joescoolcustoms Samba Member
Posted: Thu Mar 14, 2019 1:18 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Bashr52 wrote: |
dustymojave wrote: |
My Hi Jumper in my avatar has always had axle tube stiffeners without RGBs.
But yes, in a Johnny Johnson No-Hop kit, the axle sleeves ARE pivot tubes. The regular axle tube rides inside of the sleeve to rotate (I think that's a more fitting word than "spins") and thus let the 2nd link take up torque thrust to eliminate "hop" as one reduction gear tries to climb the other when power is applied. |
Maybe I'm missing it, but I don't see hope the tubes tie into the lower stiffener bar?
The system works in a 4 link style suspension.
The two Spring Plates are the top 2 links, and are bolted to the gold sleeve that is overtop of the axle tube, but free to rotate on the axle tube. The axle tube "floats" inside the sleeve.
The bottom strut bars are the bottom 2 links in the 4 link system.
On a race car, it is standard to use a Panard bar to keep the rear end from moving side-to-side. The fixed transaxle with the axle tubes hooked to it keep the wheels fixed side-to-side.
So, as the wheel and RGB moves up/down, the top spring plate and the bottom strut bar pivot and allow the to rise and fall in a basic straight line up and down instead of in a arc following the spring plate's arc.
That is my NOS JJ No Hop set up in the picture above. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
dustymojave Samba Member
Posted: Tue Mar 19, 2019 12:41 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Bashr52 wrote: |
The green lower bar is not a "stiffener bar". It is a radius rod. It allows pivot at both ends. If you unbolt that green lower bar, the axle tube will pivot in the gold sleeve. As the axle moves up and down with suspension movement, the axle housing rotates inside the No-Hop sleeve (the gold tube). _________________ Richard
SoCalBajas Member
pedmick Samba Member
Posted: Tue Feb 25, 2020 8:57 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Great write up!!! I am on my second no hop kit. 1st was on my glass buggy, and the latest is on my baja.
One problem I had on my glass buggy, was that eventually, the interference fit between the boxes and tubes loosened up, requiring a heliarc weld, and loctite to stop the leak.
I used adjustable length swedged tubes with heim joints to dial in the geometry, and these thing hook...Even in sand! |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Sat Sep 23, 2023 10:55 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
A have a very early version of the John Johnson No-Hop kit. I've been told the strut rods are from a Corvette.
I'm trying to find out what year Corvette so I can order adjustable ones.
_________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
BFB Samba Member
Posted: Sat Sep 23, 2023 7:28 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
You think asking in this thread will get you more responses than what you got from your own last week?
Few ppl run RBG’s and even fewer are going to know what your control arms came off of, sorry to say but what answers you got is probably all there is right now until someone pops in thats either new or old and hasn’t been on here in a while. I highly doubt anyone will know though, no pics of the kits ive seen ( and ive done a bunch of research) has had the ones like yours, they’ve all been the rec tubing ones. _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
John Ghia Samba Member
Posted: Sat Sep 23, 2023 8:26 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Make your own adjustable links. You can even improve them with heim joints. _________________ BUS BOYZ |
DesertSasquatchXploration Samba Member
Posted: Sat Sep 23, 2023 9:32 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Yea already suggested that so did BFB we live in 2023 parts can be ordered online or bought locally here in SOCAL. Adjustable links can be made in a Saturday morning with some coffee a two car garage equipped with basic fab tools. TheFladge has owned his baja for 35plus years yet struggles with simple problems. |
AlteWagen Troll
AlteWagen Troll
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
Posted: Mon Sep 25, 2023 11:47 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Wish someone would re pop those. I think there is still a market for them. Id buy a set |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Tue Oct 31, 2023 12:15 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
[quote="AlteWagen"]I thought the later versions are the ones with the vette arms as they are boxed.
The Corvette rod type are a later version. You can see an adjustable Corvette type rod on the center picture of the late 70s catalog page. The Corvette rod is longer, 16.5" vs. the rectangular rod 12".
In the first picture you can see the rear attach bracket for the control rod was also redesigned to be more vertical to fit the longer Corvette control arms.
I believe the catalog picture shows an unfinished prototype, notice the rear bolts on the spring plate/axle tube sleeve are missing and it still has the same rear bracket as the rectangular tube version. It also has a control rod with threaded rod ends instead of the Corvette rod which was sold with the kit
On the final version, the sleeve on the axle tube is several inches longer than earlier versions and the mount plate which connects the sleeve to the spring plate has five bolts vs. the earlier version's three.
Posted: Tue Oct 31, 2023 9:00 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
At the top, the picture shows the earlier version left side rear bracket with the shorter rectangular rod
Center is the later version left side rear bracket with the longer Corvette rods
Below is a later version axle tube sleeve with zirc fitting and five bolt holes in the mount plate
Posted: Wed Nov 01, 2023 11:43 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
BL3Manx wrote: |
Interesting. I thought the top one was the later design.
So, my style is the one in the middle and it also uses the five bolt axle tube sleeve.
Now I just need to figure out what year Corvette that rod is from. _________________ 1957 Vintage Baja Bug.
Posted: Wed Nov 01, 2023 3:46 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
I've read 74 is 16 3/8 and 77 is 16 9/16".
If you are going to use the rods as a jig to weld the brackets on the torsion housing, either should work.
If you are looking for a rod to fit previously welded on brackets, you need a threaded adjustable one
A threaded adjustable one is also probably helpful for setting your rear wheel toe in |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Thu Nov 02, 2023 5:07 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
I hope its OK to mention this here, as Im hoping to help someone. I have a very nice set of swing axle over tubes that I was going to use to make a no-hop kit. I sold my rgb trans and boxes, but still have these tubes.
Im hoping someone can use them. |
Posted: Tue Nov 07, 2023 8:58 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
DOM tubing chuck it in the lathe 45deg chamfer the ends drill a hole or two pound in the threaded inserts. Plug weld and run a bead around the ends, Let cool paint with Rust-Oleum cheesecake job. What's the problem???? |
Michael1 Samba Member
Posted: Thu Nov 09, 2023 2:09 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Can you guys help a german to understand the function /setup of the kit?
Does it use beetle spring plates? I have to pull rgb s from the axle tubes and install the slip over tubes ? I so understand the lower strut part.
Does it use beetle axles tubes ? You loose the rubber mounts for
Axle movement ?
Please help me
I can build it by myself once i understand the function
Regards
Michael |
jsturtlebuggy Samba Member
Posted: Fri Nov 10, 2023 2:46 pm Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
Michael1,
To install the over the axle tube pivots you have to press off the outer castings and also cut if I remember correctly (since it was in 1975 last done this) 1/2in off the end casting for clearance of spring plate.
Both my Dad and did this with our Baja Bugs.
The tubing was slip fit over axle tubes and an exhaust flange was welded to slip over tubing to bolted to spring plate. Also added was a boss and Zerk fitting to add grease inside tubing to lube it. As the tubing rotates on the Bus axle tube.
The lower strut I used was off a 1970s Volvo. This strut and front mount that make and weld to torsions has to be very strong as it has a lot of torque applied to it.
I sure you could find some kind strut in a wrecking yard that would work. Or make your own using thick wall tubing and Delrin bushings. Would recommend a Grade 8 or 12.9 rated bolts to hold strut in place _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
boxertje53 Samba Member
Posted: Thu Dec 28, 2023 1:17 am Post subject: Re: John Johnson Nop Hop Reduction Gear Box Setup Measurements |
