Slip356 Samba Member
Posted: Tue Mar 17, 2020 6:25 am Post subject: Re: The Stupid Question Thread |
The O ring for the spout is a hardware store item. The faucet rubber seal (can’t think of correct name) is another story. I searched everywhere, no luck. Finally robed one off an old Westy faucet and now no leaks.
Let me know if anyone has a source as they don’t last forever.
Slip |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Tue Mar 17, 2020 7:17 am Post subject: Re: The Stupid Question Thread |
Slip356 wrote: |
Slip |
I ended up yanking (the spout was really in there) the faucet out to replace the seal. It was torn when I removed it, though I don’t know if that was the true condition or took place when I pulled it out. Matched it up to some o-rings I had, reinstalled.
Now, it leaks worse. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
smitty1976bus Samba Member
Joined: January 21, 2013 Posts: 369 Location: Cape Cod
Posted: Fri Mar 20, 2020 12:19 pm Post subject: Re: The Stupid Question Thread |
1978 vw 2.0L EFI, Power Brakes.
I'm slowly loosing brake fluid, and can't find a leak anywhere. I assume that master cylinder is leaking into the brake booster, is there anyway to confirm this with out taking it all apart? Would i find brake fluid in the vacuum line by the engine?
Or am i loosing fluid anywhere else? Like the brake light switch? Could the fluid be leaking into the wires... could I check the brake light bulbs and see if theyre filled with brake fluid??<<< sorry, been social distancing all week and going crazy, first half of this post was a real question>>>> |
Posted: Fri Mar 20, 2020 12:47 pm Post subject: Re: The Stupid Question Thread |
smitty1976bus wrote: |
Loosen the master from the booster and see if there is any fluid to be seen. |
Posted: Fri Mar 20, 2020 6:04 pm Post subject: Re: The Stupid Question Thread |
Seems to be some. Do I just need to replace the o-ring between the master and booster:
Or do the seals inside the master itself need to be replaced?
Or is it easier to just by a new unit? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Mar 20, 2020 6:14 pm Post subject: Re: The Stupid Question Thread |
Seems to be some. Do I just need to replace the o-ring between the master and booster: |
If only it was that easy, you need to replace the master cylinder, and wash out the booster now since it's contaminated with brake fluid. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 20, 2020 7:44 pm Post subject: Re: The Stupid Question Thread |
I agree with Busdaddy, you need to replace the master cylinder and drain the booster as best you can. The seals in the master are what separate the brake fluid and the vacuum in the booster, the o-ring just seals between the vacuum and the ambient air. |
laneven28 Samba Member
Joined: January 09, 2007 Posts: 312 Location: Cedar Hills, Utah
Posted: Fri Mar 20, 2020 9:35 pm Post subject: Re: The Stupid Question Thread |
First time bay owner, 71 Westy. My body guy is wondering if the small hole below the tail light opening in lower right corner of panel should be there (not the apron)? If so, both sides? And what for?
_________________ 1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Fri Mar 20, 2020 10:38 pm Post subject: Re: The Stupid Question Thread |
laneven28 wrote: |
Yes, it was there from the factory. Probably for some kind of rust-proofing chassis spray.
www.airschooled.com |
Posted: Sat Mar 21, 2020 8:12 am Post subject: Re: The Stupid Question Thread |
laneven28 wrote: |
Robbie |
Thanks. Do you know if the hole was on both sides? I would assume so, but assuming has got me in trouble before. _________________ 1950 Pearl Grey Hoffman Standard Split Window
Posted: Sat Mar 21, 2020 8:19 am Post subject: Re: The Stupid Question Thread |
laneven28 wrote: |
laneven28 wrote: |
Robbie |
Thanks. Do you know if the hole was on both sides? I would assume so, but assuming has got me in trouble before. |
Yes, both sides once matched. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Mar 21, 2020 8:30 am Post subject: Re: The Stupid Question Thread |
The hole on the right side tends to disappear earlier because of acid from the starting battery. |
Posted: Sat Mar 21, 2020 8:34 am Post subject: Re: The Stupid Question Thread |
Thanks everyone _________________ 1950 Pearl Grey Hoffman Standard Split Window
maz-o Samba Member
Joined: February 21, 2017 Posts: 79 Location: Helsinki, Finland
Posted: Sun Mar 22, 2020 8:47 am Post subject: Re: The Stupid Question Thread |
Would it be stupid to just cut off this "diagnostic tool" bracket? I'm pretty sure I won't ever use it. Tidying up the engine bay as we speak and it would make things a lot neater. Has anyone else here just cut the thing off?
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Mar 23, 2020 4:23 pm Post subject: Re: The Stupid Question Thread |
the trans fill and drain plugs on my manual 73 bus are 17mm, right? |
Posted: Mon Mar 23, 2020 4:36 pm Post subject: Re: The Stupid Question Thread |
alman72 wrote: |
Correct. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
alman72 wrote: |
Yep. "Allen head" helps with searching websites or hardware stores.
maz-o wrote: |
Would it be stupid to just cut off this "diagnostic tool" bracket? I'm pretty sure I won't ever use it. Tidying up the engine bay as we speak and it would make things a lot neater. Has anyone else here just cut the thing off? |
You would not be the first, nor the last. I'd probably use it to mount an engine compartment light switch, perhaps a push-button momentary switch that engages when you open the deck lid? If you can make the cut clean and avoid an arm-slicing finish, it's your bus. You won't win a concours show, but then again, camping at the beach is better than Pebble Beach 10 times out of 10.
Posted: Mon Mar 23, 2020 4:38 pm Post subject: Re: The Stupid Question Thread |
maz-o wrote: |
[img]pic[/img] |
It's your bus, the diagnostic plug is pretty well a non functional decoration these days, if you want it gone do it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 23, 2020 5:30 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
maz-o wrote: |
[img]pic[/img] |
It's your bus, the diagnostic plug is pretty well a non functional decoration these days, if you want it gone do it. |
I think there is a small market for the female side of this pug for some that want to play with this port cleanly. maybe 3d print? Unfortunate that the only examples for a scan (for printing) are on diagnostic units that were put in the landfill a long time ago.
has anyone here found one of them? not for my grand 3d plan, but just for fun? |
