rsvp Samba Member
Joined: September 02, 2006 Posts: 162 Location: Annapolis, MD(but usually travelin' somewhere else)
Posted: Sun Jan 19, 2020 6:06 pm Post subject: Ouch! My (diesel injection pump) Nipple Broke!! |
Hi all
The nipple on the vacuum module on my JX injection pump broke off. What’s my best way of fixing this? (I’m thinking of J-B Weld, but not sure if it’ll hold.
Thanks again
Steve
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Sun Jan 19, 2020 6:17 pm Post subject: Re: OUCH! MY NIPPLE BROKE!! |
I would not trust JB Weld for that fix, not without reinforcement. Not familiar with the engine but have learned what JBW can't do.
I broke the nipple end off a fuel pump plastic piece and used tiny brass tubing as a sleeve JBWed on the inside, then wrapped the outside with fine mesh and slathered JBW on it. When dry I installed fuel line with a clamp but that piece is now my emergency spare that I hope will work properly if needed. _________________ '87 Westy in Wolfram Grey Metallic |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sun Jan 19, 2020 6:45 pm Post subject: Re: OUCH! MY NIPPLE BROKE!! |
campism wrote: |
I would not trust JB Weld for that fix, not without reinforcement. Not familiar with the engine but have learned what JBW can't do. |
I agree with campism.
That kinda looks soldered.
Is that possible?
Maybe it's silversolder?
I have a hard time believing an OEM would solder, but... _________________
....KTMs, GasGas, SPOT mtb |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10370 Location: Sunshine Coast B.C.
Posted: Sun Jan 19, 2020 6:49 pm Post subject: Re: OUCH! MY NIPPLE BROKE!! |
Cut new threads for a brake bleeder or other nipple?
I'd wonder how to keep metal shavings out from inside of that part though.
I agree. Looks like it might've been silver brazed.
1988 West DIY 50º ABA
VE7TBN |
Sodo Samba Member
Posted: Sun Jan 19, 2020 7:02 pm Post subject: Re: OUCH! MY NIPPLE BROKE!! |
Thread a brake nipple in, then JB-weld a big structural fillet all around the brake nipple?
Could put it right at center, then cover the original nipple hole with JBweld .
If that's a diaphagm, it probably wont be bothered by little bits from drilling & threading, and most might shake out..
Drilling thru the membrane would be detrimental.
JB weld can be done like this.
Epoxy a steel tube on, with a structural blob for "strain relief".
Maybe steel brake tubing (or copper tube)? _________________
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Sun Jan 19, 2020 7:06 pm Post subject: Re: OUCH! MY NIPPLE BROKE!! |
Recommend brazing if you can find someone willing to work on something that small.
Epoxies are not going to cut it. _________________ This free advice is worth exactly what you paid for it.
old_man Samba Member
Joined: June 19, 2018 Posts: 1381 Location: Newfoundland
Posted: Mon Jan 20, 2020 1:59 am Post subject: Re: Ouch! My Nipple Broke!! |
New one. Pricey.
My only suggestion is to keep in mind that the hose doesn't have to go to that exact spot. You could patch that hole and drill a cleaner hole elsewhere. That area shouldn't see more than 15psi. |
T3messie Samba Member
Joined: October 03, 2017 Posts: 209 Location: Germany
Posted: Mon Jan 20, 2020 4:32 am Post subject: Re: Ouch! My Nipple Broke!! |
Title is not very catchy to a diesel vanagon enthusiast .
Is the diaphragm intact? |
rsvp Samba Member
Posted: Mon Jan 20, 2020 6:35 am Post subject: Re: Ouch! My Nipple Broke!! |
Hi all,
Thanks for the ideas... I'll thread it for a brake bleeder nipple and see how that works.
Ill keep you appraised!
regards,
Steve |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1645 Location: Budapest Hungary, Europe
Posted: Tue Jan 21, 2020 1:28 am Post subject: Re: Ouch! My Nipple Broke!! |
its brazed (hard soldered) by factory _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
rsvp Samba Member
Posted: Tue Jan 21, 2020 5:07 am Post subject: Re: Ouch! My Nipple Broke!! |
NIPPLE FIXED!!
Thanks everyone
I ended up threading a brake bleeder nipple on, and sealing it with JB-Weld. It seems to be holding a vacuum when I pull it open by hand.
I’m not sure of the longevity of the repair, but we’ll see.
Thanks again,
Steve |
