Jeler Samba Member
Posted: Wed Jan 22, 2020 9:03 pm Post subject: Re: Official good deal on Buses or parts topic |
Just purchased my first '66 13 window today via an auction here in Iowa.
Fresh paint, orig. seats, headliner, engine, etc. but does need some TLC.
Ecstatic with my purchase and can't wait to get into the shop and start work on it
Looking forward to advise from my newly found board, packed with more information than I can fathom.
Jeff In Iowa
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Thu Jan 23, 2020 5:04 am Post subject: Re: '66 13-Window in Iowa |
It looks great, especially for that part of the country. Any history on it?
Take and post some pics of the underneath, engine, etc etc. if you'd be so kind. |
volkswagen60 Samba Member
Posted: Thu Jan 23, 2020 8:07 am Post subject: Re: '66 13-Window in Iowa |
Congrats! I have a 66 too. I have less windows and trim Nice score!
Curious what the OG color was?
Looking forward to your updates! _________________ http://www.vw-trader.com |
Jeler Samba Member
Posted: Thu Jan 23, 2020 12:26 pm Post subject: Re: '66 13-Window in Iowa |
Thanks, I'm happy with the purchase. You just don't run across these at all in Iowa, unless they are made up of 90% rust.
It's getting delivered to us on Saturday.
Here are a few more photos.
Thanks again for allowing to share this info with you.
Jeff
Jeler Samba Member
Posted: Thu Jan 23, 2020 12:27 pm Post subject: Re: '66 13-Window in Iowa |
Jeler Samba Member
Posted: Fri Jan 24, 2020 5:31 pm Post subject: Re: '66 13-Window in Iowa |
Bus get delivered tomorrow morning and no doubt spend the rest of the day investigating what I actually got for my $. I'll spend some time and decipher
the VIN tag.
Jeff |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Fri Jan 24, 2020 6:53 pm Post subject: Re: '66 13-Window in Iowa |
volkswagen60 wrote: |
Looking forward to your updates! |
43 44 70 makes for titian red, beige gray, and mesh platinum / platinum silver upholstery. _________________ regards
Uli
Jeler Samba Member
Posted: Fri Jan 24, 2020 8:03 pm Post subject: Re: '66 13-Window in Iowa |
ManDrake
Excellent, you just saved me alot of time trying to decipher this ViN.
I did find out that 430 is a "North American Package"
025 is "Seat Belt Mount Sockets"
130 is "No sunroof or skylight windows"
Also discovered that the "UT" is "Shipped to Tourist Delivery Program"
Thanks again and have a great weekend.
Jeff |
Jeler Samba Member
Posted: Sat Jan 25, 2020 4:15 pm Post subject: Re: '66 13-Window in Iowa |
Bus was delivered this morning on a flat bed truck, sure glad I didn't use a trailer with our gravel roads like a skating rink along with hills.
Installed a new battery, 12V. I assume the previous owner converted it to 12 V even though one of the tail lights had a 6V bulb? Had to remove the tail light to exchange batteries. Has me a bit concerned using a 12V battery after I thought about it for a bit. I have no idea at this point even what to look for. Alternator/generator/regulator/condenser?
Well it turned over fine but with fresh fuel in the tank and the use of some starting fluid not a "pop" was heard from the engine wanting to start. Tomorrow I'll see if I'm even getting spark.
Regards
Jeff
Posted: Sat Jan 25, 2020 5:24 pm Post subject: Re: '66 13-Window in Iowa |
I would peek at the top of the generator just in case.
There are a bunch of numbers on top near the fan shroud and it will say 7v (6-volt unit) or 14v (12-volt unit) on there.
If it's hard to see, get a little mirror.
If it's dirty, get some steel wool to scrub on it a little
Example
_________________ How to Post Photos
Jeler wrote: |
Regards
Jeff |
pretty sure your heater element on the right hand side of your carb will say the voltage.
the generator maybe difficult to check. Check some other bulbs, but in general i would assume a 66 is 12volt. _________________ regards
Uli
Jeler Samba Member
Posted: Sun Jan 26, 2020 7:06 am Post subject: Re: '66 13-Window in Iowa |
Mandraks
Awesome, thanks. The heating element in fact is a 12 Volt.
Jeff |
Jeler Samba Member
Posted: Sun Jan 26, 2020 7:10 am Post subject: Re: '66 13-Window in Iowa |
EverettB wrote: |
If it's dirty, get some steel wool to scrub on it a little |
Got the back of the Generator brushed off and will try to clean it up a bit more.
Difficult to see, but a mirror helps. I think I saw a 14 V, but I'll need to study it a bit more. Reading upside down numbers is not my forte. Thanks again |
zozo Samba Member
Posted: Sun Jan 26, 2020 7:32 am Post subject: Re: '66 13-Window in Iowa |
Sometimes it’s easier to stick your phone in there and take a pic, rather than craning your neck. |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Sun Jan 26, 2020 9:52 am Post subject: Re: '66 13-Window in Iowa |
"If" some previous owner converted that '66 from 6 volt to 12 volt, you might want to check all the electrical consuming devices to be sure they have already been changed to 12 volt items (every light bulb everywhere on the Bus), horn, generator with (matching amperage) voltage regulator, under-dash light and emergency relays, starter and solenoid, etc. If it was me, I'd make a "buy list" of every bulb and get all brand new ones and keep the good used ones as back-up spares.
As for starting that engine up, move the Bus outside, get a fresh fire extinguisher or two and have 'em handy next to the engine compartment, and know how to use them. Hopefully you will never need to. Then check condition of your oil (is it super old and dirty or clean?) and proper oil level. The condition of your fuel pump (looks like a good German one!) is unknown and may not be pumping any or enough fuel up to the carb. Hopefully your ignition system (gets power, a properly timed distributor and properly gaped points, provides a good spark to the plugs, and good functioning spark plug wires) is ready and functional. Test by getting everything ready to start and then while someone else cranks the engine over, slowly pour about a teaspoon or so of fresh fuel down the neck of the carb. If it fires up and runs and then dies after consuming the fuel, your fuel pump might be bad (usually a stiff pump diaphragm, no worries - it can be rebuilt) or a fuel line may be clogged, or the tank may be clogged with sediment/gunk at it's outlet on the bottom of the tank. Carb might need a rebuild... A lotta maybe's. Have fun and good luck!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Jeler Samba Member
Posted: Sun Jan 26, 2020 10:49 am Post subject: Re: '66 13-Window in Iowa |
zozo wrote: |
Excellent suggestions. Worked great and discovered it's 14V
Thanks
Jeff |
Jeler Samba Member
Posted: Sun Jan 26, 2020 10:56 am Post subject: Re: '66 13-Window in Iowa |
BulliBill wrote: |
Bill |
Very useful information. So far I've discovered the generator is 14V and the heating element on the right side of the carb is 12V. From everything I've read VW didn't switch over to 12V until '67, but I guess there's always mid-year changes. But i'll start making my list of things to check. Can't see any numbers of the wiper motor yet.
Will definitely be pushing the bus outside to attempt starting it. Just discovered
I'm not getting any spark to the plugs. Carb cleaning and checking out the fuel pump is a great idea.
Thank you
Jeff |
Posted: Sun Jan 26, 2020 11:28 am Post subject: Re: '66 13-Window in Iowa |
If you are handy and a bit mechanical, and have basic tools you can tune it up and perhaps rebuild the carb and fuel pump with rebuild kits from Wolfsburg West ( www.WolfsburgWest.com ). But there are a couple of guys here on TheSamba.com with very speciallized tools, parts and most importantly superior restoration skills who can restore your German carb and fuel pump and distributor to basically new condition for a fee of course. Take a stab at it if you are comfortable and then fall back on the experts if needed. Pretty soon that engine will be purring away in your driveway!
Check the transaxle too to be sure you have enough gear oil in your transaxle before you take off driving that Bus.
Jeler Samba Member
Posted: Sun Jan 26, 2020 6:22 pm Post subject: Re: '66 13-Window in Iowa |
BulliBill wrote: |
Bill Bowman |
Bill, I sure hope you're right about the "Purring"! Just wrapping up a complete tear down and restoration of a '48 Chevy 1/2 ton, so I am some what mechanically inclined. Right now I just want to get it running so
we can move it around if need be. Complete restoration will take place once
the truck is done (at least that's what I'm telling my very understanding wife). I'll go done thru your list of items to check out and have the fire extinguisher handy. No spark today, and tomorrow I'm going to run some more test with a long wire, alligator clips and a light bulb so as I crank it over I can test what;s going on. One man shop here and wife still works. In time I'm sure I can figure it all out.
thanks again
Jeff |
