jimf909 Samba Member
Posted: Fri Mar 27, 2020 7:55 pm Post subject: Quick question: what does it take to pull an R&P? |
Somewhat random, hypothetical question for all y'all sitting around waiting to be released.
I've got a 4 speed 2WD manual transmission. What does it take to R&R the R&P once the trans is pulled, say, if the trans never would be used, e.g. if I just wanted to replace the R&P and sell the trans as a core?
Am I correct in believing that the tranny pretty much has to come apart to get the pinion shaft? How many hours would that take? Are the bearings and gears pressed on (sorry, Ive never been inside one of these).
I know this isn't a 2WD but its the best image I could find...
Thanks. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Fri Mar 27, 2020 8:16 pm Post subject: Cutaway diagram 2WD Vanagon transaxle gearbox transmission |
It requires 100% disassembly.
If you were putting a trans together the pinion shaft is the first part that you pick up.
edit for Samba pic searches: Cutaway diagram 2WD Vanagon transaxle gearbox transmission tranny case 091 091/1 _________________
....KTMs, GasGas, SPOT mtb
Posted: Fri Mar 27, 2020 9:11 pm Post subject: Re: Quick question: what does it take to pull an R&P? |
That's what I thought. Thanks. I'm looking forward to sharing pics of last year's rebuild in a week or two.
It started with this...
Waldi wrote: |
Send it back to the rebuilder. |
Abscate wrote: |
