New Elring flywheel seal too loose.
Page: Previous  1, 2
sjbartnik
sjbartnik is offline
PostPosted: Sat Feb 01, 2020 5:28 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
So the real interesting question for me is how did that happen?
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Cliff@BrownBags
Cliff@BrownBags is offline
PostPosted: Sat Feb 01, 2020 5:56 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
It’s weird the hole is too big, but had that factory seal in it. I can’t find that seals dimensions listed anywhere to make sure it’s the typical one.
its not about what you say you will do oneday, its what you do today that actualy means something.
Cliff@BrownBags
PostPosted: Sat Feb 01, 2020 5:58 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
Also had a guy measure his engine and the hole was 90.2
modok
modok is offline
PostPosted: Sat Feb 01, 2020 6:47 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
Rolling Eyes
Specification is 90.00-90.05mm
According the the bently factory service manual, or without guesswork manual
See here
https://www.thesamba.com/vw/archives/manuals/1971withoutguesswork/6_7.jpg
The box the seal cam in says 90mm, so, at least we identified the problem based on the availible information.
If samba members can effectively measure a hole accurately is..... always suspect IMO. Nothing personal. Just based on experience
esde
esde is offline
PostPosted: Sat Feb 01, 2020 9:35 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
modok wrote:
Rolling Eyes
Ha!
I measured the hole. And then when reading your post Glen, I wondered if I had the case bolts all tight? Went and checked, and of course the case bolts were NOT all tight. When tightened down, the seal bore measures dead 90.
Cliff, it's Seth. Could your case bolts at the main be loose?
I know its hard to imagine that the case bolts could be loose enough that the seal slips in, without the engine pissing oil and rattling. But, it's a weird problem so best to check EVERYTHING, right?
SD
modok wrote:
Ovally
Ovally is offline
PostPosted: Sun Feb 02, 2020 11:25 am    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
Cliff@BrownBags wrote:
The VW seal that I removed was nice and tight and measured 90.6mm
Part number 113-105-245-2
SABO O 1927 BR
The Erlin is 90.2mm
The felpro is 90.2mm
And the factory hole in the block is 90.3mm
Any thoughts? I appreciate any info in advance.
For some reason the hole in your block is larger than standard.
You really need the SABO seal.
The dimensions of the SABO seal 01927BR (part number 113-105-245-2) are 70 x 90.5 x 10
Try to find a supplier of SABO seals or contact https://www.sabo.com.br/en/
Still available according to the SABO catalog 2019.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
Ovally
Ovally is offline
PostPosted: Sun Feb 02, 2020 2:16 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
Here for sale : R$60,00 = 14,01 USD
https://diskpecas.com.br/auto-pecas/motor/retentor...7-brp.html
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Cliff@BrownBags
PostPosted: Sun Feb 02, 2020 8:28 pm    Post subject: Re: New Elring flywheel seal too loose. Reply with quote
Thank all of you for the feedback, the time you took to send links and share info. It’s very appreciated.
Seth, it wouldn’t hurt to check. I can also measure top to bottom to see if that number still stays true.
I will also order the seal you guys listed.
Again, it’s VERY appreciate.
Page: Previous  1, 2
Page 2 of 2
