swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Sat Jan 25, 2020 12:40 pm Post subject: Re: My new 71 Super |
Got some parts for the Super today. Friend Dustin gave me the tail light housing to replace the rusty one, and I happened to come across a really cheap set of Civic seats on Facebook marketplace. The prelude seats I got earlier got ruined by my wife’s cat peeing on them. These look like they’ll fit pretty nicely.
_________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
vamram Samba Member
Posted: Sat Jan 25, 2020 1:19 pm Post subject: Re: My new 71 Super |
Can you document how you mount those seats? Will they slide back & forth? They look like they sit low. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sat Jan 25, 2020 3:11 pm Post subject: Re: My new 71 Super |
vamram wrote: |
Can you document how you mount those seats? Will they slide back & forth? They look like they sit low. |
Sure can. Preliminary plan is to weld the bottom part of the old VW seat to the new Honda seat and the way it’ll use the stock VW track and be completely reversible. Did the same thing on my wife’s Thing.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100 _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Sun Jan 26, 2020 6:24 pm Post subject: Re: My new 71 Super |
Got some more paint off of the Super today. Took the guts out of the door and sanded the rest of it too.
My Patina 66
My 74 Ghia
07 Boxster |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Mon Jan 27, 2020 6:32 am Post subject: Re: My new 71 Super |
What colour are you painting this beast? _________________ "Albatross"! |
Posted: Mon Jan 27, 2020 7:13 am Post subject: Re: My new 71 Super |
calvinater wrote: |
What colour are you painting this beast? |
Orange, and most likely either the clementine it was originally or something really close to it. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
AlmostHeavenWV_VW Samba Member
Posted: Mon Jan 27, 2020 8:12 pm Post subject: Re: My new 71 Super |
Good to see another WV VW getting love and attention!
Making good progress mountaineer! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Tue Jan 28, 2020 5:47 pm Post subject: Re: My new 71 Super |
AlmostHeavenWV_VW wrote: |
Making good progress mountaineer! |
What part of the state are you in? _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
talljordan Samba Member
Joined: January 10, 2012 Posts: 967 Location: San Francisco, CA
Posted: Wed Jan 29, 2020 4:49 pm Post subject: Re: My new 71 Super |
What method are you using to strip the paint? _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Wed Jan 29, 2020 5:43 pm Post subject: Re: My new 71 Super |
talljordan wrote: |
What method are you using to strip the paint? |
I’m using a dual action sander and I’ve been through about 90 sheets of 80 grit peal and stick paper. In some of the corners and along the edges I’ve been using a wire wheel on grinder. Once I get all the flat areas sanded I’m going to drag it out to the driveway and media blast the hard to get to areas.
That being said, I started on the passenger door.
My Patina 66
My 74 Ghia
07 Boxster |
41mb04tj Samba Member
Joined: January 28, 2020 Posts: 7 Location: Marin County, CA
Posted: Thu Jan 30, 2020 10:27 pm Post subject: Re: My new 71 Super |
Nice progression on the work, I might be following suit in my near future... I will keep following your posts. |
Posted: Fri Jan 31, 2020 5:58 am Post subject: Re: My new 71 Super |
What are you doing to prevent flash rust? _________________ "Albatross"! |
Posted: Fri Jan 31, 2020 6:27 am Post subject: Re: My new 71 Super |
I’m about to epoxy primer the whole car. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Fri Jan 31, 2020 6:58 am Post subject: Re: My new 71 Super |
Great, lets see some pics of prep and paint , thanks and good luck. _________________ "Albatross"! |
Posted: Sun Feb 02, 2020 4:10 pm Post subject: Re: My new 71 Super |
Got some pre Super Bowl work done on the Super today.
Got the passenger door stripped. Found a small rust spot on the inside of the door which I welded shut. Took the old one of the car and fitted up the new door. Almost got all the old paint off that I can get off with a sander. Going to have to drag it out into the driveway and blast the inside of it, as well as all the corners and edges.
When I was done I started assembling my new planishing hammer and the stand I’m making for it. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Sun Feb 09, 2020 6:51 pm Post subject: Re: My new 71 Super |
Welds need some help, but that was my day. Floated some of the dents out of 3 of the 3 fenders. Welded up the crack at the bottom of the drivers rear fender. Now I need to finish shaping it. Then I decided to start on the dash. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4416 Location: Stuck in Ohio
Posted: Tue Feb 11, 2020 5:47 am Post subject: Re: My new 71 Super |
Buggeee wrote: |
That fender found its memory nicely.
I like metal dash idea. Are you going too keep that super cool steering wheel? It has a fascinating shape and will make a good centerpiece. |
Yep. Bought the wheel just for the car. Had one back in the 90s on my last 71 Super. Loved it so much when I got this car I searched out a good used one. It’s a Formuling Futura. Kinda of rare being a 3 spoke. Most Formuling wheels are 4 spokes. They also haven’t made them in about 20 years. Shame, they’re very high quality. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Sat Apr 25, 2020 4:26 pm Post subject: Re: My new 71 Super |
Been too long since I posted an update. I worked on the dash a little more, and had been blasting the inner fenders. I realized it was going to take forever so I just called in the mobile blast guy. He came out today.
My Patina 66
My 74 Ghia
07 Boxster |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
