ajsamora Samba Member
Joined: February 01, 2006 Posts: 16 Location: Bellingham, Washington
Posted: Mon Feb 24, 2020 8:38 am Post subject: Vanagon Westfalia Interior Lighting Options |
I'm hoping to see what interior lighting options there are out there. I have a 1983 Westfalia and could use better lighting that would be handy and practical. What do you all recommend? Photos appreciated.
kourt Samba Member
Joined: August 13, 2013 Posts: 1948 Location: Austin, TX
Posted: Mon Feb 24, 2020 9:52 am Post subject: Re: Vanagon Westfalia Interior Lighting Options |
Thank you I'll check them out! |
Marshj Samba Member
Posted: Mon Feb 24, 2020 10:19 am Post subject: Re: Vanagon Westfalia Interior Lighting Options |
When building out our vans my goal has always been to have portable solutions, things that functioned for everyday uses / other uses as well as Vans. And having multiple vans portability makes sense.
We have 8 of these sitx headlights. They have many mount styles, and you can use them on bright and on ultra bright. They last 3.5 hours on one led and 2 hours on 2. One is enough lighting for the entire rear and charges on usb. They also function as our bike lights when on road rides or commuting. Their portability and brightness for the battery length is top notch.
https://www.google.com/search?q=specialized+stix+h...ent=safari |
Marshj Samba Member
Posted: Mon Feb 24, 2020 10:23 am Post subject: Re: Vanagon Westfalia Interior Lighting Options |
Looks like the latest version is even better.
Low- 38 lumens for 10 hours run time
High- 100 lumens for 2.5 hours |
kamzcab86 Samba Moderator
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Mon Feb 24, 2020 8:51 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
Two improvements that worked well for me was adding an LED light strip from the closet to the above the sink and an overhead light. We cook in our westy and use the closet. Now light reaches the closet and there is good light over the stove and sink. The overhead light provides central overhead light which we find as an improvement to lower driver side only light. We also can turn it on by opening the slider and reaching up to turn it on without the need to crawl or step into the van.
This thread has some failed ideas and starting with the April 8th post shows what worked.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Vanlife Geek Samba Member
Posted: Mon Feb 24, 2020 11:48 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
The first thing I did was to swap out the florescent bulb in the fixture above the kitchen/table area with a LED replacement bulb and it made a world of difference in both light output and energy consumed, while retaining the stock fixture. Although unless I'm cooking or need a bunch of light for some task, I think it's way too bright for just hanging out. I also replaced the old stock bulbs in the driver's door light fixture and the map light with LED bulbs, which was very cheap and provides much more light.
I also added a new LED lamp just behind the rear bench, which will light up the entire back area (and engine bay). It also swivels to serve as a great reading light while sitting in the back. (Gold Stars RV Reading Light MR16 Base LED Bulb 12v - https://amzn.to/3c4XrqK - mine came with warm LED's, which I prefer)
For the rest of my lighting, much like Marshj above, I chose to use portable lights that can be multi-purposed. My favorite is the Goal Zero Lighthouse 400 Lantern. It is super bright, but will dim down to next to nothing, can light from the front or both front and rear (surprisingly handy), has a dynamo for manual recharging, an internal lithium 4,400mAh battery with a 1.5A USB output for charging other devices, and can be charged via USB from the built-in cable. The legs can fold if you want to just hang it from the pop-top bar, which will also cast light into the upper bunk area. Since it's portable, it can be used everywhere... I like to use it under the awning at night. (https://amzn.to/2w77MSj)
Another portable option that is less bright, but will collapse down to the size of a hockey puck is the ThorFire light. It also has a dynamo handle and a USB port for charging phones, etc. and two brightness levels. It's also considerably cheaper at around $18. (https://amzn.to/37YgwaC)
Both the Goal Zero and ThorFire put out a nice warm light.
Speaking of warm light... my favorite portable lights in the fall and winter are the classic UCO candle lanterns. The single candle version is collapsible and is easily stored. I love candle light and the heat output is a bonus in colder weather. I also have the non-collapsible 3-candle version which really cranks out the heat at 5,000 btu's.
Single Candle Lamp: https://amzn.to/2SWKibN
Three Candle Lamp: https://amzn.to/2PjlIPR
Here's a video of some dude using it to heat his camper and has some interesting mods:
The main negative to the candle lanterns is the cost of the candles, but if you buy them in the 20 packs when they're on sale, it's not so bad.
Another great Westy lighting solution is the Luminoodle. I got a knock-off from China for about $9 that also has step-less dimming. It is flexible and has several magnets to mount wherever there is metal. I use it under my awning attached to the van when camped, but normally have is stuck along the spice rack area above the kitchen, which makes for great "mood" lighting. It also comes with some plastic ties to hang it from non-metallic areas and a long-ish USB cable. https://www.aliexpress.com/item/33034468326.html
Amazon carries the full line of "real" Luminoodle lights: https://amzn.to/2w0cdyo
Of course, I also find a good headlamp invaluable for task lighting, and especially for those late night "tree runs" where hands-free lighting works well . Since I usually camp in mountain forest areas, I'm always aware that bears/lions might be lurking about and a bright, focused headlamp is way better than a lantern for lighting up wildlife eyes from a distance. Distance is good! Black Diamond makes first class headlamps and most come with a red light option to preserve night vision. Here's one similar to my NLA verion: https://amzn.to/2ut60L5
I think the next permanent fixture I'll install is something for above the sliding door. I'd love to have a light for when I'm loading stuff into the van from the slider at night without having to hop into the van and turn on the main light. I especially like the solution from uniWerks Designs, Upperbunk 2 Switch LightPod w/USB and Level, which serves several purposes, and may very well be my next upgrade.
http://uniwerksdesign.com/product/upperbunk-2-switch-lightpod-w-usb-and-level/
That's my long-winded suggestions for lighting! _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era) |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Feb 25, 2020 10:59 am Post subject: Re: Vanagon Westfalia Interior Lighting Options |
epbiggs wrote: |
That's my long-winded suggestions for lighting! |
You sir, are awesome!Awesome - and with the links-great info!
I'm with you on the portable lights. I have two solar powered ones and a long-life USB chargeable one that Dan from Syracuse gave me. These get near nightly use at home as well. We also have a crank/USB rechargeable lantern as well.
This one below (Ultimate Survival Technologies 30-Day Duro Lantern) with 3 D Cells and LED lighting, lasts FOREVER - as in, we have had it years and I think it is still on original batteries. Maybe I need to change them before they leak. It rated to run 30 days at low setting.
https://www.rei.com/product/155144/ultimate-surviv...lsrc=aw.ds _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Tue Feb 25, 2020 4:57 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
When I undertook a comprehensive electrical/aux battery upgrade I installed a couple of different LED options - some pics and links to the actual items can be found about halfway through this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Three years in and still very happy with the results
Feel free to PM me if you need any more info. _________________ 1991 Westfalia EJ251, 1972 Volvo 1800 ES |
84Cabby82Westy Samba Member
Joined: April 03, 2004 Posts: 49 Location: Missoula, MT
Posted: Thu Feb 27, 2020 7:58 am Post subject: Re: Vanagon Westfalia Interior Lighting Options |
I replaced the light over the stove with a 1 meter warm white LED flexible strip from Superbrightleds.com in their aluminum channels and frosted cover. An amazing improvement in the amount of light and the distribution - we can see n the little cabinets above the water tank without a flashlight. Liked it so much I put another over the engine compartment on the bottom of the AC cabinet. Great for light when camping and also when working on the engine. For the door, I installed a low profile LED rv porch light and wired it to a door switch on the slider. When I open the door the light goes on, but it has an integrated switch on the bottom so that I can shut it off when the door is open.
Also installed a center mounted boat LED dome light in the cab. Has a switch to allow it to be turned on or to come on with the door switch. Great upgrades that cost about $75 total. |
Posted: Thu Feb 27, 2020 8:32 am Post subject: Re: Vanagon Westfalia Interior Lighting Options |
84Cabby82Westy wrote: |
For the door, I installed a low profile LED rv porch light and wired it to a door switch on the slider. When I open the door the light goes on, but it has an integrated switch on the bottom so that I can shut it off when the door is open. |
I would love to hear more about how you wired this setup. I have a slider door switch that does nothing at the moment and would like to incorporate it into some lighting for the slider area. As I understand it, the switch has only a ground wire, so I'm wondering how you wired your light and additional switch. Pictures would be cool, too. Thanks! _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Feb 28, 2020 1:23 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
Couple ideas you could steal, from my Bus:
The "light bulb" you see is something I picked up randomly at some point. It is just a small LED, battery powered bulb. You pull the bulb to turn on/off. It's nice for a quick bit of low light, or as a nightlight if you've got little kids camping with you. It's not lit up in this pic, just visible hanging from the pop top bar as always.
The other is some LED strips I got from Amazon. I replaced the original panels along the upper edges with some cut to order semi-opaque sign plastic I ordered. The LED lights are stuck to the metal behind the plastic panels. I have a three position rocker switch where the old fixture was that selects the door-operated ground switch or a separate ground to allow them to simply be turned on. The little module and it's remote control "eye" are simply tucked away on top of the cabinet. _________________ Dave Cook
1973 Wild Westerner
My Thing |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Fri Feb 28, 2020 1:57 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
I used LED strips and a touch-dimmable switch.
The video is bad below, but you simple tap it on and off. If you want to adjust brightness you hold the touch until desired brightness. It also remembers your brightness (good for before bed, middle of night, etc.)
For more info please visit my 'jo ann the van build ' thread
https://imgur.com/Sozxmv9 _________________ Brandon
Instagram @joannthevan |
letsrig Samba Member
Posted: Tue Mar 03, 2020 2:29 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
shagginwagon83 wrote: |
https://imgur.com/Sozxmv9 |
Nice setup! Do you have links to the LED strip and switch you used? I am having trouble sourcing a dimmable 12v flexible LED strip. Although, i think the switch may be more important in regard to dimming LEDs. _________________ '84 Westfalia - Bostig Conversion |
valvecovergasket Samba Member
Posted: Tue Mar 03, 2020 3:13 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
when i redid our interior last summer i went with an extruded aluminum housing and led strip light from superbrightleds - with a small switch mounted on the spice rack.
its a warmer soft light and plenty bright for cooking/night time moving around.
i also popped a wamer led bulb in the drivers dome light and did the footwell/underdash lighting on both sides up front.
so far with the camping we did last summer, we havent felt like we needed anything in the back section of the bed.
i dont have any great nighttime pics of it yet....
also, ill have to keep an eye out for your van around town! _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Blue Hill Samba Member
Posted: Fri May 08, 2020 7:02 pm Post subject: Re: Vanagon Westfalia Interior Lighting Options |
Ya
