VW Addict Samba Salesman
Posted: Tue Feb 04, 2020 10:05 am Post subject: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
I bought some VW parts the other day, along with it... was this motor. Someone mounted a mounted GM Alternator to a VW Generator. HAHA...
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Tue Feb 04, 2020 10:27 am Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
Looks like they welded the bracket to the generator body! Hope they removed the innards before applying all that heat! Maybe they didn't; is that a torn pulley at the left?
Looks like a modern take on this VW design, probably for police or ambulance service:
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Feb 04, 2020 11:46 am Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
KTPhil wrote: |
Looks like they welded the bracket to the generator body! Hope they removed the innards before applying all that heat! |
Really, what does it matter, it was probably not in working condition anyway
Have seen that before, pretty ingenious. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Feb 04, 2020 12:00 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
KTPhil wrote: |
Now that is interesting!!
What I can't understand is... why not just replace the generator. Or buy an alternator... so easy to install. Why go through the hassle of mounting a GM alternator welded to a VW Generator...
Some people.... |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3815 Location: Georgia
Posted: Tue Feb 04, 2020 12:16 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
I wish I had a picture of it but my first Ghia had the stock generator to run the car and an alternator attached to an A/C compressor bracket to run the stereo.
Two separate batteries as well. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Tue Feb 04, 2020 12:46 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
Why? because that is a small amp 6 volt generator and they probably had that larger amp 12 volt alternator just lying around waiting to be used.
That is how people fixed things back then. They just didn't go out and buy everything new like nowadays. It was called barely getting by _________________ Rick
tasb wrote: |
sb001 wrote: |
Danwvw Samba Member
Posted: Tue Feb 04, 2020 1:01 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
I bet they did not remove the generator insides before welding it the reason to do this would be if you had the thing and a welder and did not want to pull the generator to fix it. I wonder if they bothered to run the fan belt to cool the engine? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21509 Location: Oklahoma City
Posted: Tue Feb 04, 2020 1:21 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
I have seen pictures of the dual generator set up before. As noted....it for police/fire/ambulance.
Why did they want an alternator?
Who wouldn't?....and looking at the age of that thing...just guessing....back in the 70's/80's....alternator set ups for type 1 were not everyday fare.
That being said.....when my type 4 engine goes back together in my 412.....I'm getting rid of the damn 55 amp alternator and putting in a Delco 10si...hopefully ....(which has upwards to 72 amps) ...or possibly a CS130....which is 100-105 amps
https://www.hemmings.com/blog/article/delco-cs130-alternators/
You can buy them rebuilt...good quality or even new...moderate quality.
It will take some pulley and mounting bolt work....but nothing like welding it to the old alternator
Ray |
mark tucker Samba Member
Posted: Tue Feb 04, 2020 3:50 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
the one off to the side would be better as both would have good belt contact. was I the only one to notice the rear of the engine was connected to the trans??? somebody put it in basckwards.... I wonder if they fliped the ringing gear thingy over.... |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Tue Feb 04, 2020 8:09 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
i've seen that in some buggies from down under,
they run a longer belt
use the old gen as an idler to run the cooling fan |
Posted: Tue Feb 04, 2020 8:17 pm Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
oprn Samba Member
Joined: November 13, 2016 Posts: 12695 Location: Western Canada
Posted: Wed Feb 05, 2020 5:26 am Post subject: Re: Well isn't this... interesting (GM Mounted Alt to VW Gen) |
A couple of other interesting items on that Beetle, no hoses on the fan shroud for the heating/defrost system and of course the mandatory plastic automatic fire starter mixed in with the high tension wiring between the coil and distributor! |
