Bobnotch Samba Member
Posted: Sun Mar 29, 2020 7:13 am Post subject: Re: My first type 3 |
sjbartnik wrote: |
Don't forget, that 30mm fan hub bolt is torqued to ~100 ft lbs., not the ~30 ft-lbs. for a Type 1 pulley. |
Yup, or it'll come off, rattle a little bit, then make a hell of a noise. BTDT once, had to replace the bolt afterward. Bentley spec is 95 to 103 ftlbs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Sun Mar 29, 2020 10:36 am Post subject: Re: My first type 3 |
sjbartnik wrote: |
Yea I got the warning about the pulley bolt.
My torque wrench only goes to 75 ft. lbs. so I maxed that out and with a breaker bar gave it a little more with an educated guess.
I'm pretty confident it'll stay putt but I will definitely keep an eye on it.
Thanks guys. |
QRP Samba Member
Posted: Sun Mar 29, 2020 11:12 am Post subject: Re: My first type 3 |
Gonna try and muster up some linkage with spare parts.
And for the record, I did not butcher the Deano linkage. I got it that way years ago.
gotta get the cable link a little lower to line it up better, maybe just weld this piece here. I'll figure something out before dropping a bill on new stuff.
gt1953 Samba Member
Posted: Sun Mar 29, 2020 12:11 pm Post subject: Re: My first type 3 |
Nice work you have been doing. Clean is great way when going back together. On my oil pressure sending unit I added a 90 degree fitting for clearance. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
QRP Samba Member
Posted: Sun Mar 29, 2020 6:43 pm Post subject: Re: My first type 3 |
OK I'm sure everyone could use a good laugh about now with all this virus BS going on out there.
Tight on money and still not sure what exhaust I want yet so I went on a tweaker in the garage today.
Type 1 monza into type 3 single tip.
It's super ghetto but it'll do for now . . . LOL
Please feel free to talk all the crap you want or leave any wise ass comments you can think of. My feelings will not be hurt.
Stay safe out there!
Posted: Mon Mar 30, 2020 12:14 pm Post subject: Re: My first type 3 |
QRP wrote: |
Hey, if it works, it can't be any worse than the 2 outlet 4 tip version. Those are absolutely the worse muffler set up on a type 3. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
QRP Samba Member
Posted: Tue Mar 31, 2020 10:19 pm Post subject: Re: My first type 3 |
Nothing special today, trying to get something that at least looks like a seat together.
Getting closer to first fire up.
old_man Samba Member
Joined: June 19, 2018 Posts: 1382 Location: Newfoundland
Posted: Wed Apr 01, 2020 5:48 am Post subject: Re: My first type 3 |
Looking nice. Are you planning on having heat at all? There is also a piece of foam/insulation that is suppose to go on top of the oil cooler, not sure I can see it in your pic. Interesting seat. |
QRP Samba Member
Posted: Wed Apr 01, 2020 8:11 am Post subject: Re: My first type 3 |
old_man wrote: |
I did put foam strips along this area.
Funny you ask about the heat.
I don't plan on having it just yet but I do have a question about the heater boxes .
Even when not being used should there still be a hose from the fan housing to the heater box to keep it from cooking itself? |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Wed Apr 01, 2020 8:57 am Post subject: Re: My first type 3 |
YES! The Type 3 HB have a lot of heat flowing through them even with the heater lever off. If you don't have forced air from the fan blowing through them whenever the engine is running, the heat will rise and overheat your head and at least one cylinder. I speak from experience...
What I did was to insert one of these type 1 heat exchanger hose connectors into the top of each Type 3 HB and RIVET it in place. Don't use sheetmetal scews which can work loose. Then route the air hose from the fan shroud outlet down into the upper part of that connector, and use a good hose clamp to hold the hose in place.
http://vwparts.aircooled.net/Muffler-to-Heater-Hose-Connector-Pipe-113255165-p/113-255-165.htm |
Posted: Wed Apr 01, 2020 11:05 am Post subject: Re: My first type 3 |
Rome wrote: |
Yup, I've done that to several type 3s over the years without the stock muffler set up. The idea behind pushing air thru the heat exchangers (in the summer months for example) is to help pull the heat out of the heads. It does work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
QRP Samba Member
Posted: Wed Apr 01, 2020 8:10 pm Post subject: Re: My first type 3 |
Thought I was gonna test run the motor today but this starter is giving me issues.
Starter spins no problem in the trany but bolted up to the motor it won't turn it over . . UGH
I was just gonna turn it over to get some oil pressure going before firing it up.
Plugs are out and motor spins by hand.
Might have to pull the one from the ghia and see if the starter is the problem. Or try a different battery.
QRP Samba Member
Posted: Thu Apr 02, 2020 9:48 am Post subject: Re: My first type 3 |
OK figured out that problem.
Turns out the ground side of my jumper cable was jacked! Thats the last time I let my neighbor use em.
All good now, stay tuned for start up. |
QRP Samba Member
QRP Samba Member
Posted: Fri Apr 03, 2020 12:13 pm Post subject: Re: My first type 3 |
Now that the motor is dialed in I was crawling around under the squareback this morning to clean up a little and prep for installing the motor and I noticed this.
I'm lucky I noticed this in time . . UGH
QRP Samba Member
Posted: Fri Apr 03, 2020 5:53 pm Post subject: Re: My first type 3 |
Trany mount problem solved.
Cleaning out the engine air intake, how does all this get in there when the air should be going the other direction.
QRP Samba Member
Posted: Sun Apr 05, 2020 10:32 am Post subject: Re: My first type 3 |
I gotta hand it to you type 3 guys, putting the motor in one of these is a breeze compared to a type 1
There's so much room to work with!
That home grown exhaust pipe came out perfect . . LOL
Posted: Mon Apr 06, 2020 11:13 am Post subject: Re: My first type 3 |
So, were you able to get a new trans mount?
Yes, they do offer more room than a bug or even a bus to install. Looks good in there. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
QRP Samba Member
Posted: Mon Apr 06, 2020 2:08 pm Post subject: Re: My first type 3 |
Bobnotch wrote: |
Yes, they do offer more room than a bug or even a bus to install. Looks good in there. |
I was actually able to fix the one I have.
I drilled through the mount in these two spots and used 2 10mm bolts with counter sink heads to hold it together, it wasn't ripped all the way in half it was an easy fix. Probably better than stock.
I goofed and didn't take any pics before I reinstalled it.
One thing that ain't so easy to install is that large air intake boot.
Still not done with that. . . UGH |
Posted: Mon Apr 06, 2020 2:12 pm Post subject: Re: My first type 3 |
Keep in mind 2 things on that boot. The large end goes to the body. And the thick rubber lugs go down and have a slit in then for the cooling boot clamps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
