dobryan Samba Member
Joined: March 24, 2006 Posts: 12992 Location: Brookeville, MD
riceye Samba Member
Joined: March 09, 2006 Posts: 1554 Location: Caledonia, WI
Posted: Thu Jan 16, 2020 1:10 pm Post subject: Re: What did YOU do to your van today? |
campism wrote: |
campism wrote: |
If I tried that it'd be valuable chassis parts on both vehicles or something even more costly and troublesome. |
Sonofabitch. It worked.
Hooray, and props to 4Gears4Tires for the idea, and remember what Hillary says: "It takes a Mopar minivan to fix a Vanagon." |
This made me laugh really hard. Thanks, and congrats on your success. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
4Gears4Tires Samba Member
Posted: Thu Jan 16, 2020 3:55 pm Post subject: Re: What did YOU do to your van today? |
Necessity is the mother of invention. I'm glad it worked out for you.
Jake: My handbrake does work, the rock was there so the car didn't roll back any and lose tension on the rope. If the rope lost tension it would have slid off the rachet. That happened once before, so I put a rock behind the tire and rewrapped the rope. _________________ '87 Syncro
campism Samba Member
Joined: September 07, 2007 Posts: 3861 Location: Richmond VA
Posted: Thu Jan 16, 2020 4:34 pm Post subject: Re: What did YOU do to your van today? |
dobryan wrote: |
Good thing you got it out on the bus. If you remove the cat it is a b!tch to find something that can hold it stable enough while you try to remove the sensor. BTDT.
Not sure if you tried but heat is your friend in this case. |
I only have propane, which is generally not enough heat.
I had a plan (my wife hates to hear me say that) for the extraction once the cat was out. Bolt one end of the cat to a 12' long 2x6 standing on edge, and do the same with the other end so the boards are lying parallel on the ground with the cat in the middle. Then have a volunteer (that same wife, maybe?) stand strategically as ballast...er, as shapely and attractive force multiplier, while the brilliant wrench person with monster cheater pipe makes the attempt.
Same principle as when working on my steering rack; bolt the workpiece to a long piece of lumber for leverage, or for resistance to leverage.
_________________ '87 Westy in Wolfram Grey Metallic |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5561 Location: Crescent Beach, BC
Posted: Fri Jan 17, 2020 8:01 am Post subject: Re: What did YOU do to your van today? |
4Gears4Tires wrote: |
Jake: My handbrake does work, the rock was there so the car didn't roll back any and lose tension on the rope. If the rope lost tension it would have slid off the rachet. That happened once before, so I put a rock behind the tire and rewrapped the rope. |
Ah-ha! I'm glad it worked for you. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Vanlife Geek Samba Member
Posted: Sun Jan 19, 2020 11:57 am Post subject: Re: What did YOU do to your van today? |
I stuck this on the side of my Syncro.
_________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era) |
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 339 Location: Atlanta, GA USA
Posted: Sun Jan 19, 2020 8:26 pm Post subject: Re: What did YOU do to your van today? |
Had to do an emergency clutch slave bleed after a quick lunch run. To be followed, no doubt, by some quality time with the master cylinder. Apparently there is a small leak somewhere that was letting air in the clutch hydraulic system and I lost pedal over the course of a few miles. Made it back - barely.
The problem for me was that we were at our place up in North Georgia and I didn't have my bleed set-up handy nor could I find any suitable tubing to do a proper bleed (I do carry a small bottle of brake fluid though). Fortunately my awesome neighbor happened to have a couple of feet of small diameter (1/4"?) clear tubing laying around and I was able to get the air out of the line and restore clutchage - at least for the trip home. I had not thought of just how critical a small bit of tubing could be, so this is now a part of my emergency kit along with the gazillion other spare parts I lug around. It's always what you don't have that you need. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown |
westydriver Samba Member
Joined: July 08, 2017 Posts: 54 Location: Eastside of Nebraska
Posted: Mon Jan 20, 2020 7:57 pm Post subject: Re: What did YOU do to your van today? |
Set up my Blue Seas ACR to finally get my starter battery off of the plug in trickle charger and allowing that glorious sun to charge my whole setup. Excited to hook it all up tomorrow. |
JFK Samba Member
Posted: Wed Jan 22, 2020 6:26 pm Post subject: Re: What did YOU do to your van today? |
Made some curtains that snap-in.
Posted: Wed Jan 22, 2020 7:48 pm Post subject: Re: What did YOU do to your van today? |
epbiggs wrote: |
I stuck this on the side of my Syncro. |
What interesting timing. We parked next to a Ford 150 at Multnomah Falls, OR with the Overland Bound emblem just 2 days ago and it really piqued my interest. I wondered what it meant and then promptly forgot about it. Thank you for reminding me! _________________ '87 Syncro
jlrftype7 Samba Member
Posted: Wed Jan 22, 2020 10:25 pm Post subject: Re: What did YOU do to your van today? |
JFK wrote: |
Welcome to The Samba....
And a 2nd welcome for a fellow Chicago Owner( Vanagons are scarce around here... )
although you do have that For Sale Ad over in the Classifieds, so is selling the Vanagon still an active thing for you? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
‘84 Tin Top - Hilga....Auto |
JFK Samba Member
Posted: Thu Jan 23, 2020 9:54 am Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
although you do have that For Sale Ad over in the Classifieds, so is selling the Vanagon still an active thing for you? |
Yeah. It is becoming more difficult to have 2 cars in the city as a student and I am likely moving in a few months. And I would really like to have a manual over my automatic.
So if you know anybody looking for one, PM me |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 2954 Location: United States, Iowa
Posted: Fri Jan 24, 2020 8:36 am Post subject: Re: What did YOU do to your van today? |
Its been a week of not much work on the Westy .. there was a fire I had to deal with, luckily no VWs were damaged in the fire. Easy to find pictures if you want, search 'southbear fire' on that fund site if interested.
I've been driving my Westy and sleeping in it when I can, but finally was able to get a look underneith to locate the source of an annoying coolant leak. This is a pic of the T-Stat housing, with the clearly splitting hose on the left of the photo (pic taken from below the #3 exhaust runner). I believe that this is the hose that runs across to the distribution tower. I have had the entire coolant hose kit in my RMW 'cart' for a couple weeks, and had not yet clicked check-out, and now I don't see the future very well, so I am going to just try replacing this hose, and cleaning up and seeing if the wetness and drips can be contained for a little longer, with patchwork replacement.
Can anyone verify this splitting hose is Thermostat to Tower: https://www.vancafe.com/251121058A-p/251121058a.htm
_________________ '87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Jan 24, 2020 4:07 pm Post subject: Re: What did YOU do to your van today? |
The replacement oxygen sensor for the catalytic converter arrived a couple of days ago and today I got around to installing it. Those 3-wire Bosch sensors seem to be about $90 from most vendors so I tried Advance Auto online since they offered 20% discount and free shipping (slooooow, as it turned out). Took five days to arrive from Ohio, but that's what they predicted so I can't really complain. Family illness and cold weather made me not want to work on the van anyway.
But temps hit the 50s today so I popped it in (using my new socket and plenty of anti-seize), hooked up the wires and went for a spin. Thirty or so miles and nary a hiccup, and the tuneup parts I'd already thrown at it made it even smoother; ran like a dollar watch, as my old pappy would have said. Looks like it's fixed and we rolled over 94,000 during the ride.
Now on to the other stuff it needs. Thanks for the advice and encouragement! _________________ '87 Westy in Wolfram Grey Metallic |
Posted: Fri Jan 24, 2020 9:21 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
Do I see coolant at the area next to the blue connector, like a drop or two? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sat Jan 25, 2020 9:03 am Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
Do I see coolant at the area next to the blue connector, like a drop or two? |
Yes, and if you keep looking, you'll see it's wet everywhere.. cold weather is hard on rubber and shyt clamps.. _________________ '87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Sat Jan 25, 2020 3:02 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
jlrftype7 wrote: |
Yes, and if you keep looking, you'll see it's wet everywhere.. cold weather is hard on rubber and shyt clamps.. |
Since I don't have the 2.1 with that sensor, is it the type that goes into a hole and seals with a couple of O-rings or even 1 O-ring on the sensor body against the bore/hole of the housing?
If so, don't feel bad, I've always seen that type of coolant sensor leak in cold weather compared to other styles on multiple vehicles that use that design of a sensor and its feeble sealing. If you just bump the wiring to the sensor or the sensor itself, they can start leaking like that- Not a gusher, just a slowwww drip or weep....
On certain Land Rovers that use that same set-up, people through they got clever by replacing just the O-rings on the sensor once they had sized them out correctly. Then the plastic bore or hole of the sensor mounting would warp on them later on with continued use, and they needed the whole housing... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
BCE56 Samba Member
Posted: Sat Jan 25, 2020 3:27 pm Post subject: Re: What did YOU do to your van today? |
JFK wrote:
Quote: |
Made some curtains that snap-in. |
I did something similar. Curtains are made of USMC desert digital cloth and backed with fleece blanket material for added insulation. (Thanks, Mom!)
I leave them off the rear and slider windows when driving, they can be attached in a jiffy when necessary. Pretty happy with this setup.
_________________ =BCE56=
'86 Syncro tintop
OBD II Frankenmotor
Early SC adapter plate conversion
SC header, 3-way cat, VW muff.
stock springs, OME shocks*
VC, rear locker**
215-75 BFG AT/TAs on Rhein rims
*OMEs a bit too stiff in front, OK in rear or on heavier vans. Will try Bilsteins. Someday.
**PO installed taller top gear before Subie install. Not recommended. |
Posted: Sat Jan 25, 2020 3:54 pm Post subject: Re: What did YOU do to your van today? |
Started on my spring spacer project to cure the Westy lean. Once I knew the specs I searched for a board that would give me enough material and found one at W*****t for about $12. Used a jigsaw to cut them out and a hole saw for the center holes. Pieces are 5/16" thick so I made three to go on the left-rear, which is about an inch lower than the other corners. I'll tweak as required and have enough material for two more spacers if I need them. Might get them installed tomorrow.
Russpauly Samba Member
Joined: January 13, 2019 Posts: 125 Location: San Diego
Posted: Sat Jan 25, 2020 5:15 pm Post subject: Re: What did YOU do to your van today? |
campism wrote: |
Nice, I see what you did there. _________________ 1988 Wolfsburg Edition - TinTop
2.1L Watercooled
The Space man Van |
