Modification to Intake Manifold Heat Riser-Parts Identification
UkeGhia
UkeGhia is offline
PostPosted: Thu Feb 06, 2020 12:04 am    Post subject: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
I have been restoring my 68 Ghia and came across a modification to the heat riser tube for the intake manifold. In the image you can see how a part has been welded to the heat riser. I have circled two parts in the image, does anyone know what these parts are for? Wondering if I should keep this modification or pull it out and install new heat risers. This is a single port, single relief engine.
c21darrel
c21darrel is offline
PostPosted: Thu Feb 06, 2020 10:51 am    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Here is a start for you. Its a throttle positioner/altitude compensator.
https://www.thesamba.com/vw/forum/viewtopic.php?t=641337
GhiaBuild
61SNRF
61SNRF is offline
PostPosted: Thu Feb 06, 2020 3:40 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Hi,
It's a retrofit EGR system sold by Grancor in the 70's...
Image found on search in hazetguy's Gallery.
Background: in the early 70's, to reduce NOX emissions, the State of California required VW owners to have this devise installed by a licensed installer/station in order to renew the registration or transfer the title.
Although not as effective, most other older liquid cooled cars also got some form of devise or engine mods to reduce NOX.
The system worked to a degree but killed the engine's power. Most have been long ago removed and trashed.
Since your car is now exempt from Smog Check inspection you are free to do as you wish with it.
-Bruce
An ounce of prevention is worth a pound of cure.
djkeev Premium Member
djkeev is offline
PostPosted: Thu Feb 06, 2020 4:23 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Who woulda thunk?!?!?
Another good day!
I learned something new!
Dave
Ghia
Vanagon
Beetle
UkeGhia
UkeGhia is offline
PostPosted: Thu Feb 06, 2020 8:06 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Thanks Darrel and Bruce for this information on the throttle Positioner and EGR, this is really great info.
Now that I know what itís called I was able to find it in Bentley too!
Iíve noticed that mine is missing the pull rod (see pic) so it is clearly not doing itís job right now, Iíll have to see if I can find one or rig something up and Iím also thinking that I will pull out the EGR.
Thanks for the help!
-Jeff
c21darrel
PostPosted: Fri Feb 07, 2020 11:41 am    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Your missing piece. Cut?
GhiaBuild
UkeGhia
UkeGhia is offline
PostPosted: Fri Feb 07, 2020 12:05 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Yeah, looks like it was cut but I think it is threaded so hoping that I can find a threaded rod that I can use.
61SNRF
61SNRF is offline
PostPosted: Fri Feb 07, 2020 3:31 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Because the rod is threaded right hand thread on one side and left hand thread on the other you will need to find the exact replacement. You will also need a suitable left hand thread lock nut and of course the ball socket as well.
You might try searching the Classifieds or place a WTB ad.
Another option is go to your local self service salvage yard and look around in the foreign section.
By looks it appears very similar to the throttle rod from most 80's to 90's Volvo 4-cylinders with fuel injection. Very common in these cars, anything from a 240, 740 or 940 is the same and should give you everything you need except the vacuum pot itself.
-Bruce
UkeGhia
UkeGhia is offline
PostPosted: Fri Feb 07, 2020 4:13 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
Thanks Bruce for the info on the left hand threading...learning new things all of the time Smile
-Jeff
Bleyseng
Bleyseng is offline
PostPosted: Sun Feb 09, 2020 12:01 pm    Post subject: Re: Modification to Intake Manifold Heat Riser-Parts Identification Reply with quote
They are actually nice to have working instead of backfiring when decelerating.
Who wants to hear that Pop Pop..
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
