dhaavers Samba Member
Joined: March 19, 2010 Posts: 7753 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Mar 16, 2019 12:41 pm Post subject: rain gutter / side mount for traction mats? |
OK...over the years I've only seen maybe one thread about side mounting anything (skis/boards as I recall) so I'm looking
for experience/details/tips/tricks as I start a similar project...
My application will be for a pair of CCTM's (Cheap Chinese Traction Mats) hanging from the rain gutter. Starting with $25
of bombproof eBay mounts (seller lists $60/set of 6; I got just 2 for $25):
Mounts: https://www.ebay.com/itm/UNIVERSAL-GUTTER-ROOF-RAC...2749.l2649
I like them a lot - they're VERY sturdy, mount up perfectly & well clear of the poptop. I'll strap mount the mats only when
I need them & add a security cable through the holes as backup in case of strap failure &/or temptation minimizer:
In this mock-up the mats are still pretty loose/floppy, so further plans include:
- hang a "J" bracket below the mounts for holding mats in place while strapping in,
- light cross-bracing to secure entire structure as a unit (which I suppose you'd call a "rack"...???),
- rubber padding where rack may contact sheet metal & to keep ANYTHING from contacting glass...
- "quality" rattle-can paint job all around...basic black.
I'm not a welder, so I'll be using probably 5/16 bolts & locking nuts. I figure the J-hook will be ~2" flat with a slot for the strap
at the bottom & the cross bracing will be small (maybe 1/2"?) angle stock. The mats weigh barely 11lbs, FWIW.
As mentioned, let me know if I'm really way off base with this...experience /tips /tricks /pointers /etc. greatly appreciated!
CCTM info/not directly mount related...
FWIW: I picked up the mats just recently on sale... just $57/pair ...after seeing them very well reviewed on YT:
eBay link, FWIW: https://www.ebay.com/itm/2X-Recovery-Traction-Sand...2749.l2649
Good enough for me...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Sat Mar 16, 2019 12:43 pm Post subject: Re: rain gutter / side mount for traction mats? |
Nice! I am contemplating doing the same thing. Perfect timing and thanks for sharing |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4765 Location: Bemidji, MN
Posted: Sat Mar 16, 2019 1:39 pm Post subject: Re: rain gutter / side mount for traction mats? |
consider a suction mount on the glass to keep the mats from lifting at speed, and it would prevent banging. doesn't need to be weight bearing, just resist a pulling force.
https://www.amazon.com/ABN-Double-Suction-Windshie...&psc=1
those gutter mounts would be useful for carrying a variety of rilly long objects and have strength as long as the load can be inline directly below the mount or stopped from leveraging by the body/glass.
i've been stuck so many times this year snowplowing i'm looking at carrying mats in the truck. but i need something that can dip down into a hole created by a tire in snow. _________________ -dan
www.thefixitworkshop.com |
E1 Samba Member
Joined: January 21, 2013 Posts: 6528 Location: Westfalia, Earth
Posted: Sat Mar 16, 2019 5:43 pm Post subject: Re: rain gutter / side mount for traction mats? |
Cool, Dave!
Our sand ladders need a new spot, too. I'm leaning towards just forward of the vent, atop two to four stock cleats or similar, or at the very rear. To now they've always lived cozily in the luggage rack.
Tilt ladders forward for better front-end grip, or back for better liftoffs.
( ) _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Sat Mar 16, 2019 6:44 pm Post subject: Re: rain gutter / side mount for traction mats? |
Thanks for the chatter, all y'all...
I really like the secure suction cup idea...I'll be working on that!
I settled on the side mount because in road trip mode our luggage rack is already full (propane grill,
camp chairs, spare gas) so I didn't want to try to cram the mats up top, plus I figure it'll be much
easier to unstrap from near ground level when the mats are actually needed...
Yeah, if I had the budget I'd spring for a system like the CVC blokes, but like I've said before:
...I'm CHEAP!
Updates to follow...
"The WonderVan"
Posted: Sun Mar 17, 2019 6:03 pm Post subject: Re: rain gutter / side mount for traction mats? |
Squeezed in a little time this afternoon...current mock up on the first side:
Rubber pads hold it all away from the window & the suction cup (when it arrives) will hold it down in place.
Currently sits about 1" clear of all sheet metal & glass. All about harmony...balance...yin/yang...whatever...
As always, comments welcome...
"The WonderVan"
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Sun Mar 17, 2019 8:02 pm Post subject: Re: rain gutter / side mount for traction mats? |
Think you could rig something up to connect to those mounts to do like a surfboard rack? |
Posted: Sun Mar 17, 2019 8:46 pm Post subject: Re: rain gutter / side mount for traction mats? |
^^^ The mounts are very sturdy & it shouldn't be any harder than what I'm doing...I say go for it!
"The WonderVan"
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Mon Mar 18, 2019 11:59 pm Post subject: Re: rain gutter / side mount for traction mats? |
Cool idea! How thick are those traction mats stacked? |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Tue Mar 19, 2019 1:02 am Post subject: Re: rain gutter / side mount for traction mats? |
Ive seen a number of vans with the rear drivers side window removed and replaced with some panel. Not sure if its glass or metal or plastic. That window serves as no good to me, in fact its a bit of a nuisance at times.
That panel would provide a lot of use as a mounting board. Definitely don't want to hijack the thread so Ill look around. Interested in knowing how that's done (replacing the window). Might be an option for you too. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Tue Mar 19, 2019 4:30 am Post subject: Re: rain gutter / side mount for traction mats? |
My Chinese mats measure up at 4" stacked (2 mats)...in comparison, the brand name looks to be about 2-1/2" or so...???
That's OK for me - I'm not a hardcore offroader, I just want these along for insurance once in a while...
I considered mounting on the back hatch but didn't really want to add the weight there, plus the side mount is
always easily accessible, plus didn't want to cover any more window than necessary (we like windows! ),
plus I'm cheap and didn't want to spring for a whole window-out replacement-panel mod, so here we go.
Would be great to see these other ideas...post 'em up!
"The WonderVan"
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Tue Mar 19, 2019 5:00 am Post subject: Re: rain gutter / side mount for traction mats? |
These gutter mounts I would prefer them to have a wider base. You say they work so that's good. Is there any rubber cushion under the feet to protect the base paint? _________________ This free advice is worth exactly what you paid for it.
Posted: Tue Mar 19, 2019 3:33 pm Post subject: Re: rain gutter / side mount for traction mats? |
You could easily flip over the tall part & have the wider end in the gutter, just need to drill a new hole for the clamp bolt.
I used some cheap edge trim to cushion the parts that touch the paint:
https://www.amazon.com/dp/B01BKSGVWG/ref=twister_B00N9VG9WK?_encoding=UTF8&psc=1
"The WonderVan"
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Fri Jan 24, 2020 4:23 pm Post subject: Re: rain gutter / side mount for traction mats? |
this llooks great!
I'm looking for some way to carry skis, and I like the idea of right alongside the van. I like where you are going with this - please post more pics.
Am I correct in saying you have not put any holes in the body? It is a little hard to tell from the photos. _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
izzydog Samba Member
Posted: Fri Jan 24, 2020 7:04 pm Post subject: Re: rain gutter / side mount for traction mats? |
AZ Landshaper wrote: |
Ive seen a number of vans with the rear drivers side window removed and replaced with some panel. Not sure if its glass or metal or plastic. |
It would be pretty easy to remove that window, trace the shape on aluminum of the same thickness and then mount the tracks to that. You could even spruce it up with a few cans of custom-match paint and match your van color to give it that panel-van look. |
elizer Samba Member
Joined: May 02, 2016 Posts: 1461 Location: Northern Virginia
Posted: Fri Jan 24, 2020 7:30 pm Post subject: Re: rain gutter / side mount for traction mats? |
izzydog wrote: |
Put on the tires and use the maxtraxx spare tire mount. I think it will work with the chinese ones too because it doesnt use the mounting pins.
https://www.vanagonlife.com/vanagonshop/rearvowL |
Posted: Fri Jan 24, 2020 10:20 pm Post subject: Re: rain gutter / side mount for traction mats? |
^^^ Bad link...
FIFY: khttps://www.vanagonlife.com/vanagonshop/rearvow
"The WonderVan"
elizer Samba Member
Posted: Fri Jan 24, 2020 10:25 pm Post subject: Re: rain gutter / side mount for traction mats? |
I dont know how internet |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
