scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
AlteWagen Troll
Posted: Sat Jan 25, 2020 11:27 am Post subject: Re: Rear apron help |
The stamping on the AC apron looks swollen to me and is easily identifiable as aftermarket. The wolf part looks much more correct but as you mentioned lacks the inner assembly and seal channel. Other than the cutouts I believe them to be the same as 56-60 aprons.
depending what engine you will be putting in you may want to sell the AC apron and use a later apron to graft so the rear tin will fit without cutting _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Jan 25, 2020 1:38 pm Post subject: Re: Rear apron help |
- i'd go with an original... but many in early 1955 had no cut-outs for twin pea shooters - a late '55 to 60 would be nice - and 1961 to 1963 would work, but no H-pattern. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1773 Location: Winnipeg
Posted: Sat Jan 25, 2020 3:11 pm Post subject: Re: Rear apron help |
I have bought several pieces from Wolfparts and have been very happy with them. It is unfortunate he does not make the correct apron from your year of car because it would be pretty much perfect.
Don _________________ Better and better mistakes! |
Posted: Sat Jan 25, 2020 5:36 pm Post subject: Re: Rear apron help |
scotty timmerman wrote: |
I will be using a 36hp so engine fitment won’t be an issue. I would like to get a good original apron but they all seem to be rusty or hammered. They would also take a lot of work to make right. I think I will be going with a wolfparts apron and cutting up the autocraft one for the pieces. |
i hear ya - found a pretty nice apron, from a 1959 - sept has pretty hacked pea shooter cut outs - not looking for perfection - will be very functional... _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
jason Samba Member
Posted: Sat Jan 25, 2020 6:19 pm Post subject: Re: Rear apron help |
Easiest way to tell they’re aftermarket is the lock tab. Correct is with square corners but I have only seen rounded. Wolfs looks correct.
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 278 Location: Colorado
Posted: Fri Feb 14, 2020 4:48 pm Post subject: Re: Rear apron help |
It looks like they have the inner breast plate area in them. Is that accurate?
Did you purchase a cutout version or the early 55 version? |
Posted: Fri Feb 14, 2020 5:28 pm Post subject: Re: Rear apron help |
Good info to know. Thanks. |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Wed Nov 11, 2020 6:29 am Post subject: Re: Rear apron help |
I bought one from there and they are autocraft. |
What was your overall thought of the quality? I just received one from KN and I am not happy with it. _________________ '63 Ragtop |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Wed Nov 11, 2020 4:38 pm Post subject: Re: Rear apron help |
Mark Evans wrote: |
What was your overall thought of the quality? I just received one from KN and I am not happy with it. |
What do you not like about it? |
Posted: Fri Nov 20, 2020 8:50 am Post subject: Re: Rear apron help |
Snort wrote: |
Mark Evans wrote: |
As mentioned by Scotty, the clarity of the stampings of the H pattern, to me, was unacceptable. Latch tab was crooked. Also, the drip holes looked to have been drilled poorly.
