HaggardMelon Samba Member
Joined: August 08, 2018 Posts: 147 Location: Washington
Posted: Thu Mar 12, 2020 5:49 pm Post subject: Stalling When Coming to Stop Downhill Only |
1970 Beetle Sedan / 1600cc SP
A while back I replaced my fuel pump, fuel tank, carburetor (h30/31 PICT) and distributor (Pertronix Flame Thrower 009 type).
I've noticed when coming to a stop when going downhill, when I press the clutch and it lets go of the engine, the RPM drops down to about 500 and it will be chugging a bit like it wants to die. It has only actually died once.
It seems to be much worse when the car is cold. Once warmed up, it's not as much of an issue.
If I just barely blip the throttle, it's straightens up and runs fine again.
I believe the carb is tuned properly. When warmed up and in all other situations it idles nice at 850 RPM without any real issues.
What could be going on here? This is a brand new carb. Is it possible it just had some issues out of the box?
Also, timing is set correctly, I haven't found any vacuum leaks and I believe the choke is set correctly as well.
Thanks! |
mukluk Samba Member
Posted: Thu Mar 12, 2020 6:13 pm Post subject: Re: Stalling When Coming to Stop Downhill Only |
Idle mixture is too lean. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Mar 12, 2020 7:05 pm Post subject: Re: Stalling When Coming to Stop Downhill Only |
Is it okay for me to back that screw out like a ¼ of a turn before each drive to see when it improves, or should I reset everything and start over again? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Mar 12, 2020 7:26 pm Post subject: Re: Stalling When Coming to Stop Downhill Only |
jwuori1635 wrote: |
Yes. Keep track of the screw turns. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
airschooled Air-Schooled
Posted: Fri Mar 13, 2020 8:31 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
I have a secret technique for adjusting stock-style carburetors that isn’t in any manual, ready for it?
1. Ignore everything you’ve read about carburetors.
2. On a warm engine, turn the small screw until the engine is happiest.
3. Turn the big screw until you like the speed.
That’s it. Really.
If you count the number of turns you do, you can always go back to where it was in case you make it worse.
Good luck,
www.airschooled.com |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Mar 13, 2020 8:37 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
I had that same issue once with a 009. The timing was a bit too retarded. Advanced it like 2 degrees and it was better. Never figured out why it was only on the downhills. Maybe I was lean as well? IDK. That's setup is long gone. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Fri Mar 13, 2020 9:55 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
If the problem is only when facing downhill I'd look to the fuel level in the carb fuel bowl. Warm up the engine allowing time for the engine to stabilize. Rev the engine and hold it at 2500rpm for 10sec to get the greatest output from the fuel mechanical pump. Immediately shutoff the engine w/o letting it idle. Remove the top of the carb and measure the level of the fuel in the bowl. Normally, the float and inlet valve maintain the level at 3/4" from the top of the bowl. If the fuel level is too high you might experience issues with fuel overflowing from the bowl into the carb when tilted (up/downhill). _________________ AshMan40
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 641 Location: Reno NV
Posted: Fri Mar 13, 2020 10:01 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
asiab3 wrote: |
That’s it. Really.
Good luck,
Robbie |
Now you have done it. It's no longer a secret technique _________________ Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, ***** |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Fri Mar 13, 2020 10:04 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
There are 3 main things that can cause this (to only happen on down hills, all of which I have stuggled with for months before finding....)
1. Float level too low - If your float level is rather low, the extra retarded timing of the 009 at idle combined with a sudden real lean mixture just causes the engine to cut
2. Intake leak - Pretty self explanitory
3. impropper fuel pressure (low or high) - Over pressurizing will cause some horrendous cold startups and you basicaly just flood the carb. This will typicaly cause the issue regardless of up or down a hill from what i hear, but for me it was only down hill. Low fuel pressure causes the pump to not have enough suction to pull the fuel against the acceleration of breaking. Typicaly though this will also cause a general rough idle and realy exacerbate the deadspot of the 009+pict34 _________________ '74 - front disks/lots more work to do |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Fri Mar 13, 2020 10:34 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
given OPs location, i would add intake air preheat to the list. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Fri Mar 13, 2020 11:07 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
One other things to check... loose intake center section. I recall a report of someone who had left the heat riser tubes unconnected at the exhaust (because their headers didn't have flanges) so the intake center + carb was only being supported by their connection to the two end castings. In this case the clamps on the boots were loose enough that on hard braking or going downhill caused the intake + carb to rotate towards the fan shroud. This changed the fuel level in the bowl.
The point above about too little fuel in the bowl also makes sense. When the fuel shifts it exposes the main jet and the engine struggles. _________________ AshMan40
Posted: Sat Mar 14, 2020 7:43 pm Post subject: Re: Stalling When Coming to Stop Downhill Only |
Thanks for the tips, everyone. I'll do some tinkering with it and see if it clears up. I was hoping since the carburetor was brand new I wouldn't have to worry about it too much.
If the float level is incorrect, is there any adjustability with that, or does that just point to fuel pressure issues?
Like I mentioned earlier, there's a new tank, cleaned the metal line out really well, new fuel pump, new filter, new carburetor.
Hopefully I can just adjust the mixture a bit to straighten it out.
Also, someone mentioned intake heat. This may end up being an issue. I have noticed on one side, the heat riser barely gets warm. The other side is too hot to touch within seconds. Can't remember which was which, but it's the side the hot air doesn't go through first that's just barely warm. |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Sun Mar 15, 2020 5:35 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
What brand/model is the new carb? _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
cbeck Samba Member
mukluk Samba Member
Posted: Sun Mar 15, 2020 11:54 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
jwuori1635 wrote: |
It's a good idea even with brand new carburetors to pull them apart and give them a good cleaning -- some people have found small metal shavings or other debris left over from the manufacturing process inside.
The float bowl fuel level on stock type Solex carbs is adjusted by varying the thickness of the washer between the needle valve and the carb upper body. Rebuild kits usually come with a 0.5mm and a 1.0mm washer that can installed singly or paired for this purpose.
Regarding the manifold heat, it's normal for the one side feeding directly off the cylinder exhaust stub to be very hot while the other side is not nearly as hot, this being a result of the intake manifold center absorbing heat from the riser tube. The important thing is the cooler side isn't cold to the touch, indicating the riser may be clogged. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Mar 16, 2020 6:08 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
Okay. Yeah it's just lukewarm on the one side so there's definitely some heat getting through. |
Posted: Mon Mar 16, 2020 7:23 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
mukluk wrote: |
The float bowl fuel level on stock type Solex carbs is adjusted by varying the thickness of the washer between the needle valve and the carb upper body. Rebuild kits usually come with a 0.5mm and a 1.0mm washer that can installed singly or paired for this purpose. |
... the thinner washers raise the level of the fuel; thicker washers lower the level as they move the height of the inlet valve. The default washer size used on the Solex Pict carbs is as follows:
1.0mm thick washer = 28Pict-1 & -2, 30Pict-1 & -2
1.0mm + 0.5mm washers = 30Pict-3; H30/31
0.5mm washer = 34Pict-3
Also check that the float has not failed. They can leak and fill will fuel and sink prematurely. Leaking floats need to be replaced. _________________ AshMan40
jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 459 Location: GALWAY,IRELAND
Posted: Mon Mar 16, 2020 8:30 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
When I changed my worn out original 30pict3 for a new, out of the box Brosol H30 I had the same kind of problems on my stock 72 1200.
I added a fuel filter just over the rear drive axle where the clutch lever arm. I use an easily available, cheap, good quality VW rabbit MK1 or 2 fuel filter with 2 jubilee clamps to secure it. Don't forget to check that your fuel pump may have a little built in filter mesh,if so like my one,
it can easily clog causing your problem.
I found my ignition timing needed to be retarded slightly just one or 2 degrees down from near 30degrees all out to near 28 degrees all out.
Then after taking it for a drive, with a hot engine I raised the idle speed by about 50 rpm more than where it was with the original carb.
This just took between a quarter and half a turn clockwise of the Idle Screw.
Try it and see if that helps.😎Worked for me. |
Posted: Fri Apr 17, 2020 11:44 am Post subject: Re: Stalling When Coming to Stop Downhill Only |
Thanks, armchair. I'll try that too. I've been wanting to move the fuel filter to somewhere safer anyway. |
