bassam Samba Member
Posted: Tue Feb 11, 2020 4:45 am Post subject: 1973 Squareback Grease Front Suspension? |
My father says my 1973 Squareback's front suspension doesn't have grease points. Is he right or lazy? _________________ 1973 VW Squareback |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Tue Feb 11, 2020 5:31 am Post subject: Re: 1973 Squareback Grease Front Suspension? |
The beam has 4 grease fittings, one on either end of the upper and lower sections. The fittings for the upper section may be hard to find, since they're located in the mount brackets, and often crusted over with dry grease - but they're there.
Also, the ball joints may have grease fittings, as well. |
old_man Samba Member
Joined: June 19, 2018 Posts: 1382 Location: Newfoundland
Posted: Tue Feb 11, 2020 6:04 am Post subject: Re: 1973 Squareback Grease Front Suspension? |
vwsquare2 Samba Member
Joined: February 16, 2016 Posts: 104 Location: Pennsylvania
Posted: Tue Feb 11, 2020 9:49 am Post subject: Re: 1973 Squareback Grease Front Suspension? |
Page 51 of the 1973 Owner's Manual shows the grease points. If you don't have the manual, you can find a PDF of the manual under the Technical Tab.
For the 1973, greasing was specified as every year or 18,000 miles. I believe the duration was less for previous years. |
Bobnotch Samba Member
Posted: Tue Feb 11, 2020 5:02 pm Post subject: Re: 1973 Squareback Grease Front Suspension? |
Also check the right upper sway bar adjustment, as they like to change if they haven't been done regularly. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
gt1953 Samba Member
Posted: Wed Feb 12, 2020 3:13 pm Post subject: Re: 1973 Squareback Grease Front Suspension? |
The zerks are there and you do have to LOOK for them. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
