vwfye Samba Member
Posted: Fri Jan 17, 2020 12:59 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
After 14 weeks of unemployment, I am employed again!
Now, I can get back to working on the swap. This has turned into a quagmire without the ability to fund anything... _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Jason37 Samba Member
Posted: Sun Jan 19, 2020 9:38 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Congrats on being back to work and can’t wait to see work commence! |
vwfye Samba Member
Posted: Tue Apr 07, 2020 4:49 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Starting to fit the NOS lid and seeing what needs tweaked. The old lid had 4 holes and bondo in it.
This lid was directed my way and is pretty straight, though it will still need body worked.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Wed Apr 08, 2020 10:43 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
Nice Brian. Sometimes I wish mine fit that good. I think they all get a little tweaked over the years. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Wed Apr 08, 2020 12:54 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Some of the gap appearing will be gone after adjustents. I currently have the hinges at the old lid position. I have some room to drop it a touch more. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Apr 16, 2020 3:46 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
No more wing evidence.
After all the handwringing to make the fender flare cuts, today it was fairly easy to change up the flares from just the rears to the full set.
vwfye Samba Member
Posted: Thu Apr 16, 2020 8:16 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Holes drilled and flares officially on.
Finally, it is a custom
Posted: Fri Apr 17, 2020 11:11 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
Looks like no trimming was required of the fenders, unless it was at the top of them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Qldelsie Samba Member
Joined: September 22, 2019 Posts: 518 Location: Queensland Australia
Posted: Fri Apr 17, 2020 5:05 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Do you have details / photos of where /how you mounted your roll bar and rear support bars ? Did you take the rear bars back to those rear chassis bolts ? I may be forced by the regulations to put one in if I do the Wild Alaska Rally in September 2022, so am looking for ideas while I have the car in pieces.
Thanks,
Giles |
vwfye Samba Member
Posted: Fri Apr 17, 2020 8:06 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Qldelsie wrote: |
Thanks,
Giles |
Cages tend to be sport specific. Hill climb cages are different than drag cages, for example. This car is very different since it is midengine. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat May 16, 2020 5:43 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Trying to decide if the nose should come down one more spline or not...
Posted: Sat May 16, 2020 6:16 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
Do you have all 4 on the ground in that pic? If so, then yes it needs another spline down. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Thu Jun 11, 2020 5:35 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
I swear, going from dual carbs to turbo was much quicker than going back to dual carbs. 😡
Next up is trying to get the new to me MSD style distributor wired in correctly as well as the shift light. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Jun 12, 2020 3:51 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Finally, all 4 corners on the ground and rolled out. Still not sure if it needs to go lower.
vwfye Samba Member
Posted: Fri Jun 12, 2020 7:22 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
New M/H rear tires and suspension changes...
Posted: Sat Jun 13, 2020 10:24 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
So, do you have the water cooled engine in it now? Or did you build another engine for it?
The drop looks ok to me. Almost just about right. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Jun 13, 2020 3:19 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Still building the vr6 turbo. The sweep the floor engine is in there with dual carbs for now. Just hoping to make a pass in a couple weeks _________________ 64 No'back Speedster "Pearl"
Posted: Sat Jun 13, 2020 5:35 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
Still building the vr6 turbo. The sweep the floor engine is in there with dual carbs for now. Just hoping to make a pass in a couple weeks |
Cool. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Mon Jun 15, 2020 4:37 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Oil in the engine. Testing fuel system tomorrow and then turning the key. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Jun 16, 2020 2:46 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
It's alive! Now... tuning the new carbs, running the valves and trying to get the tach and shift light to share a signal. _________________ 64 No'back Speedster "Pearl"
