kevzo1 Samba Member
Joined: February 10, 2016 Posts: 9 Location: Sebastopol, Ca
Posted: Wed Oct 10, 2018 11:22 am Post subject: 1966 Beetle Sea Sand Interior Carpet Trim Color |
I recently picked up a 66 Beetle, Sea Sand. The carpet appears to have a brown or oatmeal trim on it. Carpet is really faded any ideas as to the original trim color. Carpet seems to be black.
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Oct 10, 2018 1:05 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
I think the carpet is oatmeal with tan trim. Looks like you have mold issues. Or Pigpen living in your car. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
kevzo1 Samba Member
Posted: Sun Oct 21, 2018 9:55 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Ok so the rulebook from WW says T317 Lava (Charcoal) for the carpet color which it appears to be, so what about the trim color, is it a different color from the carpet? |
bluebus86 Banned
Posted: Sun Oct 21, 2018 10:11 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
fabric can change color when exposed, perhaps dissect the trim to take a look at the underside that was not exposed, see if it is a different color?
Good Luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
kevzo1 Samba Member
Posted: Sun Oct 21, 2018 10:20 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Good idea cut back the trim it appears to be grey |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sun Oct 21, 2018 2:26 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Colleague from work had a Sea Sand '66 Beetle 6 years ago with 33,000 original miles. Wonderfully solid and well preserved car. I photo'd it at a local car show, and I just checked some photos. The carpet color was indeed lava, and the cloth sewn edge binding was a dark beige. You could also describe the edge binding color as oatmeal.
Here's a shot of a 8000 original mile '65 Beetle that has carpet color slightly lighter than lava, but the same color edge binding as the '66. The binding color is not grey; it is a dark beige/oatmeal.
If you can carefully separate your large front side footwell carpet piece from the center firewall and rubber section, toss the carpet into the washing machine using the warm cycle, use a non-bleach clothing detergent, then let it air-dry on a clothesline. That will get you much closer to seeing the clean edge binding color.
Year-correct edge binding is a detail you almost never see even on a good restoration. The cheapie carpet kits have edges bound with the same material as the carpet. Others use vinyl, which looks good but is not correct. Having an upholstery shop sew on a beige-colored cloth binding onto even a cheapie carpet set would enhance the carpet appearance immensely. |
Sahara74 Samba Member
Joined: December 12, 2013 Posts: 150 Location: Northern California
Posted: Mon Oct 22, 2018 5:37 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Based on the remnant scraps of carpet from my 66, the original binding is actually a woven cotton light weight tape in a twill pattern. The width of the tape is close to 3/4". The good news is that this type of tape is out there in the world and might be available at your local fabric shop. Since it is cotton, you can dye it any color you wish with Rit dye, also commonly available. Just depends on how nutzoid you are about details but that's what I used to bind my German square weave and it looks pretty spot on. Good luck !! |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Mon Oct 22, 2018 11:51 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
The original binding was a bluish grey color that fades to tan. Check under the back seat where sunlight hasn't' faded the binding.
Refer to this thread of a '64 with 22 miles that's been stored indoors under a cover. Check near the pedals, it looks like it's already faded to a lighter shade compared to the rear floor area. The binding on my '64 is faded to the lighter tan color everywhere except under the seat, where the blue/grey color is still noticeable.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Ddog574 Samba Member
Joined: April 04, 2017 Posts: 3 Location: Vancouver, Wa
Posted: Sun Mar 01, 2020 7:41 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
I as well have a 66 sea blue car and am looking for the correct replacement carpet color. It was lava originally. But now looks like brown with beige binding. So if i am ordering from WW, would this be charcoal? Or gray? Or black? What did u decide kevzo1? |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Mon Mar 02, 2020 10:09 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Why don't you guys go to the technical section of the SAMBA, Paint and upholstery section where it tells you and shows you with pictures what your car is supposed to have? |
harrymarlin Samba Member
Joined: June 07, 2018 Posts: 720 Location: Washington, DC
Posted: Mon Mar 02, 2020 10:44 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Sahara74 wrote: |
Based on the remnant scraps of carpet from my 66, the original binding is actually a woven cotton light weight tape in a twill pattern. The width of the tape is close to 3/4". The good news is that this type of tape is out there in the world and might be available at your local fabric shop. |
I bought original looking binding from Autos International (Porsche specialists): http://www.porschetopsandinteriors.net/, although I went with a more tan one (my original definitely had hints of mauve in it - I didn't think about the blue!) _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
Posted: Mon Mar 02, 2020 9:24 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Helfen wrote: |
Helfen, Ive been everywhere looking for this information. That is why I am asking. Not on WW. Not on the samba under technical. Not on jbugs. Not on West Coast Metric.
I was hoping someone with lava T317 carpet, used in a 1966 beetle interior can tell me what the original color looked like so i can order it. Pictures would be even better.
I would not have posted needing this information if it was that easy to find...and I definitely wouldnt have asked the question if i hadnt searched for weeks. |
Helfen Samba Member
Posted: Mon Mar 02, 2020 9:54 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Ddog574 wrote: |
Helfen wrote: |
It's right here in the technical section of the Samba It tells you what you need to know. I assume you know where the technical section is? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Mon Mar 02, 2020 10:08 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Helfen wrote: |
Ddog574 wrote: |
Helfen wrote: |
Helfen, he wants to know what it actually looks like, preferably with a photo.
I don't know of that being available in the Tech section.
The color name is listed (he lists it above) but not the actual in-person information on what it looks like.
Did I miss it? Please post a direct link or the photo.
Some more stuff I found is below:
I don't know if this is the same but I did a search on lava carpet in the Gallery
https://www.thesamba.com/vw/forum/album_search.php?search_keywords=lava+carpet
2 pics came up:
A search on only Lava came up with this original carpet photo from a Ghia
_________________ How to Post Photos
Helfen Samba Member
Posted: Tue Mar 03, 2020 10:00 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
L360
Sea blue
Year
8/1/65
Models
113,114,117,118
Color Code
Color Name
Color Below Waistline
Upholstery Material (Cloth)
P370/K493
Mosaic Plat./Platinm
Upholstery Material (leatherette)
K499/L493
Platinum/Platinum
Upholstery Material (leatherette#2)
Headliner color
K456B
Cloud white, vinyl
Door pillar color
L358B
Cloud white
Convertible headliner color
Convertible Top Color
Convertible Top Color, alternate
Door panel color
KsK102
Platinum
Door panel color, alternate
Sunroof cover color
Carpet color, front
T317 is the code for Lava
Lava
Carpet color, rear
Armrest color
Ku019
Platinum
Assist strap color
Ku003
Cloud white
Wheel disc (center)
L41
Black
Rim (outer) color
L289
Blue white
Floor mat color
Lava
Steering wheel color
Grey-Black
Gear shift and brake lever color
L43
Grey-black
Seat frame color
Steering column tube color
L43
Grey black
Grab handle color
Lava
FYI the definition of lava has many spectrums of color from bright red out of a volcano to when it cools which is charcoal gray. I'm certain the Lava color for a Seablue car is charcoal. I've owned my 65 for 53years and the carpet was charcoal in color, and when I restored the car in 1974 I installed charcoal. |
Helfen Samba Member
Posted: Tue Mar 03, 2020 10:09 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
A Sea sand painted car
Color code
L568
Sea sand
Year
8/1/65
Models
113,114,117,118
Color Code
Color Name
P371/K494
Mosaic teak/Teak
K504/K498
Black/Black
Headliner color
K456B
Cloud white, vinyl
Door pillar color
L358B
Cloud white
Door panel color
KsK103
Teak
KsK107
Black
Sunroof cover color
Carpet color, front
T317
Lava
Carpet color, rear
Armrest color
Ku041
Black
Assist strap color
Ku003
Cloud white
Wheel disc (center)
L41
Black
Rim (outer) color
L87
Pearl white
Floor mat color
Lava
Grey-Black
L43
Grey-black
Seat frame color
L43
Grey black
Grab handle color
Lava
Running board mat color
Caramel
Bumper color (type 2)
Shift boot
Grey-black
Hub cap color
Dash, shift knobs
FYI, I have a 64 beetle that I've owned since 74 and It's painted L-87 Pearl white and it came with Grey/Black carpet and I restored the car in 1978 and along with the correct L87 paint I installed T305 Gray/Black carpet. |
Posted: Tue Mar 03, 2020 9:34 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Gentlemen,
I placed a call to technical support at WW today and it is confirmed that T317 Lava is german square weave Charcoal.
I apologize for wasting anybody's time. Evidently i should have placed this call weeks ago.
At some point i will start a thread with my perfect patina, yanked out of connex in San Fran, 66 Sea blue beetle. It is a stunning all original never been wrecked beauty. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Mar 04, 2020 6:03 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
Ddog574 wrote: |
In the meantime, tantalize us with a few photos. |
seibert66 Samba Member
Posted: Sun Sep 06, 2020 6:50 pm Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
It's interesting to see the difference between a 1966 Sea Sand interior for the European market compared to the one for the US market. In Europe they had the option of using cloth seats instead of vinyl. When cloth was used, they would combine it with "rust" trim and carpet (code T343) instead of Lava T347 as you show in your picture...I have the Euro interior and I'm wondering if I'll be able to find the original square weave rust carpet and rust trim to match what I have in the back...at the moment I still have the original 1966 carpet only in the luggage area as my reference...
Posted: Wed Sep 09, 2020 11:48 am Post subject: Re: 1966 Beetle Sea Sand Interior Carpet Trim Color |
When I was looking for new binding for the rear package shelf/tray of my 1967 Beetle convertible, I found the exact pattern/texture (Porsche) from Autos International (in Escondido, CA): http://www.porschetopsandinteriors.net/. I assumed my gray darkened a little over time, and got the one, below on the left. The one in the center is the cleanest part of my original I could find, and the one on the right was another option.
It was very inexpensive. _________________ -Harry
