Need help identifying my 63 Single Cab vin plate and location
Page: Previous  1, 2, 3
Clara Premium Member
Clara is offline
PostPosted: Tue Feb 25, 2020 11:17 am    Post subject: Re: Need help identifying my 63 Single Cab vin plate and location Reply with quote
mstg07 wrote:
Is that a Brazilian single cab? Is the m code the same as a German?
It is a German SC.
That particular truck was German delivered, and is a Westfalia widebed.
I don't know about M-code plates for Brazilian buses/trucks. Does someone with a Brazilian truck want to chime in?
Eric&Barb
Eric&Barb is online now
PostPosted: Wed Mar 04, 2020 11:17 am    Post subject: Re: Need help identifying my 63 Single Cab vin plate and location Reply with quote
62DoKaGuy wrote:
mstg07 wrote:
Would you happen to know the type and size of screws used for the plate?
Refreshing an oldie to ask the same question: Does anyone know the type and size of the screws for mounting the VIN and M-code plates to the firewall and bulkhead, respectively?
For a 1962?
In Stereo, Where Available!
62DoKaGuy
62DoKaGuy is offline
PostPosted: Wed Mar 04, 2020 11:39 am    Post subject: Re: Need help identifying my 63 Single Cab vin plate and location Reply with quote
Eric&Barb wrote:
For a 1962?
Correct, the non-riveted models/locations...the little roundhead, slotted screw.
EDIT: I've looked through parts catalogs a while back and could not find anything. I'd like to know for reference and have that info out there for those that might need to replace them and want the correct type of screw...
Couldn't find any at hardware store either that match correctly...I need a hobby haha.
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
Eric&Barb
PostPosted: Wed Mar 04, 2020 4:05 pm    Post subject: Re: Need help identifying my 63 Single Cab vin plate and location Reply with quote
Here is the M-code plate screw from our midDEC62 single cab.
Length 8.84mm:
Outside of threads 3mm:
Head diameter 5.3mm:
Height of the domed head 2.2mm (Approximate due to the slot cut thru it:
Measured in the valleys of the threads 2.24mm:
Eric&Barb
PostPosted: Fri Jan 29, 2021 12:41 pm    Post subject: Re: Need help identifying my 63 Single Cab vin plate and location Reply with quote
Finally got around to pulling out the mounting screw for the engine compartment VIN plate from a cut up bus here. Same general dimensions as the Mcode plate screws shown above.
Page 3 of 3
