Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Tue Feb 11, 2020 9:41 am Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
My BN4 fuel filter glass is bad. Bit disappointed…
You could wet sand that down. That would take a while, and possibly if it would then be too small for the seal area due to the taper or the filter inside. _________________ In Stereo, Where Available! |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2013 Location: SW Nova Scotia, Canada
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Tue Feb 11, 2020 1:25 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
Eric&Barb wrote: |
sgellis wrote: |
You could wet sand that down. That would take a while, and possibly if it would then be too small for the seal area due to the taper or the filter inside. |
That would take longer than I would like. But maybe I could grind it down first... |
Its a very common part. Just buy one. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Tue Feb 11, 2020 1:53 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
notchboy wrote: |
sgellis wrote: |
Eric&Barb wrote: |
sgellis wrote: |
Its a very common part. Just buy one. |
You are taking all the fun out of it... |
Brother those leak on a good day. Do yourself a solid and get a nice one and pick the rubber out of the filter side and put a new o-ring in. _________________
t3kg wrote: |
1964 1500 S
Posted: Thu Feb 13, 2020 6:36 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
Picked up a few more bits.
Rubber block for the hatch striker. Hatch doesn't latch quite as nice as without it. I have to push it to latch. Maybe it will get better with time. |
Did you apply a little grease to lubricate those latching surfaces. Lubrication helps to make surfaces slide together easier. _________________ In Stereo, Where Available! |
Posted: Mon Feb 17, 2020 3:51 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Nice work! Do recommend replacing the rusty pipe though. _________________ In Stereo, Where Available! |
Posted: Sat Feb 22, 2020 3:28 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Got the welder fixed so started the rear bumper. 37 year old Miller Matic had 2 diodes go bad so replaced all 4.
Overriders have the ends rusted bad. Found some pipe with the correct size to replace the ends. I slid sockets in the pipe, put it in the vice and tapped in the indent. I will fix them up once they are welded. Fitted the end but will likely need a little adjustment once assembled.
Was going to start on the new engine but decided to get new connecting rods. I had planned to change the wrist pin bushing but that turns out to be a complex job and no local machine shops I would trust.
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Mon Feb 24, 2020 7:48 am Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Impressive of the over rider ends... |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sat Mar 28, 2020 6:39 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Killer save. |
mdege Samba Member
Joined: January 16, 2018 Posts: 939 Location: Niederkruechten, Germany
