vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Thu Aug 16, 2007 3:18 am Post subject: Anyone tried the Passat steel wheels? |
are the 15x6.5's good with the BF A/T 215/75SR15 ?
i've been too busy to schlep to the pick a part, and i'm tempted just to get them from tire rack. they're only like $44 a pop.
cheers
droo |
Petervw Samba Member
Joined: July 04, 2005 Posts: 1020 Location: Sarnia Ont. Canada
Posted: Thu Aug 16, 2007 4:01 am Post subject: Re: anyone tried the passat steel wheels? |
vwlovr wrote: |
cheers
droo |
I think you need to do some research before buying any steel wheels to avoid being surprised about what you get...vanagon.com has a write-up about passat steelies in there wheel and tire section |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Thu Aug 16, 2007 6:03 am Post subject: |
I had some snow tires from an Audi V8 that a guy loaned me. I actually ran them on the rear of my 87 one season, but they would not fit the front because the hole is too small. Probably would fit a Syncro front, though.
But the real problem is that they are made for 12mm studs. I'm not real happy to put 12mm studs in my hubs. And I thing machining the bosses to OE tolerances might be cost prohibitive. Hell, by that time you'd be up to the price of SA wheels. well, what is the price of SA 15's?. Steel wheels have some great advantages over alloy. Strength and resistance to corrosion being foremost.
So, the answer is NO, not practical.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
vwlovr Samba Member
Posted: Thu Aug 16, 2007 9:32 am Post subject: Re: anyone tried the passat steel wheels? |
Petervw wrote: |
yeah i did vanagon.com says they bolt up without much hassle on a syncro. |
Posted: Thu Aug 16, 2007 10:10 am Post subject: |
yes, but I only got about 4 turns on the nuts. Not enough. That is, unless the Audi wheels are different.
If a guy could get some nuts with a sleeve, then a ball seat (cone), to even get about 4 more turns, it would be enough.
I think this is a bigger problem than the center hole. Tempting, still.
Vanagons:
vwlovr Samba Member
Posted: Thu Aug 16, 2007 10:38 am Post subject: |
yeah, now i'm tempted to go to the junk yard and pick up one for cheap and try i out. i have access to a milling machine so i'm could do some machining if needed, but i'd prefer not to.
i was so bummed, last time i went to the junkyard i found one audi 5000 alloy, the one with bunch of spokes, but sadly they only had one...
getset Samba Member
Joined: March 07, 2005 Posts: 437 Location: PNW | OLY
Posted: Thu Aug 16, 2007 9:09 pm Post subject: |
Yes they are quite nice with 215 75 r15.
Especially with a subaru to turn them
vwlovr Samba Member
Posted: Thu Aug 16, 2007 9:49 pm Post subject: |
jgobel wrote: |
Especially with a subaru to turn them |
those look tasty. did you need any special lugs or bolts, etc?
btw, nice pup, i've got two of them...
vwlovr Samba Member
Posted: Thu Aug 16, 2007 9:52 pm Post subject: |
hey jgobel, btw, did you make the syncro 4x4 sticker? i recently got access to a vinyl cutter and i was just thinking of making one like that today.
thanks for the pic, it's so hard to visualize wheels and tires sometimes.
cheers
andrew |
getset Samba Member
Posted: Fri Aug 17, 2007 12:41 pm Post subject: |
vwlovr,
I did have to have the centers enlarged to 67 mm to clear all the hubs. I had a local machine shop do it for me on their lathe. It is funny how many more people come up to me and ask about the mysterious 4x4 VW now that it has larger more aggressive tires. I think it ended up costing a little under $100 for all four. I still need to get a fifth for a spare, and figure out how to mount it. I am thinking about fabbing up a rear bumper with a swing away on it. Tht is when I get a shop, welder, torch, lots of money, and lots of free time.
The sticker came on it stock, and is slowly now coming off. I have a friend
She is a good pup three years old now, and settling down a little. She is also half wiemeriener (sp?) but luckily she has the shorthair personality. |
noza Samba Member
Joined: January 30, 2006 Posts: 97 Location: walla walla, wa
Posted: Fri Aug 17, 2007 3:04 pm Post subject: |
i have them as well with 215/75/15 and they are not bad. I bought them with the middles bored out.
I had to get spacers for the front, which I got at a local wheel/tire shop for about 10 bucks (1/4" genreic). I then had to get longer wheel bolts for the front (les schwab)
Run up and down the entire west coast on them with no problems. |
remraf Samba Member
Posted: Sat Aug 18, 2007 6:29 am Post subject: |
jgobel wrote: |
What year passat are those off of?
I recently found some full size spares of a late model passat that fit real well and have an et of 37. I was kind of worried about the load rating but realized the late model passats are pretty heavy.
Is there a part # on yours?
Different topic. I'm in the process of putting a 2.2 subie in my syncro passenger van and was curious how you like the performance? |
izzydog Samba Member
Posted: Sat Aug 18, 2007 11:25 am Post subject: |
Are any of you guys with the steelies running 15" big brakes? I've heard that 285 mm rotors and up won't fit so that might be a consideration when choosing a new set of wheels for yer van...
Jeff / 87 Syncaru Westy |
yellowjacket Samba Member
Posted: Tue Dec 04, 2007 9:50 pm Post subject: |
I have the same question Jeff has, do the 15" passat steel wheels fit with any of the big brake calipers? What modifications did you have to make; spacers, longer studs?
I would like to go with bigger calipers/rotors and upgrade to 15 inch steel wheels. My brakes are starting to squeal, so need to decide, stock or upgrade before next spring.
The type of van trips I like, steel would be more suitable. The syncro did great on our trip last month to Utah, going out to Panorama Point in the Maze District was a treat. But got me thinking 15 inch wheels would give alittle more clearance for a return trip down the Flint Trail to the Dollhouse and Maze Overlook, anyone done that tour? _________________ 86 Syncro Westy - Bostig RG11
71 Squareback |
VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Tue Dec 04, 2007 10:40 pm Post subject: Re: anyone tried the passat steel wheels? |
vwlovr wrote: |
cheers
droo |
Hi droo
Might be very well worth your time to go to the pick a part. The one I visit episodically sells **any** alloy wheel WITH tyre for $25.00 each. I don't recall what they ask for steel wheels only that they are cheaper.
You may also want to check CraigList. There I found a set of 15x7, 8 holes Mercedes wheels with tyres for two bags of peanuts. I did luck out as they were previously installed on a Vanagon, so I knew they fit and they came with the bolts and nuts. I only had to buy the longer studs for the rear from SmallCar. Which, by the way, means I'll be putting my VW alloys for sale in classifieds pretty soon, as soon as I concoct a solution the (3 missing) center caps issue, as I refuse to pay the extravagant (to me) prices some guys ask for 4 pieces of s...t plastic that will fly away anyway.
Good luck |
HetzerHarry Samba Member
Joined: July 06, 2004 Posts: 46 Location: Encino, SFV, CA.
Posted: Sat Dec 08, 2007 11:40 am Post subject: |
I have heard the "big brakes" don't fit with the steel wheels.
I will say I love them, running 235 75 15's makes me think they should have been fitted with 15's all along. It is very stable, easier to get off road tires for & of course the added ground clearance is wonderful.
I had a local machinist open the centers up I think it was 10 bucks a wheel (had him do 6). I do suggest you get a balancing shop that can do a "lug centric" balance since it is hard to get the centers true.
The rear lugs get enough purchase on the threads to hold them well... I've given them plenty of testing... they will just look 3/4 tight.
Contact me for additional pics or questions.
Harry
_________________ 1987 SYNCRO GL (steel 15's) 250k
A tank... (its a long story) |
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Sat Dec 08, 2007 9:38 pm Post subject: |
I did the same mod as Stromline mentioned. My passat wheels came from an '02 and are ET37. I had the center bores enlarged and I painted them silver.
I did try these wheels on a buddy's syncro that had the Van Cafe Big Brake kit. They did NOT fit. Even with an 8mm spacer still the inner welded structure of the wheel hit the caliper. I was sort of bummed about that.
_________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!) |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Sat Dec 08, 2007 10:23 pm Post subject: |
Stromline wrote: |
I do suggest you get a balancing shop that can do a "lug centric" balance since it is hard to get the centers true. |
Done at a machine shop and not true? Eeeeekkkkk!
I did mine by hand with a cut off wheel on a grinder and they are certainly close enough for balancing purposes. Not perfect, but I don't have any balance issues up to 85MPH, fwiw.
But if you're going to go thorough the hassle of bigger wheels why not just go to 16's and be done with it? Assuming you have an engine othert han stock back there.
Mine were $49 each from tire rack, ET 42, 12 mm spacers from Loggy and I'm all set.
I used old tiny cut-off wheels to make the center hole bigger, scribed a line into the paint on both sides first, used the existing hole for a guide for my line,
195 75 16s, they are 27.5" in diameter, and I can still fit some extremely burley chains in there, I picked up an additional 1 1/4" of ground clearance plus %10 taller gearing for extra MPGs,
Posted: Sun Dec 09, 2007 10:28 am Post subject: |
My centers are maybe 2 or 3mm out of round... I know that's not too bad.
I'm just a balance perfectionist!
With my 235's I can't do much in the way of a snow chain, unless I mill off some lip on the lower trailing arm, or get 16" versions. Here in SoCal, snow is not often seen. (sure would be fun to play in it though!!!)
Harry _________________ 1987 SYNCRO GL (steel 15's) 250k
jwallis Samba Member
Posted: Mon Mar 09, 2020 9:38 am Post subject: Re: anyone tried the passat steel wheels? |
Sorry to revive a long-dead thread, but what is the point of this? Don't these steel wheels look *really* similar to the cheap stock vanagon wheels? _________________ TheVanTracker.com - Kill Switch + GPS Tracker + Door-open alerts, made specifically for the Vanagon!
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
