.amazon.com/Antigravity-Batteries-AG-XP...2341248951
Inverter
https://www.amazon.com/Renogy-1000W-120VAC-Inverte...amp;sr=8-5 _________________ 66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it"
Last edited by casey79westfalia on Sat Jan 18, 2020 5:01 pm; edited 1 time in total |
zimflux Samba Member
Posted: Sat Jan 18, 2020 9:28 am Post subject: Re: Aux Battery Setup |
Only since it wasn't mentioned.... Your current alternator, if it doesn't have an adjustable regulator, won't keep up with the required charging voltage for the AGM type battery. I assume from time to time you'll use the charger to top it off.
Use 4 gauge wire. Keep your runs as short as possible.
Curious what you're going to use the inverter for? Pretty much everything can be 12-volt nowadays.
Otherwise looks like a proper basic economical setup. 👍 _________________ 84 1.9 Westy |
Posted: Sat Jan 18, 2020 9:31 am Post subject: Re: Aux Battery Setup |
Quote: |
PostPosted: Today 8:28 am Post subject: Re: Aux Battery Setup
Otherwise looks like a proper basic economical setup. 👍 |
thanks! I am running a 1.8t conversion and I do have the upgraded 120 amp alternator. It does look like it has a voltage regulator built in from what I have read.
Inverter may not be installed initially. I agree I am going to see if it poses an issue down the rd and add it if needed. _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
"Do it the right way, or you'll pay for it" |
Timwhy Samba Member
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Sat Jan 18, 2020 11:31 am Post subject: Re: Aux Battery Setup |
This one always bothered me.
What happens if the genius charger and solar are both sending voltage to the AGM? Which device manages the AGM charging profile?
Here is a typical charge profile. I can’t figure how two independent devices can manage a single battery using a profile like this.
_________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3786 Location: VA/TN
Posted: Sat Jan 18, 2020 11:58 am Post subject: Re: Aux Battery Setup |
I never really thought of that RMCD.
In my case, my MPPT Victron should detect float state and cut off most of power to battery.
Also some of your wire looks too big - however it ultimately depends on length of cable. I use this calculator often
https://www.wirebarn.com/Wire-Calculator-_ep_41.html
Any 'source' of power should have a fuse inline to battery. Shore charger/solar charger. _________________ Brandon
Instagram @joannthevan |
jimf909 Samba Member
Posted: Sat Jan 18, 2020 1:14 pm Post subject: Re: Aux Battery Setup |
Timwhy wrote: |
I think I would add an On/Off switch for the ACR, as it is bidirectional. There may be times that you don't want to be charging both battery bank at the same time.
1000 watt inverter seems big, why all the wattage? |
Good point. The Blue Seas 7622 includes an on/off/auto switch function. But it's $100 more so a simple switch could at least handle the off function. The forced on function is nice to combine batteries regardless of voltage. _________________ - Jim
Abscate wrote: |
jocoman Samba Member
Joined: August 11, 2016 Posts: 425 Location: Ottawa, Canada
Posted: Sat Jan 18, 2020 1:53 pm Post subject: Re: Aux Battery Setup |
I'm thinking of something similar. Question...
Why does the fuse panel need to be grounded? doesn't it just distribute the 12 v to the accessories? _________________ '86 Westfalia 2.0L Zetec
'97 Volvo 850 AWD Turbo
" The fun never stops" |
Posted: Sat Jan 18, 2020 1:59 pm Post subject: Re: Aux Battery Setup |
jocoman wrote: |
Why does the fuse panel need to be grounded? doesn't it just distribute the 12 v to the accessories? |
It depends on the style of fuse panel. Some offer ground posts for the circuits, others don't. The way this is drawn it looks like the ground to the fuse panel is superfluous.
Alternatively, the OP could ground the fuse panel and run circuit grounds there too instead of the bus (no, I don't mean school bus, zeitgeist). _________________ - Jim
Abscate wrote: |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Sat Jan 18, 2020 2:53 pm Post subject: Re: Aux Battery Setup |
jocoman wrote: |
Question...
For use in marine applications. As a rule, boats have negative polarity wiring to match the positive. They are not grounded through a metal frame as terrestrial vehicles are. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1826 Location: Vancouver Island, BC
Posted: Sat Jan 18, 2020 3:31 pm Post subject: Re: Aux Battery Setup |
Hi
This caught my attention:
casey79westfalia wrote: |
I tend to not use a ton of power when camping and I only fo for a couple days at a time so I am not looking to go overkill just enough to be off grid for a couple days at most. |
You shouldn't need any solar then. Unless there's some heavy amperage equipment you need to run? The usual stuff doesn't require much (LEDs, music, phone charging...).
My advice would be to install your aux battery setup without solar first, see how it works for you (what's your aux battery voltage after 2 days, etc). Then you can decide if you need solar panels. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sat Jan 18, 2020 3:54 pm Post subject: Re: Aux Battery Setup |
Quote: |
Hi
My advice would be to install your aux battery setup without solar first, see how it works for you (what's your aux battery voltage after 2 days, etc). Then you can decide if you need solar panels. |
This is the plan! Then add solar and inverter and other items as I go! Thanks _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2779 Location: North Carolina
Posted: Sat Jan 18, 2020 5:38 pm Post subject: Re: Aux Battery Setup |
X2 on don’t need solar to be a weekender. Three years in, a (I know) gowesty kit continues to work great for 3 nights charging devices, using interior lights, and running a 12v fan for 8-10 hours a day.
That said, I’m adding solar now because Christmas and my family needed suggestions
So I like the staggered approach. Of course, you’ve already proven your patience in your build thread whixh, btw, is awesome. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Sat Jan 18, 2020 6:08 pm Post subject: Re: Aux Battery Setup |
A good electrical plan starts with an enumeration of all loads , current and time needed
Most weekender camping can be electrically served by the starter battery and single external jump pack as back up. _________________ .ssS! |
Posted: Sat Jan 18, 2020 6:35 pm Post subject: Re: Aux Battery Setup |
Thanks Guys. So here's the thing. I'm a weekend warrior right now! I do plan on doing a cross country trip in the coming year or so with my family. Currently I will be running the following on the aux.
Truckfridge T49
5kw Diesel heater (still researching what model to buy)
Interior Led Lights
Sink pump
Radio
USB ports for charging
Some 12v fans for hot days
That's really it for now!
If needs change I can always upgrade the 100ah battery and jump to a 200ah and add the solar. _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3424 Location: Dartmouth, Mass.
Posted: Sat Jan 18, 2020 8:23 pm Post subject: Re: Aux Battery Setup |
[quote="jimf909"]
jocoman wrote: |
Alternatively, the OP could ground the fuse panel and run circuit grounds there too instead of the bus (no, I don't mean school bus, zeitgeist). |
I have the same BlueSeas fuse block and my grounds are run to it, as you stated one could do above.
If I had a lot of feeds to the back of the van, I suppose running grounds to a
common grounding point back there would save wire and effort. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Sat Jan 18, 2020 8:26 pm Post subject: Re: Aux Battery Setup |
Depending on the size of the aux. battery the fridge and heater could push you into solar or run-the-motor for a while territory, e.g. if the aux batt is less than 100 ah and you run the heater all night or open the fridge and you head out for a three-day wknd, etc. _________________ - Jim
Abscate wrote: |
Posted: Sun Jan 19, 2020 7:45 am Post subject: Re: Aux Battery Setup |
Just thinking... but i read that agm batteries should not exceed a 40 amp charge.
Maybe the fuse on the agm battery should be 40 amps to prevent to much current presented to the AGM? _________________ '86 Westfalia 2.0L Zetec
Posted: Sun Jan 19, 2020 9:40 am Post subject: Re: Aux Battery Setup |
Maybe the fuse on the agm battery should be 40 amps to prevent to much current presented to the AGM? |
Good point, I checked the specs on my battery and it does say max charge is 40a. _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
fxr Samba Member
Joined: December 07, 2014 Posts: 2300 Location: Bay area CA
Posted: Sun Jan 19, 2020 5:54 pm Post subject: Re: Aux Battery Setup |
Truckfridge T49
Interior Led Lights
Sink pump
Radio
You will not need a 5kW diesel heater - a 2kW one will be perfectly adequate even at very low outside temps with the pop-top up! The 5kW ones do not go low enough to stop the temperature inside rising above normal levels - you'd have to open a window or other vent and keep adjusting that.
The cheapo Chinese diesel heaters work fine especially if you buy an Afterburner controller. _________________ Jim Crowther
Vespa GTS 300 |
