Welded connecting rods
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Sun Feb 23, 2020 10:18 pm    Post subject: Welded connecting rods Reply with quote
Yes I know "crazy " ... ..ive was looking around the internet and was just looking around and found this ..
http://www.dlkweb.org/phpBB3/viewtopic.php?f=23&t=5970
Seems like in the 60s guys were welding big end 36hp rods and welded 40 or 1500 rod small end for a custom ratio rod and seems like they welded the i beam of the rod for strength "h beam style " ... does any of you old timers have experience with those type of welded rods and how safe were they ??? I love how guys in those days weren't scared to do the unthinkable...
FritzCP
FritzCP is offline
PostPosted: Tue Feb 25, 2020 2:32 pm    Post subject: Re: Welded connecting rods Reply with quote
I looked into doing this, and found a few shops that have and do still weld them. Mainly used in the vintage tractor pulling world.
Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller
modok
modok is offline
PostPosted: Wed Feb 26, 2020 12:23 am    Post subject: Re: Welded connecting rods Reply with quote
Yep, since most OE conrods are just good quality mild steel.....they can be welded.
I think it would work fine.
Why do you never see it done.......
it's "unthinkable" .... only because nobody has ever thought to ask. Wink
Busted-bolt
Busted-bolt is offline
PostPosted: Thu Feb 27, 2020 7:48 pm    Post subject: Re: Welded connecting rods Reply with quote
I was always thinking about tacking the rod bolt heads, my self Cool
Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission.
Busted-bolt
PostPosted: Thu Feb 27, 2020 7:55 pm    Post subject: Re: Welded connecting rods Reply with quote
Yeah I can see where a couple of pieces of flat sheet metal with a good weld will in fact make an "I" beam "H" beam hybrid rod almost bomb proof ,albeit a bit heavier.
[email protected]
PostPosted: Thu Feb 27, 2020 7:56 pm    Post subject: Re: Welded connecting rods Reply with quote
I thought about having the rod bolt holes of the 36hp rod welded and redrilled and tapped for smaller bolts 1.4x 1/4 bolts so that it would have better clearance for a bigger lobe ...but I told that if I did that the rods would fail but who knows if they would ...
Busted-bolt
PostPosted: Thu Feb 27, 2020 8:04 pm    Post subject: Re: Welded connecting rods Reply with quote
I think I would go with the larger stock thread diameter ,and just modify the depth of the threads in the cap and use a allen or twelve point external "aka arp "rod bolt. That alone if adjusted correctly should achieve the room you need to clear the cam.
TomSimon
TomSimon is offline
PostPosted: Thu Apr 09, 2020 4:39 pm    Post subject: Re: Welded connecting rods Reply with quote
I beam rods w/sheetmetal 'caps' welded over the beam, V8 stuff, show up at old car swap meets once in a while. VW rods are old school heavy 'clubs' by comparison to anything modern. With the availability of inexpensive and decent quality Chinese H beams, you don't see the rods when you pop the decklid, so why bother?
2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer
earthquake
earthquake is offline
PostPosted: Sun Apr 12, 2020 7:39 pm    Post subject: Re: Welded connecting rods Reply with quote
Hey, If MacGyver could do it with a half dollar as the welding rod any body with a flux core welder should be able to handle it fine!
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
