Stumbled upon a syncro in bad shape, what parts to keep?
westfalia-jx-1988
westfalia-jx-1988 is offline
PostPosted: Sun Jan 05, 2020 2:02 pm    Post subject: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Hi
Plan is to part out a 1988 syncro 1,6 td
What is a must have, what do I keep?
It's more a save parts for the future for others with a syncro, instead of seeing everything being crushed. Shocked
I have a 2wd 1,6td myself, so I see the value in that engine Smile
Thank you
4mymalamute
4mymalamute is offline
PostPosted: Sun Jan 05, 2020 2:19 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
If it has a locker, save it and any of the associated parts. Transmission would be good to pull and save as well.
SIDE note...if it does have a locker....and you want to sell it, LET me know. Very Happy
1989 Sally the Syncro.....she is a work in progress. 1.8T and tuned...she scoots up the hills...watch for flying dog drool out the windows.
1969 Bucky the Bug Convertible...red, rusted, work in progress....LOTS of work.
ledogboy Premium Member
ledogboy is offline
PostPosted: Sun Jan 05, 2020 2:40 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Transmission, entire front cradle/suspension, front diff, driveshaft, VC, syncro gas tank and fuel filler, and the locking diff panel and associated vacuum assemblies. These parts are only getting more rare, so please either save them, or if it is beyond your capabilities to do so, pass the project on- many people want these parts! Best of luck!
1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice...
Kombi///M3
Kombi///M3 is offline
PostPosted: Sun Jan 05, 2020 3:35 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Don’t forget the gauges cluster.. the Speedometer is what
You need. And all the front suspension.
Pics?
levi
levi is offline
PostPosted: Sun Jan 05, 2020 3:45 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
What part of Europe are you in
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
vanagonjr
vanagonjr is offline
PostPosted: Sun Jan 05, 2020 7:54 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
and there's one under chassis piece unique to a Syncro that should be cut out to go with all the above.
SyncroHead Premium Member
SyncroHead is offline
PostPosted: Sun Jan 05, 2020 8:56 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Get these too:
- Steering rack mounting assembly - a pain to cut out, but a conversion will need it.
- Syncro driveshaft protection bars AND cut out the mounting brackets from the body.
- Rear body area around the fuel filler. I cut out almost the whole corner of the van from the window down, but you probably won't need more than 200mm around the filler area in any direction.
Jim
"A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote:
I have *no* idea what the previous owner carried in his Westy... angry donkeys?
Steve M.
Steve M. is offline
PostPosted: Sun Jan 05, 2020 9:43 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Define "Bad Shape"!
westfalia-jx-1988
PostPosted: Mon Jan 06, 2020 1:58 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Hopefully it has Smile
Thank you Smile
Pics?
I plan to see it and take photos next weekend.
Norway
What is that exactly?
SyncroHead wrote:
Get these too:
Jim
Thanks for the reply Smile
Steve M. wrote:
Define "Bad Shape"!
I can't until I see it. Owner says it is total junk. I'ts been sitting outside for many years so I expect rust, but I hope the kids have not broken everything Shocked
westfalia-jx-1988
PostPosted: Sun Jan 26, 2020 12:33 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Hi
So here is the pictures i promised.
What do you think? It's worse than I tought..
330 USD he wants for it.
If I can find and read the frame number it can be recycled, then I get the same amount back from the junkyard after i have picked the parts off it, so I guess its a no brainer. but where to put it? Laughing
Have a great day Smile
jimf909 Premium Member
jimf909 is offline
PostPosted: Sun Jan 26, 2020 12:54 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Steve M. wrote:
Define "Bad Shape"!
Hehe, I guess these photos do just that. Very Happy
Geez, are the Syncro bits salvageable?
- Jim
Abscate wrote:
Steve M.
Steve M. is offline
PostPosted: Sun Jan 26, 2020 1:21 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
jimf909 wrote:
Steve M. wrote:
Define "Bad Shape"!
Geese, are the Syncro bits salvageable?
Okay, "Bad Shape" may have been an understatement...
What part of the seabed is it resting on? It certainly looks wet!
Without the windhield the water/ corrosion effets on the under dash electrics are not something I want to visualize.
The internals of the gearbox and front diff will be okay if they were not damaged before it was parked - the external housings will be corroded.
Why was it parked?
Still, without seeing it in person to really see it's metal I'm just quarterbacking from a recliner...but I'd swim away from it.
stuzbot
stuzbot is offline
PostPosted: Sun Jan 26, 2020 3:05 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Were the AstroTurf Captain's Chairs seat covers factory fitted, or an after-market job?
Click to view image
1992 VW LT35 2,4D [SOLD]
1993 VW LT35 2,4D [SOLD]
1992 VW T3 1,6TD Syncro [SOLD]
Escorial Syncro
Escorial Syncro is offline
PostPosted: Sun Jan 26, 2020 3:21 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
grab that syncro diesel fuel tank! That tank might not be rare where you are but we never got them over here so there is value there. It would be cool if the trans and front diff are there. If so it's worth the effort. Good luck!
Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!)
kguarnotta
kguarnotta is offline
PostPosted: Sun Jan 26, 2020 9:36 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
Not sure if I should start a new post on this or not - but I have an '86 Syncro, and I'm replacing some parts on it. I don't know how rare/sought after certain parts are.
I know when I worked on my old '65 splittie - people seemed to want everything and anything if it was original, even if it was in bad shape.
I have some random stuff (ie skylight, speakers are two things off the top of my head) that I changed for new. I don't want any money for these things - but hate to throw them out if someone was a real vintage/original person and was into fixing old speakers, or wanted that authentic skylight - even if it had some crazing it it...etc. Aside from posting the individual items for free in the classifieds - is there an alternative?
-Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper
levi
levi is offline
PostPosted: Sun Jan 26, 2020 9:47 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
There is a thread.
Karma part it forward, or something along that line
jimf909 is offline
PostPosted: Sun Jan 26, 2020 11:22 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
levi wrote:
There is a thread.
Yep. Post your spares here. If no one bites after a few weeks take it to the dump. I've made a few folks happy as pie and also dumpstered some junk with a clear conscience.
https://www.thesamba.com/vw/forum/viewtopic.php?t=478468
- Jim
kguarnotta
PostPosted: Mon Jan 27, 2020 4:57 am    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
thanks! Nice thread...
-Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
SyncroChrick
SyncroChrick is offline
PostPosted: Mon Jan 27, 2020 7:09 am    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
At the very least get the syncro specific dash middle section (above from the shifter...)
designer
designer is offline
PostPosted: Mon Jan 27, 2020 2:43 pm    Post subject: Re: Stumbled upon a syncro in bad shape, what parts to keep? Reply with quote
^^Already PM'd for that yesterday ... Wink
__________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013.
