Smurf Samba Member
Joined: January 20, 2004 Posts: 914 Location: Colmar, PA
Posted: Fri Mar 27, 2020 8:22 am Post subject: Does this look right? Nose cone chassis area |
Does this look right on my ‘62 chassis? Should the hole for the trans cone have this oblong shape to it?
_________________ 1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Mar 27, 2020 8:31 am Post subject: Re: Does this look right? Nose cone chassis area |
It's 'spoda be round, It looks like it got hammered by the nose cone after a long time with a bad front mount. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
donco735 Samba Member
Joined: December 13, 2018 Posts: 38 Location: New Mexico
Posted: Fri Mar 27, 2020 5:33 pm Post subject: Re: Does this look right? Nose cone chassis area |
ditto, should be round.
Smurf Samba Member
Posted: Fri Mar 27, 2020 6:10 pm Post subject: Re: Does this look right? Nose cone chassis area |
donco735 wrote: |
Dang, looks like I’ll have to post a wanted ad. Trans mount must’ve be loose/bad for years _________________ 1962 Beetle
-Men at Work |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Fri Mar 27, 2020 6:30 pm Post subject: Re: Does this look right? Nose cone chassis area |
That is easily fixable, all you needs is a hammer and dolly... maybe not even a dolly and just a flat edge. plus, if you f up, its not like you see it and neither will it affect operation. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
bluebus86 Banned
Posted: Sat Mar 28, 2020 7:12 am Post subject: Re: Does this look right? Nose cone chassis area |
Or... just LITFA, the seal should still cover the opening & no one will ever see it again. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Mar 28, 2020 11:30 am Post subject: Re: Does this look right? Nose cone chassis area |
Hey, so I just checked my 66 chassis and I have the same issue. It was a baja so it was most likely driven hard.
'66 RIP
'69 RIP
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 334 Location: Right Coast, Florida
Posted: Sat Mar 28, 2020 7:45 pm Post subject: Re: Does this look right? Nose cone chassis area |
Flop Stop, or a mid mount trans bracket will help prevent the damage. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
bad91teg Samba Member
Joined: February 13, 2007 Posts: 473 Location: florida
Posted: Sun Mar 29, 2020 5:13 am Post subject: Re: Does this look right? Nose cone chassis area |
Chickensoup wrote: |
wow that sucker took some abuse |
Smurf Samba Member
Posted: Sun Mar 29, 2020 1:06 pm Post subject: Re: Does this look right? Nose cone chassis area |
That is easily fixable, all you needs is a hammer and dolly... maybe not even a dolly and just a flat edge. plus, if you f up, its not like you see it and neither will it affect operation. |
That’s what I’m thinking of doing now. The top of this where the inspection plate goes is kinda buggered up too. Someone at some point I time had one of those backup switches installed at the coupler _________________ 1962 Beetle
-Men at Work |
Smurf Samba Member
Posted: Sun Mar 29, 2020 1:07 pm Post subject: Re: Does this look right? Nose cone chassis area |
Now I don’t feel so bad about mine
Is that a chassis you are planning on using? _________________ 1962 Beetle
-Men at Work |
Posted: Sun Mar 29, 2020 1:14 pm Post subject: Re: Does this look right? Nose cone chassis area |
No, it's just scrap metal and for parts _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
