Marking up defects
meranda
meranda is offline
PostPosted: Thu Feb 13, 2020 2:34 am    Post subject: Marking up defects Reply with quote
I have just given my 68 1500 it's first top coat and of course with my painting skills there are plenty of blemishes" errors"! I remember seeing film of the factory inspectors marking blemishes on the bodies for remediation. I wonder what I could use to do the same. Can someone suggest a product?
Dan2973
Dan2973 is offline
PostPosted: Thu Feb 13, 2020 3:31 am    Post subject: Re: Marking up defects Reply with quote
What kind of defects? What exactly happened?
bomberbob
bomberbob is offline
PostPosted: Thu Feb 13, 2020 5:37 am    Post subject: Re: Marking up defects Reply with quote
Not sure what they used at the factory, but you need something that will not leave any residue and will wipe off. You might try a dry erase marker, but try it on one of the test coupons you sprayed first.
1968 Beetle (dismantled)
1990 Jetta GLI megasquirted, burning E85
2004 Jetta turbo GLI
Marion, Iowa
beetlenut
beetlenut is offline
PostPosted: Thu Feb 13, 2020 10:51 am    Post subject: Re: Marking up defects Reply with quote
I just used painter's blue tape cut in pointy triangles that pointed to the blemish I needed to fix. Then just pulled them off as I fixed the blemish.
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
meranda
meranda is offline
PostPosted: Fri Feb 14, 2020 2:52 am    Post subject: Re: Marking up defects Reply with quote
That's a great idea Thanks.
